    CoreXY or Cartesian which is better ?
    53
    6.2k
    • oliofundefined
      oliof @o_lampe
      @o_lampe no, I mean getting the frame square, especially when using aluminum extrusions. Belt tension is another issue, looking forward to see your fix (-:
      • fcwiltundefined
        fcwilt @Hiroaki
        @hiroaki said in CoreXY or Cartesian which is better ?:
        @fcwilt What is the lead of screws of yours?
        I don't understand the question. The one printer I mentioned, in response to your post about having all screw drive, has all belt drives.
        • fcwiltundefined
          fcwilt @oliof
          @oliof said in CoreXY or Cartesian which is better ?:
          What do you think about the E3D motion system in that regards?
          • fcwiltundefined
            fcwilt @oliof
            @phaedrux CoreXY may be easier to build, but it's ultimately (pun intended) harder to square. An ultimaker style sheet-based box printer is more or less self-squaring ...
            Can you provide a link to a design like that?
            • mrehorstdmdundefined
              mrehorstdmd
              You don't "tune" belt tension in a corexy printer. The exact and even the relative tensions of the belts isn't important (of course, you don't want them flopping around and you don't want them so tight that they destroy the motor bearings). All that matters is that the x and y axes are square when you're finished. That's easily verified in different ways depending on how your machine is built. The way most corexy mechanisms are laid out, the belts will be about the same tension when the axes are square.
              It can be pretty easy to align the linear guides in a corexy printer if you build the xy mechanism on a flat plate. That's probably true of any other xy motion system, too.
              You can design any printer to be easy to align or alignment can be an afterthought, and then you suffer the consequences.
              Hiroakiundefined 1 Reply Last reply Reply Quote 1
              • Hiroakiundefined
                Hiroaki @mrehorstdmd
                @mrehorstdmd I understand! Thank you!
                • Michael Hathawayundefined
                  Michael Hathaway @Hiroaki
                  @hiroaki I don't use T8 lead screw (too slow), I use Igus high helix lead screws. I will never be as fast as the corexy guys, but I have no belts.
                  https://youtu.be/I-3kKkkonrs
                  Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
                  www.MatterHackers.com - https://discord.gg/Ked7GREqux
                  Hiroakiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                  • Hiroakiundefined
                    Hiroaki @Michael Hathaway
                    @tinken I see, how much is the lead ?
                    Michael Hathawayundefined 1 Reply Last reply Reply Quote 0
                    • fcwiltundefined
                      fcwilt @Michael Hathaway
                      @tinken said in CoreXY or Cartesian which is better ?:
                      Too slow for what?
                      How do you keep your pants up?
                      πŸ˜‰
                      Phaedruxundefined Michael Hathawayundefined 2 Replies Last reply Reply Quote 2
                        Phaedrux Moderator @fcwilt
                        @fcwilt said in CoreXY or Cartesian which is better ?:
                        suspenders obviously.
                          Michael Hathaway @fcwilt
                          @fcwilt Who needs pants... 😊
                            @hiroaki I think they cost about $40 per meter.
                            I think you are best off with a corexy printer. My printers are expensive, extremely accurate for long periods of time without adjustment. But they are slow, 160mm/s max.
                            fcwiltundefined Hiroakiundefined 2 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              Since when is 160 slow? I limit mine to 90.
                              Michael Hathawayundefined 1 Reply Last reply Reply Quote 1
                                @fcwilt I bet you could go 300 if you wanted to..?
                                I only print nylon, so realistically, my maximum is 25-55. To me it's like watching paint dry in Antarctica.
                                • Hiroakiundefined
                                  @tinken Hello No no, My question is the length for one rev of the screw....
                                  • oliofundefined
                                    oliof
                                    Ultimaker Original.
                                    • MaxGyverundefined
                                      MaxGyver
                                      @Hiroaki
                                      In my opinion, a simple Cartesian design is the best choice.
                                      I have come to this conclusion after designing and building 7 high-end printers in CoreXY, Hbelt, Cartesian and Markforged-Style configurations. I have not yet tested the new scurve acceleration feature on a cartesian printer, but I recon it can overcome the added vibration of the extra moving mass.
                                      CoreXY, H-Belt, Markforged etc.
                                      Pros:
                                      • Less moving mass
                                      Cons:
                                      • Longer belts always add "springiness" to the system
                                      • Higher number of belt idlers, that each add a little "wobble" to the system, since even good idlers are often far from running perfectly true
                                      • More idlers mean more parts and also higher wear on the belt since it is bend back and forth around multiple radii.
                                      • The necessary interpolation of X and Y Moves drastically limit the top speed of diagonal moves
                                      • Can take a lot of fiddling until all motors move in the right way
                                      Cartesian:
                                      Pros:
                                      • Higher top speed
                                      • Belts are as short as possible
                                      • Belts are only bend in one direction ->reduced wear
                                      • Fewer parts and very simple
                                      • Super easy setup
                                      Cons:
                                      • higher mass
                                      • extra wiring for the moving motor
                                      Hiroakiundefined fcwiltundefined peter247undefined 3 Replies Last reply Reply Quote 0
                                      • Hiroakiundefined
                                        Hiroaki @MaxGyver
                                        @maxgyver Hello.
                                        Thank you for your advise. It’s very helpful !!!
                                        • fcwiltundefined
                                          fcwilt @MaxGyver
                                          @maxgyver said in CoreXY or Cartesian which is better ?:
                                          Cons:
                                          Have you any data to back up these "cons"? The last two are particularly suspect.
                                          I certainly have not found these "cons" to make any noticeable difference between my printers.
                                          MaxGyverundefined 1 Reply Last reply Reply Quote 0
                                          • MaxGyverundefined
                                            MaxGyver @fcwilt
                                            No, these points are only based on my personal experience and should be seen as such.
                                            Right now I am designing a copy of my markforged-style printer but with a Cartesian belt setup, I am happy to share some data when it is finished.
