    Nema 17 intergrated servo motor possible?
    1.4k
    • mrehorstdmdundefined
      mrehorstdmd @rabbit
      @rabbit @IBICO I tried them in my corexy machine driving the mechanism directly- no reduction from pulleys- and got the salmon skin effect. Can you post photos of the prints your machine produces with these motors and 3:1 reduction? When the motors were in my printer they were completely silent.
      I have the software to tweak the driver settings, but there's no information on how to do it anywhere that I can find, so I used them with factory default settings.
      I used a duet expansion board to get the step/driection/enable signals to drive the motors. It works fine, but requires a little tweaking of the signal timing to get them to work right. I have the motors installed in a corexy sand table mechanism now:
      arrakis mechanism
      Here's how I configured the motors with the Duet expansion board:
      M584 X5 Y6  ; remaps the X and Y motor drives to the Duet expansion board
      M569 P5 S1 R1 T4.0:5.0:6.0:11.0  ; sets the timing parameters for the X motor servo drive signals
      M569 P6 S1 R1 T4.0:5.0:6.0:11.0    ; sets the timing parameters for the Y motor servo drive signals
      M92: X500 Y500  ; sets steps/mm for motors using 20 tooth drive pulley and 20,000 steps/rev
      M350 X1 Y1 ; sets Duet to output full steps (microstepping is handled by the servomotor drivers)
      M201 X10000 Y10000 ; set maximum acceleration limits for each axis
      M204 P2000 T2000 ; set print and travel move acceleration
      M566 X20 Y20  ; set maximum jerk speed for each axis
      M203 X240 Y240 ; set maximum speeds for each axis
      The servomotors will take as much current as they need to keep up with the input signal, so if you're going to run them hard, you need beefy power supplies. I run the sand table with acceleration at 10k-20k and speeds up to 2000 mm/sec and use a 150W supply for one motor and a 200W supply for the other, and sometimes the supplies shut down. I would think that a single 200W supply would be able to provide all the juice needed to power two motors in a 3D printer.
      I wrote a couple blog posts on these motors:
      https://drmrehorst.blogspot.com/2020/11/heres-what-happened-when-i-swapped.html
      https://drmrehorst.blogspot.com/2020/04/ihsv-servomotor-information.html
      https://drmrehorst.blogspot.com/2020/04/the-spice-must-flow-gets-servo-motors.html
      • rabbitundefined
        rabbit
        I can post some pics on friday.
        • rabbitundefined
          rabbit
          Here is a picture of a print before the gear reduction:
          And after:
          Printspeed was 100 mm/s @20 000 mm/s² acc
          • rabbitundefined
            rabbit
            Here are some pics from the printer
            and from the final belt reduction gear:
              mrehorstdmd
              @rabbit Looks great! That was 3:1 reduction? Can you post the M569 statements from config.g? Are there any special config tweaks?
              • rabbitundefined
                rabbit
                yes that's the 1:3 reduction with a 60t and a 20t gt2 belt.
                M569 P5 S1 T3.5                                  ; physical drive 4 goes forwards
                M569 P6 S1 T3.5                                  ; physical drive 4 goes forwards
                I set the rigidity of the motors (Parameter P01-03) to 22.
                taylo708undefined 1 Reply Last reply Reply Quote 0
                • taylo708undefined
                  taylo708 @rabbit
                  @rabbit I set the rigidity of the motors (Parameter P01-03) to 22.
                  How do I change this parameter? Do I just buy a cable and download a program? I too am getting a salmon finish to my prints. I have a 2:1 reduction in the Y but not in the X. I would like to try to reduce the effects of this if possible with tuning. If not I may look into other motors or possible mechanical reduction.image0.png
                    mrehorstdmd @taylo708
                    @taylo708 I have been gathering iHSV servo info on a blog page here: https://drmrehorst.blogspot.com/2020/04/ihsv-servomotor-information.html
                    You need a USB to RS-232 adapter like this one to program the driver parameters: https://www.amazon.com/UGREEN-Converter-Adapter-Chipset-Windows/dp/B00QUZY4UG/ref=sr_1_3?dchild=1&keywords=usb%2Brs232%2Badapter%2BPL2303&qid=1592150850&sr=8-3&th=1
                    There are many different ones made- just look for the PL2303 chip and it should work.
                    You'll also need the software for programming the motors - there's a link on my blog page for that.
                    • taylo708undefined
                      taylo708 @mrehorstdmd
                      @mrehorstdmd
                      Your blog is phenomenal! I have been trying to find information on these for about a month. I finally got them working but always wanting better.
                        @taylo708 Thanks! What is the filament you used in that print? It's beautiful!
                        If you find any info I don't have yet, send me a link so I can add it to the blog post.
                        • 3DPMicroundefined
                          3DPMicro
                          I noticed the voltage on those servos is advertised as 24. Is there a maximum or range stated in it accompanying literature?
                          Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
                            mrehorstdmd @3DPMicro
                            @3dpmicro The manual here says 24V for the NEMA-17 size motors. The NEMA-23 motors are good for 36V.
                            jay_s_ukundefined 3DPMicroundefined 2 Replies Last reply Reply Quote 0
                              jay_s_uk @mrehorstdmd
                              I've just ordered a couple of these from china to play with.
                              £60 each at the moment https://www.aliexpress.com/item/1005002331999899.html
                              • 3DPMicroundefined
                                3DPMicro @mrehorstdmd
                                @mrehorstdmd thank you
                                  mrehorstdmd @jay_s_uk
                                  @jay_s_uk I ordered 4 of them. That's the best price I've ever seen on them.
