    Unable to configure bed heater
    2.0k
    • Weevilundefined
      Weevil
      My Duet is complaining about my bed heater taking too long to heat up. Note, in the past I had a separately powered heating pad. When it died, I decided to have a board control one.
      I am using the original Duet 3 board (6HC) - firmware ver MB6HC 3.3RC2 (2021-05-11)
      The power supply is 24V 500 watts
      The bed heater is 24V 400 watts
      This is my code (H0 is the bed heater):
      M308 S0 P"temp1" Y"thermistor" T100000 B4138
      M950 H0 C"out2" T0
      M307 H0 B1 S1.00
      M140 H0
      M143 H0 S120
      M308 S1 P"temp0" Y"thermistor" T100000 B4138
      M950 H1 C"out1" T1
      M307 H1 B0 S1.00
      M143 H1 S280
      I ran the heater configuration and followed the steps:
      Auto tuning heater 0 completed after 5 idle and 9 tuning cycles in 1403 seconds. This heater needs the following M307 command:
      M307 H0 B0 R0.300 C615.0 D1.30 S1.00 V22.7
      I do that and get this message:
      Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 209C
      I save with M500 anyway.
      I even rebooted afterwards but still get this when I instruct via web control to heat the bed to 60 😄
      "Error: Heating fault on heater 0, temperature rising much more slowly than the expected 1.7°C/sec"
      • o_lampeundefined
        o_lampe @Weevil
        @weevil
        You have to read config-override by sending M501 at the end of config.g or in the Web interface.
        Weevilundefined 1 Reply Last reply Reply Quote 0
        • Weevilundefined
          Weevil @o_lampe
          @o_lampe I always had this just above the tools lines, near the bottom:
          M501
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
          engikeneerundefined 1 Reply Last reply Reply Quote 0
          • engikeneerundefined
            engikeneer @Weevil
            @weevil post your full config and config override using the </> code tags.
            Looks like it's not reading the tuned parameters (1.7deg/s is the default for a heater)
            i3 clone with a bunch of mods
            • Weevilundefined
              Weevil @engikeneer
              @engikeneer You just gave me an idea. I'll try editing the M307 code.
              • Weevilundefined
                Weevil @Weevil
                @engikeneer EDiting the code directly didn't work either. It's still complaining.
                  • Weevilundefined
                    Weevil @Phaedrux
                    @phaedrux config:
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 16:55:51 GMT-0800 (Pacific Standard Time)
                    G90
                    M83
                    M550 P"MYTH3D"
                    M667 S1
                    M575 P1 B57600 S1
                    ; Networking
                    M552 P192.168.1.19 S1
                    M553 P255.255.255.0
                    M554 192.168.1.1
                    M586 P1 S1
                    M586 P2 S1
                    M552 S1
                    M569 P0.0 S1
                    M569 P0.1 S0
                    M569 P0.2 S1
                    M569 P0.5 S1
                    M569 P0.3 S1
                    M569 P0.4 S1
                    M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5
                    M350 X16 Y16 Z16 E16 I1
                    M92 X80.00 Y80.00 Z400.00 E400.00
                    M566 X900.00 Y900.00 Z12.00 E120.00
                    M203 X6000.00 Y6000.00 Z180.00 E1200.00
                    M201 X500.00 Y500.00 Z20.00 E250.00
                    M906 X800 Y800 Z800 E800
                    M84 S30
                    M671 X-15:150:310 Y50:310:150 1S0.5
                    M208 X0 Y0 Z0 S1
                    M208 X300 Y300 Z500 S0
                    M574 X2 S1 P"io5.in"
                    M574 Y1 S1 P"io2.in"
                    M950 S0 C"io7.out"
                    M558 P9 C"io7.in" H5 F120 T6000
                    G31 P25 X-38 Y0 Z1.05
                    M557 X15:227 Y5:210 S50
                    M950 H0 C"out2" T0
                    M307 H0 B1 S1.00
                    M140 H0
                    M143 H0 S100
                    M308 S0 P"temp0" Y"thermistor" T100000 B4138
                    M950 H1 C"out1" T0
                    M143 H1 S280
                    M950 F1 C"out7" Q500
                    M106 P1 S1 H T45
                    M950 F0 C"out8" Q500
                    M106 P0 S255
                    M501
                    M563 P0 S"MYTHprint" D0 H1 F0
                    M563 P0 D0 H1 F0
                    G10 P0 X0 Y0 Z0
                    G10 P0 R0 S0
                    T0
                    Config override
                    ; config-override.g file generated in response to M500 at 2021-05-23 11:36
                    ; Heater model parameters
                    M307 H0 R0.299 C620.600:620.600 D1.28 S1.00 V22.7 B0 I0
                    M307 H1 R1.970 C184.600:184.600 D5.04 S1.00 V23.9 B0 I0
                    ; Workplace coordinates
                    G10 L2 P1 X0.00 Y0.00 Z0.00
                    G10 L2 P2 X0.00 Y0.00 Z0.00
                    G10 L2 P3 X0.00 Y0.00 Z0.00
                    G10 L2 P4 X0.00 Y0.00 Z0.00
                    G10 L2 P5 X0.00 Y0.00 Z0.00
                    G10 L2 P6 X0.00 Y0.00 Z0.00
                    G10 L2 P7 X0.00 Y0.00 Z0.00
                    G10 L2 P8 X0.00 Y0.00 Z0.00
                    G10 L2 P9 X0.00 Y0.00 Z0.00
                      I would suggest deleting the config-override.g file and then re-run the heater tuning with M303 and when it completes use M500 again to save it, which should create a fresh config-override.g file.
