    Requirements to have a 1000x1000 aluminium build plate
    48
    4.2k
    • vistalertundefined
      vistalert @sinned6915
      @sinned6915 I'm not sure I actually stated any expectations, nor questioned anyone's credentials. I'm here to seek a simple answer. The simple answer to the question just needs to be "a plate of x and y size, needs to be z thick". Based
      on many other factors then I can make a decision, with one more blank filled in.
      I've seen terrible warped beds work "ok" (I used to have one). So I know not to "need" perfection. I'm pragmatic.
      Many times I've got through life with "good enough" solutions, by listening, learning and then acting, learning some more when I stuff up, and iterating. That's all I'm doing here. I'm not sure how the impression was gained that I'd be acquiring iron or granite plates. I just find this diverse thinking interesting and educational.
      sinned6915undefined theruttmeisterundefined 2 Replies Last reply Reply Quote 1
      • sinned6915undefined
        sinned6915 @vistalert
        @vistalert you are missing the point. everyone is telling you its not a good idea and why.
        i'm telling you that even with the 'credentials' and tools, I would not attempt it.
        'resonable deflection' means what exactly? 0.1mm? 0.05mm? you want to 'know' how much- look up plate deflection equations, there are plenty online, and calc it. 3 point will be worse than 4 point, so stick with 4 point.
        i would not be surprised that to hold 0.1mm or less on 1m, you will end up with a Mic6 plate at least an inch in thickness. that will be on the order of 200-250 pounds.
        cast iron surface plates are a corrolary as to how the world makes things so that they stay FLAT, flat as in refernce surfaces to know ant trust as flat.
        o_lampeundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
        • o_lampeundefined
          o_lampe @sinned6915
          @sinned6915 said in Requirements to have a 1000x1000 aluminium build plate:
          'Everyone'?
          Please, I can speak for myself...
          A few people mentioned how to build a subframe; how to support and adjust a reasonable thick MIC6 plate.
          It's not done in an evening, but doable.
          • o_lampeundefined
            o_lampe @deckingman
            @deckingman said in Requirements to have a 1000x1000 aluminium build plate:
            I went to a graveyard and there were a bunch of guys walking round and round with a coffin.
            That must've been a 'Thriller' ? 😉
              deckingman @sinned6915
              i'm telling you that even with the 'credentials' and tools, I would not attempt it...............
              Err, the density of aluminium is around 2.7 gms/cm^3. A plate 1metre square would be 10,000 cm^2 (100 x 100). 1 inch is roughly 2.5cm so 10,000 x 2.5 = 25,000 cm^3 x 2.7 = 67500 gms = 67.5Kgs = about 148lbs. So your weight calculation of 200 - 250 lbs is out by a significant amount. But with a support frame that some of us have mentioned, the thickness could be halved bring the weight down to about 34 Kgs or around 76 lbs. I'd say it's doable without too much trouble (costly at around £600 for 12mm thick cast aluminium tooling plate but doable).
              • theruttmeisterundefined
                theruttmeister @vistalert
                @vistalert said in Requirements to have a 1000x1000 aluminium build plate:
                If I was trying to keep cost down I'd go with 1/4" plate (assuming you can get it big enough). Support it at ~300mm on center.
                Then make sure the mountings both let you adjust for bow in the plate and its supporting frame, and allow the plate to expand.
                Then spend the money on making sure the gantry is flat and stiff, because then you can tram the bed to it. Making a gantry that long flat is much less work.
                There is no 'right' thickness of plate. With the right design it could be 2mm thick. Or you could go with 25mm. I'm suggesting 1/4" just because its reasonably able to hold its shape, so you are less likely to ruin its flatness during handling, and doesn't need 400 supports.
                Isolate, substitute, verify.
                o_lampeundefined 1 Reply Last reply Reply Quote 1
                • o_lampeundefined
                  o_lampe @theruttmeister
                  @theruttmeister said in Requirements to have a 1000x1000 aluminium build plate:
                  With a 1x1m bed you have to consider, people have to step on the bed to remove the print and prepare for the next one. A 2mm plate would bend locally, from the forces it takes to remove the print and the weight of the person.
                    At 1sq meter maybe plywood and a coating of self-leveling cement? Embed a floor heating coil in the cement?
                    vistalertundefined o_lampeundefined 2 Replies Last reply Reply Quote 1
                    • jens55undefined
                      jens55 @o_lampe
                      @o_lampe .... long handled spatula and if you are patient enough to let the bed cool all the way you can work with a walking cane and just slide the print off.
                        vistalert @Phaedrux
                        @phaedrux - see, that's what I'm talking about! Innovation, dare to explore and try. If we gave up easily, there never would have been reprap in the first place 😉
                        BTW @Phaedrux - have you patented this, coz I might try :0)
                        • o_lampeundefined
                          o_lampe @Phaedrux
                          @phaedrux said in Requirements to have a 1000x1000 aluminium build plate:
                          I like the idea! How flat would that cement be?
                          Phaedruxundefined theruttmeisterundefined 2 Replies Last reply Reply Quote 0
                            Phaedrux Moderator @o_lampe
                            @o_lampe said in Requirements to have a 1000x1000 aluminium build plate:
                            Flat enough for a sensor to handle I think, but not sub-mm flat. Might be able to smooth it by hand, or even press something flat onto it to help a bit? Not sure.
                              theruttmeister @o_lampe
                              So long as you use the right 'cement', good enough for NASA.
                              Seriously, self-leveling compounds are used to make large reference surfaces and can be flat to unreasonable numbers of decimal places.
                              There's a ton of information out there. Look at polymer concrete and epoxy granite. Both are cheap and if done for a self-leveling finish, can be very very flat.
                              Just needs to be the right material and finished in the right way (materials that shrink are not going to produce a level surface).
