Nema 17 intergrated servo motor possible?
I can post some pics on friday. -
@rabbit Looks great! That was 3:1 reduction? Can you post the M569 statements from config.g? Are there any special config tweaks?
yes that's the 1:3 reduction with a 60t and a 20t gt2 belt.
M569 P5 S1 T3.5 ; physical drive 4 goes forwards M569 P6 S1 T3.5 ; physical drive 4 goes forwards
I set the rigidity of the motors (Parameter P01-03) to 22.
@rabbit I set the rigidity of the motors (Parameter P01-03) to 22.
How do I change this parameter? Do I just buy a cable and download a program? I too am getting a salmon finish to my prints. I have a 2:1 reduction in the Y but not in the X. I would like to try to reduce the effects of this if possible with tuning. If not I may look into other motors or possible mechanical reduction.
@taylo708 I have been gathering iHSV servo info on a blog page here: https://drmrehorst.blogspot.com/2020/04/ihsv-servomotor-information.html
You need a USB to RS-232 adapter like this one to program the driver parameters: https://www.amazon.com/UGREEN-Converter-Adapter-Chipset-Windows/dp/B00QUZY4UG/ref=sr_1_3?dchild=1&keywords=usb%2Brs232%2Badapter%2BPL2303&qid=1592150850&sr=8-3&th=1
There are many different ones made- just look for the PL2303 chip and it should work.
You'll also need the software for programming the motors - there's a link on my blog page for that.
Your blog is phenomenal! I have been trying to find information on these for about a month. I finally got them working but always wanting better.
@taylo708 Thanks! What is the filament you used in that print? It's beautiful!
If you find any info I don't have yet, send me a link so I can add it to the blog post.
I noticed the voltage on those servos is advertised as 24. Is there a maximum or range stated in it accompanying literature?
I've just ordered a couple of these from china to play with.
£60 each at the moment https://www.aliexpress.com/item/1005002331999899.html -
@mrehorstdmd thank you
@jay_s_uk I ordered 4 of them. That's the best price I've ever seen on them.