                      Weevilundefined 3 Replies Last reply Reply Quote 0
                      • Weevilundefined
                        Weevil @Phaedrux
                        @phaedrux I'll give it a shot.
                        • Weevilundefined
                          Weevil @Phaedrux
                          @phaedrux That did not work. I got the following message:
                          Warning: heater behaviour was not consistent during tuning
                          Auto tuning heater 0 completed after 4 idle and 25 tuning cycles in 3679 seconds. This heater needs the following M307 command:
                          M307 H0 B0 R0.317 C276.8 D1.57 S1.00 V22.7
                          Send M500 to save this command in config-override.g
                          As with all tests, the beep alarm would go off each time the bed heats up. I went ahead and saved the code with M500 but the issue remains. I would be happy if I could just disable the alert. It appears to function fine.
                          • Weevilundefined
                            Weevil @Phaedrux
                            @phaedrux I think the issue is the board is treating the bed heater like a nozzle heater. It is running tests with the fan on and fan off.
                            These codes:
                            They look identical. Perhaps there is a code for bed heaters.
                              Phaedrux Moderator @Weevil
                              @weevil said in Unable to configure bed heater:
                              What M303 command are you using to tune the bed?
                              M303 T# will tune the heater as a tool with the fan
                              M303 H# will tune the heater as a heater without the fan
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning
                              Weevilundefined 2 Replies Last reply Reply Quote 0
                              • Weevilundefined
                                Weevil @Phaedrux
                                @phaedrux I thought I was using H. I'll double-check when I get home. But the M308 command, shouldn't the T100000 B4138 be different for bed?
                                  engikeneer @Weevil
                                  @weevil depends what thermistor you have. B4138 is the default the config tool uses so is almost certainly not right for your setup. You probably should find out the correct values for your thermistor (for both hotend and bed).
                                  Having said that, it should only affect how accurate the measured temperature is (and probably won't make much difference at lower temperatures used by the bed).
                                  Weevilundefined 1 Reply Last reply Reply Quote 1
                                  • Weevilundefined
                                    Weevil @engikeneer
                                    @engikeneer The thermistor for my Keenovo pad is an NTC100K if that helps.
                                    Also note, the heated bed size is 300x300.
                                      Chances are the B value should be B3950 in that case.
                                      • Weevilundefined
                                        Weevil @Phaedrux
                                        @phaedrux Thanks, I'll try that (fingers crossed).
                                        • Weevilundefined
                                          Weevil @Phaedrux
                                          @phaedrux M303 T# produces this error:
                                          M303 H# tests with the fan
                                          M303 T1 S60
                                          Error: M303: tool 1 not found
                                          theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                                          • theruttmeisterundefined
                                            theruttmeister @Weevil
                                            M303 T1 S60
                                            Not surprising...
                                            M563 P0 D0 H1 F0
                                            You have configured Tool 0. There is no Tool 1.
                                            Although I'm not sure why you are getting the fan running when the heater is.
                                            Also you have a random H without a value:
                                            M106 P1 S1 H T45
                                            Doubt it's causing the problem, but can't hurt to fix.
                                            Isolate, substitute, verify.
