    Unable to configure bed heater
    2.1k
    • o_lampeundefined
      o_lampe @Weevil
      @weevil
      You have to read config-override by sending M501 at the end of config.g or in the Web interface.
      Weevilundefined 1 Reply Last reply Reply Quote 0
      • Weevilundefined
        Weevil @o_lampe
        @o_lampe I always had this just above the tools lines, near the bottom:
        M501
        M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
        engikeneerundefined 1 Reply Last reply Reply Quote 0
        • engikeneerundefined
          engikeneer @Weevil
          @weevil post your full config and config override using the </> code tags.
          Looks like it's not reading the tuned parameters (1.7deg/s is the default for a heater)
          i3 clone with a bunch of mods
          • Weevilundefined
            Weevil @engikeneer
            @engikeneer You just gave me an idea. I'll try editing the M307 code.
            • Weevilundefined
              Weevil @Weevil
              @engikeneer EDiting the code directly didn't work either. It's still complaining.
                • Weevilundefined
                  Weevil @Phaedrux
                  @phaedrux config:
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 16:55:51 GMT-0800 (Pacific Standard Time)
                  G90
                  M83
                  M550 P"MYTH3D"
                  M667 S1
                  M575 P1 B57600 S1
                  ; Networking
                  M552 P192.168.1.19 S1
                  M553 P255.255.255.0
                  M554 192.168.1.1
                  M586 P1 S1
                  M586 P2 S1
                  M552 S1
                  M569 P0.0 S1
                  M569 P0.1 S0
                  M569 P0.2 S1
                  M569 P0.5 S1
                  M569 P0.3 S1
                  M569 P0.4 S1
                  M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5
                  M350 X16 Y16 Z16 E16 I1
                  M92 X80.00 Y80.00 Z400.00 E400.00
                  M566 X900.00 Y900.00 Z12.00 E120.00
                  M203 X6000.00 Y6000.00 Z180.00 E1200.00
                  M201 X500.00 Y500.00 Z20.00 E250.00
                  M906 X800 Y800 Z800 E800
                  M84 S30
                  M671 X-15:150:310 Y50:310:150 1S0.5
                  M208 X0 Y0 Z0 S1
                  M208 X300 Y300 Z500 S0
                  M574 X2 S1 P"io5.in"
                  M574 Y1 S1 P"io2.in"
                  M950 S0 C"io7.out"
                  M558 P9 C"io7.in" H5 F120 T6000
                  G31 P25 X-38 Y0 Z1.05
                  M557 X15:227 Y5:210 S50
                  M308 S0 P"temp1" Y"thermistor" T100000 B4138
                  M950 H0 C"out2" T0
                  M307 H0 B1 S1.00
                  M140 H0
                  M143 H0 S100
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138
                  M950 H1 C"out1" T0
                  M143 H1 S280
                  M950 F1 C"out7" Q500
                  M106 P1 S1 H T45
                  M950 F0 C"out8" Q500
                  M106 P0 S255
                  M501
                  M563 P0 S"MYTHprint" D0 H1 F0
                  M563 P0 D0 H1 F0
                  G10 P0 X0 Y0 Z0
                  G10 P0 R0 S0
                  T0
                  Config override
                  ; config-override.g file generated in response to M500 at 2021-05-23 11:36
                  ; Heater model parameters
                  M307 H0 R0.299 C620.600:620.600 D1.28 S1.00 V22.7 B0 I0
                  M307 H1 R1.970 C184.600:184.600 D5.04 S1.00 V23.9 B0 I0
                  ; Workplace coordinates
                  G10 L2 P1 X0.00 Y0.00 Z0.00
                  G10 L2 P2 X0.00 Y0.00 Z0.00
                  G10 L2 P3 X0.00 Y0.00 Z0.00
                  G10 L2 P4 X0.00 Y0.00 Z0.00
                  G10 L2 P5 X0.00 Y0.00 Z0.00
                  G10 L2 P6 X0.00 Y0.00 Z0.00
                  G10 L2 P7 X0.00 Y0.00 Z0.00
                  G10 L2 P8 X0.00 Y0.00 Z0.00
                  G10 L2 P9 X0.00 Y0.00 Z0.00
                    I would suggest deleting the config-override.g file and then re-run the heater tuning with M303 and when it completes use M500 again to save it, which should create a fresh config-override.g file.
                    Weevilundefined 3 Replies Last reply Reply Quote 0
                    • Weevilundefined
                      Weevil @Phaedrux
                      @phaedrux I'll give it a shot.
                      • Weevilundefined
                        Weevil @Phaedrux
                        @phaedrux That did not work. I got the following message:
                        Warning: heater behaviour was not consistent during tuning
                        Auto tuning heater 0 completed after 4 idle and 25 tuning cycles in 3679 seconds. This heater needs the following M307 command:
                        M307 H0 B0 R0.317 C276.8 D1.57 S1.00 V22.7
                        Send M500 to save this command in config-override.g
                        As with all tests, the beep alarm would go off each time the bed heats up. I went ahead and saved the code with M500 but the issue remains. I would be happy if I could just disable the alert. It appears to function fine.
                        • Weevilundefined
                          Weevil @Phaedrux
                          @phaedrux I think the issue is the board is treating the bed heater like a nozzle heater. It is running tests with the fan on and fan off.
                          These codes:
                          They look identical. Perhaps there is a code for bed heaters.
                            Phaedrux Moderator @Weevil
                            @weevil said in Unable to configure bed heater:
                            What M303 command are you using to tune the bed?
                            M303 T# will tune the heater as a tool with the fan
                            M303 H# will tune the heater as a heater without the fan
                            https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning
                            Weevilundefined 2 Replies Last reply Reply Quote 0
                            • Weevilundefined
                              Weevil @Phaedrux
                              @phaedrux I thought I was using H. I'll double-check when I get home. But the M308 command, shouldn't the T100000 B4138 be different for bed?
                                engikeneer @Weevil
                                @weevil depends what thermistor you have. B4138 is the default the config tool uses so is almost certainly not right for your setup. You probably should find out the correct values for your thermistor (for both hotend and bed).
                                Having said that, it should only affect how accurate the measured temperature is (and probably won't make much difference at lower temperatures used by the bed).
                                Weevilundefined 1 Reply Last reply Reply Quote 1
                                • Weevilundefined
                                  Weevil @engikeneer
                                  @engikeneer The thermistor for my Keenovo pad is an NTC100K if that helps.
                                  Also note, the heated bed size is 300x300.
                                    Chances are the B value should be B3950 in that case.
                                    • Weevilundefined
                                      Weevil @Phaedrux
                                      @phaedrux Thanks, I'll try that (fingers crossed).
                                      • Weevilundefined
                                        Weevil @Phaedrux
                                        @phaedrux M303 T# produces this error:
                                        M303 H# tests with the fan
                                        M303 T1 S60
                                        Error: M303: tool 1 not found
                                        theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                                        • theruttmeisterundefined
                                          theruttmeister @Weevil
                                          M303 T1 S60
                                          Not surprising...
                                          M563 P0 D0 H1 F0
                                          You have configured Tool 0. There is no Tool 1.
                                          Although I'm not sure why you are getting the fan running when the heater is.
                                          Also you have a random H without a value:
                                          M106 P1 S1 H T45
                                          Doubt it's causing the problem, but can't hurt to fix.
                                          Isolate, substitute, verify.
                                            M106 P0 S255
                                            This may need to be M106 P0 S1 H-1 to work correctly as a part cooling fan. That might have something to do with it.
