Mini Duet 5+ - Part fan runs continuously
My Duet controlled machine
1.8k
    PaulHew
    So, just got my Voron V0.1 running tonight. Submitted a serial request.
    It stopped extruding half way through the 5th print.
    Stopped print etc. Noticed that the LDO Extruder was extremely hot, finger burn hot.
    Shut everything off to cool.
    Parts fans are now running continuously, no control.
    20210517_233108.jpg 20210517_233144.jpg 20210517_233208.jpg 20210517_233216.jpg Have I blown something?
    Are these boards 'safe' in regards to something going wrong, it does not affect the whole board?
    Tool fan is ok...
    Thought I would throw some pictures in just in case someone sees something I have not...
    TIA, Paul
    undefined 1 Reply Last reply 17 May 2021, 22:59 Reply Quote 0
      What exactly works now and what doesn't?
      Extruder stopped mid print. Any errors? Was the Duet otherwise functional?
      Does the extruder work now again?
      Now the part cooling fans are always on with no control, but how are you trying to control them?
      Also, please post the standard stuff. M122, config.g.
      What do you have connected to driver 0? Is that a spec of dust on the driver chip or a hole?
        PaulHew @PaulHew
        @paulhew The fans are on the White and Brown wires 4pin connector running 24v
        undefined 1 Reply Last reply 17 May 2021, 23:05 Reply Quote 0
          PaulHew @PaulHew
          @paulhew
          Everything was working, no errors in the log.
          I homed it as I was going to try an extrude.
          Thought I had a block in the hotend, then noticed the motor seemed loose.
          Released the bmg and pushed the filament through.
          Touched the motor and burnt my fingers.
          Apparently I am running too many amps even though it is rated @1amp ??
          As requested
          M122
          m122
          RepRapFirmware for Duet 3 Mini 5+ version 3.3RC2 (2021-05-11 14:55:40) running on Duet 3 Mini5plus Ethernet (standalone mode)
          Board ID: Q595J-A396U-D65J0-40KMD-2403Z-R2K02
          Used output buffers: 3 of 40 (20 max)
          Static ram: 102476
          Dynamic ram: 101052 of which 0 recycled
          Never used RAM 40176, free system stack 194 words
          Tasks: NETWORK(ready,26.0%,243) ETHERNET(notifyWait,0.1%,576) HEAT(delaying,0.0%,338) Move(notifyWait,0.1%,338) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,71.9%,426) IDLE(ready,0.4%,29) AIN(delaying,0.8%,266), total 100.0%
          Owned mutexes:
          Last reset 00:00:33 ago, cause: power up
          Last software reset at 2021-05-17 23:16, reason: User, GCodes spinning, available RAM 36968, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          MCU revision 3, ADC conversions started 33499, completed 33497, timed out 0, errs 0
          Step timer max interval 751
          MCU temperature: min 17.9, current 22.7, max 22.7
          Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 1714, writes 10, timeouts 0, DMA errors 0
          Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 1714, writes 9, timeouts 0, DMA errors 0
          Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 1714, writes 9, timeouts 0, DMA errors 0
          Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 1714, writes 9, timeouts 0, DMA errors 0
          Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 1714, writes 9, timeouts 0, DMA errors 0
          Driver 5: position 0, assumed not present
          Driver 6: position 0, assumed not present
          Date/time: 2021-05-18 00:00:44
          Cache data hit count 58213471
          Slowest loop: 6.77ms; fastest: 0.12ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.2ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = -1 -1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === CAN ===
          Messages queued 297, send timeouts 295, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
          Last cancelled message type 4514 dest 127
          === Network ===
          Slowest loop: 7.41ms; fastest: 0.03ms
          HTTP sessions: 1 of 8
          - Ethernet -
          State: active
          Error counts: 0 0 0 0 0
