    Unable to configure bed heater
    2.1k
    • Weevilundefined
      Weevil @Phaedrux
      @phaedrux config:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 16:55:51 GMT-0800 (Pacific Standard Time)
      G90
      M83
      M550 P"MYTH3D"
      M667 S1
      M575 P1 B57600 S1
      ; Networking
      M552 P192.168.1.19 S1
      M553 P255.255.255.0
      M554 192.168.1.1
      M586 P1 S1
      M586 P2 S1
      M552 S1
      M569 P0.0 S1
      M569 P0.1 S0
      M569 P0.2 S1
      M569 P0.5 S1
      M569 P0.3 S1
      M569 P0.4 S1
      M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5
      M350 X16 Y16 Z16 E16 I1
      M92 X80.00 Y80.00 Z400.00 E400.00
      M566 X900.00 Y900.00 Z12.00 E120.00
      M203 X6000.00 Y6000.00 Z180.00 E1200.00
      M201 X500.00 Y500.00 Z20.00 E250.00
      M906 X800 Y800 Z800 E800
      M84 S30
      M671 X-15:150:310 Y50:310:150 1S0.5
      M208 X0 Y0 Z0 S1
      M208 X300 Y300 Z500 S0
      M574 X2 S1 P"io5.in"
      M574 Y1 S1 P"io2.in"
      M950 S0 C"io7.out"
      M558 P9 C"io7.in" H5 F120 T6000
      G31 P25 X-38 Y0 Z1.05
      M557 X15:227 Y5:210 S50
      M308 S0 P"temp1" Y"thermistor" T100000 B4138
      M950 H0 C"out2" T0
      M307 H0 B1 S1.00
      M140 H0
      M143 H0 S100
      M308 S0 P"temp0" Y"thermistor" T100000 B4138
      M950 H1 C"out1" T0
      M143 H1 S280
      M950 F1 C"out7" Q500
      M106 P1 S1 H T45
      M950 F0 C"out8" Q500
      M106 P0 S255
      M501
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
      M563 P0 S"MYTHprint" D0 H1 F0
      M563 P0 D0 H1 F0
      G10 P0 X0 Y0 Z0
      G10 P0 R0 S0
      T0
      Config override
      ; config-override.g file generated in response to M500 at 2021-05-23 11:36
      ; Heater model parameters
      M307 H0 R0.299 C620.600:620.600 D1.28 S1.00 V22.7 B0 I0
      M307 H1 R1.970 C184.600:184.600 D5.04 S1.00 V23.9 B0 I0
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
        I would suggest deleting the config-override.g file and then re-run the heater tuning with M303 and when it completes use M500 again to save it, which should create a fresh config-override.g file.
        Weevilundefined 3 Replies Last reply Reply Quote 0
        • Weevilundefined
          Weevil @Phaedrux
          @phaedrux I'll give it a shot.
          • Weevilundefined
            Weevil @Phaedrux
            @phaedrux That did not work. I got the following message:
            Warning: heater behaviour was not consistent during tuning
            Auto tuning heater 0 completed after 4 idle and 25 tuning cycles in 3679 seconds. This heater needs the following M307 command:
            M307 H0 B0 R0.317 C276.8 D1.57 S1.00 V22.7
            Send M500 to save this command in config-override.g
            As with all tests, the beep alarm would go off each time the bed heats up. I went ahead and saved the code with M500 but the issue remains. I would be happy if I could just disable the alert. It appears to function fine.
            • Weevilundefined
              Weevil @Phaedrux
              @phaedrux I think the issue is the board is treating the bed heater like a nozzle heater. It is running tests with the fan on and fan off.
              These codes:
              They look identical. Perhaps there is a code for bed heaters.
                Phaedrux Moderator @Weevil
                @weevil said in Unable to configure bed heater:
                What M303 command are you using to tune the bed?
