Solved Duet 3 + Tool Board Extruder/Retraction Issue
@Phaedrux said in Duet 3 + Tool Board Extruder/Retraction Issue:
In future can you copy and paste the text of the M122 rather than a screen shot?
Sorry, here we go.
10/17/2020, 10:50:39 AM M122 B121 Diagnostics for board 121: Board TOOL1LC firmware 3.1.0 (2020-05-15b1) Never used RAM 8.4Kb, max stack 684b HEAT 640 CanAsync 1392 CanRecv 1380 TMC 156 AIN 524 MAIN 2284 Last reset 96:28:07 ago, cause: software Driver 0: open-load-A open-load-B, SG min/max 0/16, read errors 0, write errors 0, ifcount 54, reads 47102, writes 0, timeouts 0, DMA errors 0, failedOp 0xff Moves scheduled 3079196, completed 3079194, hiccups 7539 VIN: 24.0V MCU temperature: min 44.0C, current 56.2C, max 65.1C Ticks since heat task active 66, ADC conversions started 347266771, completed 347266770, timed out 0 Last sensors broadcast 00000002 found 1 69 ticks ago Free CAN buffers: 36 NVM user row b1d088a9 fffff8bb 20002a18 b TSENS 001602 GAIN 014ffc OFFS 00273f CAL 1f2a 10/17/2020, 10:50:30 AM M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G Used output buffers: 1 of 40 (22 max) === RTOS === Static ram: 154604 Dynamic ram: 162928 of which 140 recycled Exception stack ram used: 552 Never used ram: 74992 Tasks: NETWORK(ready,1972) HEAT(blocked,1088) CanReceiv(suspended,3388) CanSender(suspended,1392) CanClock(blocked,1436) TMC(blocked,60) MAIN(running,2672) IDLE(ready,76) Owned mutexes: === Platform === Last reset 96:27:46 ago, cause: software Last software reset at 2020-10-13 15:22, reason: User, spinning module LinuxInterface, available RAM 75056 bytes (slot 1) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 43.3, current 44.6, max 45.6 Supply voltage: min 23.7, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 1: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 2: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 3: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 4: ok, reads 59467, writes 0 timeouts 0, SG min/max 0/1023 Driver 5: ok, reads 59468, writes 0 timeouts 0, SG min/max 0/242 Date/time: 2020-10-17 15:50:17 Slowest loop: 20.33ms; fastest: 0.21ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 368, MinFreeDm: 336, MaxWait: 0ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 1176142, completed moves: 1176118, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.2 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 1 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X202.007996 Y218.643997 E6.881300" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.72ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 1170785, longest wait 9ms for type 6024 === Linux interface === State: 0, failed transfers: 0 Last transfer: 20ms ago RX/TX seq numbers: 52239/52241 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 1632/3096-0 === Duet Control Server === Duet Control Server v3.1.1 File: Buffered code: G1 X202.008 Y218.644 E6.8813 Buffered code: G1 X200.366 Y221.101 E6.9796 Buffered code: G1 X198.832 Y223.628 E7.0779 Buffered code: G1 X197.411 Y226.220 E7.1762 Buffered code: G1 X196.104 Y228.870 E7.2746 Buffered code: G1 X194.913 Y231.576 E7.3729 Buffered code: G1 X193.842 Y234.330 E7.4712 Buffered code: G1 X192.892 Y237.129 E7.5695 Buffered code: G1 X192.065 Y239.967 E7.6678 Buffered code: G1 X191.483 Y242.343 E7.7491 Buffered code: G1 X191.362 Y242.838 E7.7661 Buffered code: G1 X190.786 Y245.736 E7.8644 Buffered code: G1 X190.336 Y248.658 E7.9627 Buffered code: G1 X190.014 Y251.596 E8.0610 Buffered code: G1 X189.821 Y254.545 E8.1593 Buffered code: G1 X189.756 Y257.500 E8.2576 Buffered code: G1 X189.821 Y260.455 E8.3559 Buffered code: G1 X190.014 Y263.404 E8.4542 Buffered code: G1 X190.281 Y265.836 E8.5356 Buffered code: G1 X190.336 Y266.342 E8.5525 Buffered code: G1 X190.786 Y269.264 E8.6508 Buffered code: G1 X191.362 Y272.162 E8.7491 Buffered code: G1 X192.065 Y275.033 E8.8474 Buffered code: G1 X192.892 Y277.871 E8.9457 Buffered code: G1 X193.842 Y280.670 E9.0440 Buffered code: G1 X194.913 Y283.424 E9.1423 Buffered code: G1 X196.104 Y286.130 E9.2407 Buffered code: G1 X197.411 Y288.781 E9.3390 Buffered code: G1 X198.832 Y291.372 E9.4373 Buffered code: G1 X200.101 Y293.463 E9.5186 Buffered code: G1 X200.366 Y293.899 E9.5356 Buffered code: G1 X202.008 Y296.356 E9.6339 ==> 1524 bytes Code buffer space: 1588 Configured SPI speed: 8000000 Hz Full transfers per second: 32.49 File /opt/dsf/sd/gcodes/Pineapple_Bottom120_percent.gcode is selected, processing
@evomotors said in Duet 3 + Tool Board Extruder/Retraction Issue:
hiccups 7539
So you are getting a lot of hiccups on the tool board, so perhaps try the new beta?
is 7mm/s correct for your retraction speed?
hiccups 7539
Retraction speed is 7 mm/s, any value higher that that was performing extremely worst when stepper connected to the tool board.
I didn't install beta yet. I'm willing to do so, but a little confused in the instructions for installing unstable version using SBC and DWC.
What about bunch of blocked and suspended CAN bus commands on the Duet3 board itself?:
CanReceiv(suspended,3388) CanSender(suspended,1392) CanClock(blocked,1436) -
CanReceiv(suspended,3388) CanSender(suspended,1392) CanClock(blocked,1436)Those do not refer to messages. The clue is the "Tasks:" label at the start of the line.
@dc42 said in Duet 3 + Tool Board Extruder/Retraction Issue:
Can you please point me to how to update to latest beta? What files do I need to download update DWC (looks like it's required for new beta) what bin files do I need to update Duet3 and tool board?
I'm looking at this guide right now:
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_from_RRF3_0_Beta_12_to_3_0_Final_via_DWC -
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_from_RRF3_0_Beta_12_to_3_0_Final_via_DWCThis is for a specific case for updating to 3.0 final from 3.0 beta 12.
To update to the 3.2 beta2 using a SBC you can add the unstable repository on the pi and then use sudo apt update sudo apt upgrade as usual.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
@evomotors
Do you still face the same issue in extrusion ?
I'm planning to drive extruder from other board too. -
@user3d I believe all tool board extrusion issues are solved in recent firmware, though the firmware version must match between mainboard and toolboard.
@phaedrux said in Duet 3 + Tool Board Extruder/Retraction Issue:
Not toolboard. I'm planning so with EXP1XD
@phaedrux is it recommended? -
@user3d I am not aware of any issues using a EXP1XD to drive an extruder. The EXP1XD and the TOOL1LC use common source code, so the issues we fixed for the tool board are also fixed for the EXP1XD.
@dc42 ok. Thank you