          Socket states: 2 2 2 2 2 0 0 0
          Config.g
          ; For Voron V0.1 - Duet Mini 5+
          M550 P"Disco V0.1" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 P192.168.0.8 S1 ; enable network and acquire dynamic address via DHCP
          M553 P255.255.255.0
          M554 P192.168.0.1
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0.0 S1 D3 V0 ; physical drive 0.0 goes forwards
          M569 P0.1 S1 D3 V0 ; physical drive 0.1 goes forwards
          M569 P0.2 S0 ; physical drive 0.2 goes forwards
          M584 X0.1 Y0.0 Z0.2 E0.3 ; set drive mapping
          M350 X32 Y32 Z16 E16 I1 ; configure microstepping with interpolation
          M566 X300.00 Y300.00 Z60.00 E400.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z900.00 E3000.00 ; set maximum speeds (mm/min)
          M201 X2500.00 Y2500.00 Z1200.00 E4000.00 ; set accelerations (mm/s^2)
          M906 X425 Y425 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M92 X160.00 Y160.00 Z400.00 ;E420.00 ; set steps per mm
          M92 E730
          M208 X120 Y120 Z120 S0 ; set axis maxima
          M574 X2 S1 P"io4.in" ; configure active-high endstop for high end on X via pin io4.in
          M574 Y2 S1 P"io5.in" ; configure active-high endstop for high end on Y via pin io5.in
          M574 Z1 S1 P"io6.in" ; configure active-high endstop for low end on Z via pin io6.in
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:90 Y15:90 S20 ; define mesh grid
          ; Bed Heater
          M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
          ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
          M307 H0 B0 R1.278 C262.7 D4.55 S0.60 V23.9
          ;M307 H0 B0 R1.266 C265.2 D6.02 S0.50 V23.9
          ; Dragon
          ;M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
          M308 s1 P"temp1" Y"thermistor" A"Dragon" T100000 B4725 C7.060000e-8
          M307 H1 B0 R2.147 C176.0 D4.74 S1.00 V23.9
          ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
          M106 P0 C"Part Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
          M950 F1 C"out5" Q500 ; create fan 1 on pin out4 and set its frequency
          M106 P1 S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
          ;M106 P1 C"Tool Fan" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
          M950 F2 C"out4" Q500 ; create fan 2 on pin out5 and set its frequency
          M106 P2 C"Cooling" S1 H1 T45 ; set fan 2 name and value. Thermostatic control is turned on
          M308 S2 P"temp2" Y"thermistor" A"Chamber[C]" T100000 B4138
          ;Bed Levelling
          M671 X60:5:115 Y5:115:115
          ;M575 P1 S1 B57600 ; enable support for PanelDue
          M575 P1 S2 B57600 ; enable support for BTT
          T0 ; select first tool
          undefined undefined 2 Replies Last reply 17 May 2021, 23:10 Reply Quote 0
            PaulHew @PaulHew
            @paulhew 12v fan for tool is working correctly. ie turns on and off
            undefined 1 Reply Last reply 17 May 2021, 23:24 Reply Quote 0
              Phaedrux Moderator @PaulHew
              @paulhew said in Mini Duet 5+ - Part fan runs continuously:
              Possibly? What is the actual motor? Spec sheet? Maybe do a test with lower amps and see how low you can go.
                So which fan is not working?
                undefined 2 Replies Last reply 17 May 2021, 23:27 Reply Quote 0
                  PaulHew @Phaedrux
                  @phaedrux
                  LDO-36STH17-1004AHG-MM-VRN-RevA.pdf
                  Specs on the motor.
                  Hopefully Tony can fix it, if something on the board is broken.
                    PaulHew @Phaedrux
                    @phaedrux The 2 part cooling fans being fed by 24v are the ones that are permanently on now.
                      Ok, so when you say the tool fan is working, you mean the hotend heatsink fan?
                      Those 2 part cooling fans are wired to the out3 pins in series? Parallel?
                      And just to confirm, the extruder is still extruding ok?
                        PaulHew
                        @phaedrux The hotend heatsink fan is running on a 12V port "Out5", obviously I moved the jumper.