                M303 T# will tune the heater as a tool with the fan
                M303 H# will tune the heater as a heater without the fan
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning
                Weevilundefined 2 Replies Last reply Reply Quote 0
                • Weevilundefined
                  Weevil @Phaedrux
                  @phaedrux I thought I was using H. I'll double-check when I get home. But the M308 command, shouldn't the T100000 B4138 be different for bed?
                  engikeneerundefined 1 Reply Last reply Reply Quote 0
                  • engikeneerundefined
                    engikeneer @Weevil
                    @weevil depends what thermistor you have. B4138 is the default the config tool uses so is almost certainly not right for your setup. You probably should find out the correct values for your thermistor (for both hotend and bed).
                    Having said that, it should only affect how accurate the measured temperature is (and probably won't make much difference at lower temperatures used by the bed).
                    i3 clone with a bunch of mods
                    Weevilundefined 1 Reply Last reply Reply Quote 1
                    • Weevilundefined
                      Weevil @engikeneer
                      @engikeneer The thermistor for my Keenovo pad is an NTC100K if that helps.
                      Also note, the heated bed size is 300x300.
                        Chances are the B value should be B3950 in that case.
                        • Weevilundefined
                          Weevil @Phaedrux
                          @phaedrux Thanks, I'll try that (fingers crossed).
                          • Weevilundefined
                            Weevil @Phaedrux
                            @phaedrux M303 T# produces this error:
                            M303 H# tests with the fan
                            M303 T1 S60
                            Error: M303: tool 1 not found
                            theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                            • theruttmeisterundefined
                              theruttmeister @Weevil
                              M303 T1 S60
                              Not surprising...
                              M563 P0 D0 H1 F0
                              You have configured Tool 0. There is no Tool 1.
                              Although I'm not sure why you are getting the fan running when the heater is.
                              Also you have a random H without a value:
                              M106 P1 S1 H T45
                              Doubt it's causing the problem, but can't hurt to fix.
                              Isolate, substitute, verify.
                                M106 P0 S255
                                This may need to be M106 P0 S1 H-1 to work correctly as a part cooling fan. That might have something to do with it.
                                • Weevilundefined
                                  Weevil @theruttmeister
                                  @theruttmeister My bad, for some reason I was thinking T as temp probe, not tool. Using the code M303 T0 S60 goes to the nozzle. I need this to test the bed heater. I'm not sure what code I am missing.
                                    For the tool you use M303 T0 S### (or M303 H1 S###) and for the bed heater you use M303 H0 S##.
                                    The tool tuning is intended to allow the algorithm to use the part cooling fan during the tuning process so that it can compensate for any fan cooling effect. It's not supposed to do that when tuning the bed though, so that may be a bug. Or maybe it's taking into account the fan effect for the bed heater now as well.
                                    • Weevilundefined
                                      Weevil @Phaedrux
                                      @phaedrux Yeah, it's still running tests with the fan. I'll see if the error goes away after the test.
                                      • Weevilundefined
                                        Weevil @Phaedrux
                                        @phaedrux Calibration finished with the same error code:
                                        Auto tuning heater 0 completed after 3 idle and 25 tuning cycles in 3658 seconds. This heater needs the following M307 command:
                                        M307 H0 B0 R0.377 C62.4 D1.54 S1.00 V22.7
                                        It still errors out about the heater taking too long.
                                          dc42 administrators @Weevil
                                          1. Send M307 H0 to check that it is using the values resulting from tuning.
                                          2. What is the expected heating that it reports in the error message?
                                          Weevilundefined 1 Reply Last reply Reply Quote 0
                                          • Weevilundefined
                                            Weevil @dc42
                                            Out of an act of desperation, I ran the calibration again.
                                            M307 H0 returns this:
                                            Heater 0 model: heating rate 0.377, cooling time constant 62.4, dead time 1.54, max PWM 1.00, calibration voltage 22.7, mode PID
                                            Computed PID parameters: setpoint change: P307.5, I31.363, D331.4, load change: P307.5, I69.412, D331.4
                                            I must be crazy. This is the 5th time I ran M303 H0. This time, it worked. I just wish I could silence the long beep or at least lower the volume during the initial warm-up. It's probably a necessary safety feature.
                                            Should I be concerned with the warning: Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 209C?
