M291 messages ignored by PanelDue
PanelDue
2.4k
    flobler
    Hello everyone,
    I have an issue where messages that are issued via M291 are being displayed in DWC but not the PanelDue. It worked fine with the same macro before but somehow stopped working (I really cannot recall having changed anything about the macro).
    Some information on my setup:
    PanelDue 5i: v3.2.11
    DWC: 3.3.0-b2
    Mini 5+: 3.3beta2
    Printer: MK3S Bear
    Wiring: Ribbon cable (re-used from the original Prusa LCD), ca 60cm long
    Here is the initial snipped of macro I am referencing:
    M291 P"Do you want to start the SELF TEST? Press OK to start or CANCEL to abort!" S3 R"SELF TEST" ; requires user input to start or abort the self test
    ; motor test
    ; verifies the correct motor moving direction
    M291 P"We are now testing if all MOTORS are turning in the right direction. Press OK to start or CANCEL to abort!" S3 R"MOTOR TEST" ; requires user input to start or abort the motor test
    G91        ; relative positioning
    G1 X20 F500        ; moves X slowly to the right
    M400        ; wait for current moves to finish
    M291 P"Did the X AXIS move to the right? Press OK to confirm or CANCEL to abort!" S3 ; requires user input to confirm if test was successful, confirm or abort
    G1 Y20 F500        ; moves Y slowly forward
    M291 P"Did the Y AXIS move forward? Press OK to confirm or CANCEL to abort!" S3      ; requires user input to confirm if test was successful, confirm or abort
    G1 Z20 F500        ; moves Z slowly upwards
    M291 P"Did the Z AXIS move upwards? Press OK to confirm or CANCEL to abort!" S3      ; requires user input to confirm if test was successful, confirm or abort
    G90        ; absolute positioning
    M291 P"MOTOR TEST successful!" R"MOTOR TEST" S1 T3 ; message to confirm succesful motor test
    My problem is that the last M291 (P"MOTOR TEST successful!" R"MOTOR TEST" S1 T3) is not being displayed on the PanelDue, the other messages are.
    The macro itself provides a self-test for a user before starting to use the machine, after wiring everything etc. The snippet I am sharing is the first part of it. Further things that are being checked:
    • SuperPinda
    • Homing
    • Fans
    • Heaters + thermistors
    Each of those has their own section with a M291 that confirms the test being successful at the end, like in the example shared above. Once the message disappears, the next step of the test starts. This all happens in a single macro.
    For each section, only the confirmation message at the end is not displayed on PanelDue, other messages are. All are displayed in DWC.
    Thanks in advance!
    undefined 1 Reply Last reply 30 Apr 2021, 10:09 Reply Quote 0
      wilriker @flobler
      @flobler For all other messages you have M400 before M291 but the last one the order is reversed. Try to put M400 before M291 there also. That should fix it.
      Manuel
      My Tool Collection
      undefined undefined undefined 3 Replies Last reply 30 Apr 2021, 11:33 Reply Quote 1
        cosmowave @wilriker
        i have a general question for learning more about conditional code:
        what does the "{1}" below the m291 message mean?
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        undefined 1 Reply Last reply 30 Apr 2021, 13:24 Reply Quote 0
          engikeneer @cosmowave
          @cosmowave think that might be an issue with the forum rather than the actual code. Sometimes people get {1} appearing on line breaks when copying code over. I know the moderators have had a look at it but not managed to track down why the forum does it....
          i3 clone with a bunch of mods
          undefined 1 Reply Last reply 30 Apr 2021, 13:37 Reply Quote 1
            cosmowave @engikeneer
            @engikeneer ah ok. Thanks for the explanation.
            I'm asking me, what happens with this code:
            It's clear, when the user press ok, the macro will go on.
            But when the user press cancel? Is it like a return command from the macro?
            undefined 1 Reply Last reply 2 May 2021, 14:06 Reply Quote 0
              flobler @wilriker
              @wilriker thank you, I will try that!
                flobler @cosmowave
                @cosmowave yeah, the {1} somehow is added when I copy/paste on the forum here. I figured out that it goes away is I make a "space" at the start of the empty line.
                If you press "CANCEL" the whole macro will be aborted.
                  mfs12 @wilriker
                  @wilriker said in M291 messages ignored by PanelDue:
                  @fobler can you confirm this suggestion solved your issue and if so can you post an example? This would be helpful.