                        The 2 part cooling fans are wired together into the same port, "Out5" both sit on a 24v output. I think you would call it parallel. (Had to google it)
                        Extruder is fine.
                        Speaking to a friend, regardless of what the spec is of that LDO motor, 800ma is too high for it and should be running 400ma~. He runs his at 0.33a in Klipper values.
                        I think something has happened to the board as the fans were working correctly from DWC before I got around to my first prints.
                        undefined 1 Reply Last reply 18 May 2021, 08:47 Reply Quote 0
                          T3P3Tony administrators @PaulHew
                          @paulhew what are the two fans you are running in parallel as print cooling fans?
                          What happens if you connected them to out 4 instead of out 3
                          You need to change this line of your config.g from:
                          to
                          M950 F0 C"out4" Q500
                          to test that. also comment out:
                          ;M950 F2 C"out4" Q500 ; create fan 2 on pin out5 and set its frequency
                          ;M106 P2 C"Cooling" S1 H1 T45
                          As from the pictures and your config you don't appear to be using the cooling fan?
                          undefined 1 Reply Last reply 18 May 2021, 08:50 Reply Quote 0
                            droftarts administrators
                            @paulhew I think the LDO spec sheet is wrong, and it’s a 500mA motor. I have the same motor in an Orbiter extruder, and they say to run it at less than 500mA; I run mine at 450mA. See https://www.thingiverse.com/thing:4223085
                            What specification are the cooling fans? Running fans in parallel means that they draw the current of both fans together (in series the voltage is halved, so they run slower).
                            Can you take a good clear picture of the fan MOSFETs between the fan headers?
                            undefined 1 Reply Last reply 18 May 2021, 08:58 Reply Quote 0
                              PaulHew @T3P3Tony
                              @t3p3tony No, I have not got round to installing the cooling fans, the Mini is open to free air.
                              Will try your suggestions. Thank you.
                                PaulHew @droftarts
                                @droftarts Damn! That info was on Fermio's website.
                                They are just 2 small GDSTIME 3010 blower fans 0.05a @ 24v
                                I am sorry I do not know what a mosfet is. So took 2 pictures.20210518_095544.jpg 20210518_095559.jpg
                                Thanks Ian and Tony
                                Regards,
                                Paul
                                  PaulHew
                                  Interesting. Did as Tony asked and moved the fans to "Out4"
                                  Have control again!
                                  Do each of the fan outputs have individual mosfets things now?
                                  So it is something relevant to Out3 board side.
                                  Just plugged the fans back in with out changing config and they are running full chat.
                                  P.
                                  undefined 1 Reply Last reply 18 May 2021, 09:18 Reply Quote 0
                                    @paulhew yeah each output has its own mosfet.
                                    What fans are you using?
                                    undefined 1 Reply Last reply 18 May 2021, 09:19 Reply Quote 0
                                      PaulHew @T3P3Tony
                                      @t3p3tony They are just 2 small GDSTIME 3010 blower fans 0.05a @ 24v
                                      undefined 1 Reply Last reply 18 May 2021, 09:22 Reply Quote 0
                                        @paulhew ok yes 0.1A '24V for both together is fine. I see its a 0.5 board and we did have some issues with mosfet soldering on those boards so it could be that (although odd it was working before).
                                        undefined 1 Reply Last reply 18 May 2021, 09:32 Reply Quote 0
                                          PaulHew @T3P3Tony
                                          @t3p3tony I do not mind sending it back and paying for it to be fixed.
                                          Not one for messing people around. I agree it was working, so no dispute there hence why I am offering to pay.
                                          I have heard of mosfet's during my time on the forum, do not know what one looks like.
                                          It did get hot in that little chamber so am going to go through the wiring to make sure all is good. It was hot enough to shrink the heat shrink cable labels near the extruder!
                                          Appreciate the help as usual gents.
                                          Regards,
                                          Paul.
                                          undefined 1 Reply Last reply 18 May 2021, 10:04 Reply Quote 0
                                          6 out of 30
