    [RRF3.3b2] Possibly incorrect behavior when homing Z
    Beta Firmware
    950
    • OwenDundefined
      OwenD @pkos
      @pkos said in [RRF3.3b2] Possibly incorrect behavior when homing Z:
      @owend
      Just to be clear.
      You take the gantry to 100.
      You turn the printer off completely.
      You turn the printer on and Home z - and then it also just raises a tiny bit even though the first probe needed a drop fo 100?
      The switched off printer is the key here. If it's already homed, the problem does not exist.
      You could be right. I didn't turn the printer off.
      • pkosundefined
        pkos @Phaedrux
        @phaedrux Just checking in - is this possibly something that can be checked seeing as how others are now confirming the issue?
        Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
          Yes I've asked @DC42 to comment when he gets a chance.
          pkosundefined 1 Reply Last reply Reply Quote 0
          • pkosundefined
            pkos @Phaedrux
            @phaedrux FYI - checked with 3.3b3 - behavior still there.
            • sebkritikelundefined
              sebkritikel
              I can verify this behavior as well
              Duet2 Wifi +Duex5
              Duet Web Control 3.3.0-b3
              RepRapFirmware for Duet 2 WiFi/Ethernet 3.3beta3 (2021-04-22)
              Large(ish?) IDEX - 6HC, 1HCL
              Stratasys Dimension 1200es to 6HC Conversion
                dc42 administrators @sebkritikel
                I've tried and failed to reproduce this behaviour. However, I have found a bug:
                • If I set M558 F1000:300 A1 (or I don't specify the A parameter in the original M558 command), then homing Z using G30 probes just once and then reports "Homing failed".
                • If I set M558 F1000:300 A2, then homing Z works. It probes once at the fast speed, moves up to the dive height (even if I started at a much greater height with Z not homed), then probes twice at the slow speed.
                My G30 command to home Z has no parameters.
                @pkps and @fulg, does the issue still occur if you remove the Z-99999 parameter from the G30 command?
                @pkos and @sebkritikel, what A parameter are you using?
                pkosundefined sebkritikelundefined 2 Replies Last reply Reply Quote 0
                • pkosundefined
                  pkos @dc42
                  @dc42 I am using A10.
                  Just in case, my config is at the top.
                  I am not sure if you need the whole config.g or if the things up there are enough.
                    dc42 administrators @pkos
                    @pkos, I just found a way to reproduce the issue you saw:
                    • Send Z to +50
                    • Send G92 Z0
                    • Send M18 Z to flag Z as not homed
                    • Send G30 (after setting M558 A2 to avoid the other bug)
                    I am about to test the fix.
                    • pkosundefined
                      pkos @dc42
                      @dc42 Nice. I saw that M18 would also trigger this, but couldn't always reproduce it (so didn't want to waste your time with it).
                      For the time being, I just removed M18 from my end gcode 😉
                      Awesome you found it.
                        The fix is working and will be in 3.3RC1.
                        pkosundefined 1 Reply Last reply Reply Quote 1
                        • pkosundefined
                          pkos @dc42
                          @dc42 Awesome. Can't wait 🙂 Thank you.
                            sebkritikel @dc42
                            @dc42 said in [RRF3.3b2] Possibly incorrect behavior when homing Z:
                            For posterity:
                            M558 P9 C"^zprobe.in" H5 F1000:200 A8 R0.75 T6000 S.02