                  Visit me on github at https://github.com/mfs12/
                  undefined 1 Reply Last reply 26 Jun 2021, 10:37 Reply Quote 0
                    flobler @mfs12
                    @mfs12 @wilriker apologies it took me a while to get back to it. It does not really seem to solve this, no. I just tried it with a different macro where I had the same issue:
                    ; filament_load.g
                    ; called to load filament
                    if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed ; not all axes are homed
                      G28        ; home all
                    if move.axes[2].machinePosition < 100
                    	G1 Z120 F1500   ; lift Z axis to 120mm
                    else
                    	G1 Z10 F1500 H2 ; lift Z axis by 10mm
                    M116        	    ; wait for the temperatures to be reached
                    M300 S300 P1000     ; beep sound when temperature is reached
                    M291 P"Do you want to load FILAMENT now? Press OK to continue or CANCEL to abort!" S3 ; requires user input to start the filament loading procedure
                    M291 P"Loading FILAMENT..." S1 T60                                                    ; message confirming that filament is being loaded
                    M83                 ; set extruder to relative mode
                    G1 E80 F400	        ; feed 80mm of filament fast
                    G1 E50 F100	        ; feed 50mm of filament slow
                    M292                ; clear messages
                    while true
                        if iterations = 10
                           break
                        M291 P"Do you want to load more FILAMENT? Press OK to continue loading or CANCEL to abort!" S3 ; requires user input to start the filament loading procedure
                    The messages that ask the user to confirm are properly displayed on the PanelDue. But the M291 "Loading FILAMENT..." S1 T60 messages are only displayed in DWC, not on the PanelDue. I tried both with or without M400 right before the message.
                    Am I doing something wrong?
                    Thank you!
                    EDIT: I should add that I changed from ribbon cable to the included 4-pin wire to connect the PanelDue with the Mini 5+; this also did not seem to change the behavior
                    I also am on the most recent firmwares for the Mini, DWC and the PanelDue
                    • PaulHewundefined
                      PaulHew
                      Since updating to 3.3.0 and the latest DWC, I am experiencing this also.
                      I have a simple macro to shutdown my Pi nicely.
                      If I initiate it from the PanelDue, I have to walk to my computer to confirm or cancel if I want to shutdown my Pi!
                      Meant to mention this the other day when I saw it...
                      Regards,
                      Paul.
                      undefined 1 Reply Last reply 29 Jun 2021, 13:34 Reply Quote 0
                      • mfs12undefined
                        mfs12 @PaulHew
                        @paulhew can you share the macro you are using?
                        PaulHewundefined 1 Reply Last reply 29 Jun 2021, 21:13 Reply Quote 0
                        • PaulHewundefined
                          PaulHew @mfs12
                          @mfs12 As requested
                          M291 R"** SHUTDOWN **" P" Are you sure you want to SHUTDOWN the printer and Pi?" S3
                          M106 P10 S0
                          M7722
                          Also the cancel does not cancel, carries on and shutsdown!
                          P.
                          mfs12undefined 1 Reply Last reply 9 Jul 2021, 07:38 Reply Quote 0
                          • mfs12undefined
                            mfs12 @PaulHew
                            @paulhew thanks for providing your script.
                            I tried to reproduce you issue. Unfortunately I didn't manage to get the error.
                            I checked it with following versions:
                            • RepRapFirmware 3.3
                            • PanelDueFirmware 3.2.11 and 3.3-rc2
                            in "normal" and "sbc" mode. I was also using slight modifed macros.
                            Although what i could experience is that sometimes the messages are delayed on the PanelDue by 1 to 3s compared to the web interface. But they always showed up.
                            Could you test if you problem persists with the current releases:
                            • https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3
                            • https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.3.0-rc2
                            Macros i used:
                            • test-m291-s0.g
                            • test-m291-s1.g
                            • test-m291-s2.g
                            • test-m291-s3.g
                            • test-m291-confirm.g
                            • test-m291-loop.g
                            • test-m291-move-confirm.g
                            floblerundefined 1 Reply Last reply 12 Jul 2021, 10:05 Reply Quote 0
                            • floblerundefined
                              flobler @mfs12
                              @mfs12
                              I also just tried the macros you shared on the recent releases (RRF 3.3 and PanelDue 3.3.0-rc2).
                              Your test macros all worked fine but the macro I shared above is still not displaying all messages on PanelDue, some are only displayed on DWC.
                              This is the macro:
                              ; filament_load.g
                                G28        ; home all
                              else
                              while true
                                  if iterations = 10
                                     break
                              The second M291 message "Loading FILAMENT...." is not being displayed on the PanelDue in both cases. I tried to put a M400 between the messages which also does not seem to help. It is being displayed in DWC correctly though.
                              Additionally when flashing the new PanelDue firmware (I was upgrading from 3.2.11) on my PanelDue 5i, the auto "erase and reset" does not work and I have to physically push the buttons. Is that expected? Should I open another thread on this?
                              • mfs12undefined
                                mfs12
                                hey @flobler, sorry, but i have to tell that the usage of M292 is not allowed. This leads to the described "faulty" behavior.
                                For more details please refer to
                                • https://forum.duet3d.com/post/240796
                                • https://github.com/Duet3D/PanelDueFirmware/issues/146
                                mfs12 created this issue 12 Jul 2021, 13:56 in Duet3D/PanelDueFirmware
                                closed M291 S0 and S1 are not displayed when M292 follows #146
                                floblerundefined 2 Replies Last reply 25 Jul 2021, 10:31 Reply Quote 1
                                • floblerundefined
                                  flobler @mfs12
                                  @mfs12 thanks for the tip but I just removed M292 and the behavior remains the same. Only the first M291 message is being displayed on both DWC and PanelDue. The following message ("Loading FILAMENT...") is only displayed in DWC.
                                  Here is the updated macro:
                                  ; filament_load.g
                                    G28        ; home all
                                  else
                                  while true
                                      if iterations = 10
                                         break
                                  Am I missing something still?
                                  • floblerundefined
                                    flobler
                                    Actually after looking closer at this thread: https://forum.duet3d.com/topic/23189/m291-messages-are-not-always-displayed-in-macros/22
                                    I can say that my machines are behaving similar, if I load filament from DWC, everything is working as expected and both messages are shown on DWC and PanelDie. The second messages on PanelDue are only missing if loading the filament via macro from PanelDue.
                                    • floblerundefined
                                      flobler @mfs12
                                      @mfs12 @wilriker I am still seeing very inconsistent behaviour when using M291, especially with messages not being displayed on the PanelDue. Often for information type messages via S0 or S1, that indicate the printer is currently heating or loading or similar.
                                      I upgraded to PanelDue Firmware 3.3 before I did the following tests (I am on 3.3 for both RRF and DWC on my Duet 3 Mini 5+ in standalone mode):
                                      Note: All macros are initiated from the PanelDue
                                      1. M291 S3, followed by M291 S0
                                      M291 P"BED and EXTRUDER will be heated before the procedure starts! Press OK to start or CANCEL to abort!" S3 R"Z OFFSET CALIBRATION"
                                      M291 P"Heating..." S0 R"Z OFFSET CALIBRATION"
                                      Both messages show on DWC and PanelDue.
                                      2. M291 S3, followed by M291 S1
                                      M291 P"Heating..." S1 R"Z OFFSET CALIBRATION"
                                      Only the second message shows on both PanelDue and DWC, the first message is completely ignored.
                                      3. M291 S3, followed by M291 S2
                                      M291 P"Heating..." S2 R"Z OFFSET CALIBRATION"
                                      4. M291 S3, followed by some additional steps, followed by M291 S0
                                      M291 P"BED and EXTRUDER will be heated before the procedure starts! Press OK to start or CANCEL to abort!" S3 R"Z OFFSET CALIBRATION" ; requires user input to continue
                                      ; preparation
                                      M104 S230        ; set extruder temperature to 230C
                                      M140 S70        ; set bed temperature to 70C
                                      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed                     ; if not all axes are homed
                                        G28        ; home all axes
                                      else        ; if all axes are homed
                                      	G1 Z{sensors.probes[0].diveHeight} F360                                              ; move Z axis to probe dive height
                                      M561        ; clear any bed transform
                                      M290 R0 S0        ; clear babystepping
                                      G1 X{(move.axes[0].min + move.axes[0].max)/2} Y{(move.axes[1].min + move.axes[1].max)/2} ; move X and Y axis to their center
                                      G1 Z5        ; move Z axis 5mm above the bed
                                      M564 S0 H0        ; allow movement beyond axis limits defined in config.g
                                      M291 P"Heating..." S0 R"Z OFFSET CALIBRATION"                                            ; message to confirm heating
                                      G10 P0 S230        ; wait for extruder temperature to reach 230C
                                      M190 S70        ; wait for bed temperature to reach 70C
                                      The first message shows on both PanelDue and DWC, the second message only in DWC.
                                      5. M291 S3, followed by some additional steps, followed by M291 S1
                                      ; preparation
                                        G28        ; home all axes
                                      M291 P"Heating..." S1 R"Z OFFSET CALIBRATION"                                            ; message to confirm heating
                                      6. M291 S3, followed by some additional steps, followed by M291 S2
                                      ; preparation
                                        G28        ; home all axes
                                      M291 P"Heating..." S2 R"Z OFFSET CALIBRATION"                                            ; message to confirm heating
                                      The first message only shows in DWC, the second message shows on PanelDue and DWC.
                                      This makes it really difficult to create self-explanatory macros for our users as we aim for them to be able to navigate the printer completely from the display on the printer. Without consistent messages I am not sure how to do that though.
                                      Am I still missing an aspect of M291?
                                      floblerundefined 1 Reply Last reply 31 Aug 2021, 06:43 Reply Quote 1
                                      • mfs12undefined
                                        mfs12
                                        @flobler thanks for the detailed report. It will help to examine this problem. It is on my agenda for paneldue-3.4. We also want clarify behavior. Although i can give an exact timeline yet.
                                        floblerundefined 1 Reply Last reply 25 Aug 2021, 08:52 Reply Quote 1
                                        • floblerundefined
                                          flobler @mfs12
                                          @mfs12 Thank you! If you need anything from me, please do not hesitate to reach out 🙂
                                          oozeBotundefined 1 Reply Last reply 25 Aug 2021, 15:07 Reply Quote 0
