    Toolboard Heater Fault
    1.5k
      @dhusolo said in Toolboard Heater Fault:
      M307 H1 R2.330 C273.8:126.9 D12.41 S1.00 V25.7 ; Set PID for Hotend .4Bmm nozzle POST RRF 3.2.3
      I'm surprised the tuning thinks your hotend has 12 seconds of dead time, yet the graph shows it hitting 90c quite quickly.
      Have you tried PID tuning on 3.3 RC3 yet? Might be worth deleting your M307 line and re-tuning.
      What kind of thermistor do you have?
      If you send M98 P"config.g" do you get any errors back?
      dhusoloundefined 1 Reply Last reply Reply Quote 0
      • dhusoloundefined
        dhusolo @Phaedrux
        @phaedrux Yes I noticed it heating up quite quickly however that might be due to the fact that it's a liquid cooled setup.
        I haven't deleted the M307 line and re-tuning but I have tried PID tuning a few times with the existing M307.
        These are the thermistors I'm using. I noticed these are 3950 where I had 4725 in my M308 config however I've been using the same thermistor with the same B value for a few months. link
        When I do M98 P"config.g" I do not get any errors
          Let us know how a fresh PID tuning works out with the corrected B value. It will likely give you a slightly more accurate temp reading. So if you're used to printing at a certain temp now that might change slightly.
          • dhusoloundefined
            dhusolo @Phaedrux
            @phaedrux I just ran it again after clearing M307.
            M303 T0 F0.9 S215
            These are the results
            M307 H1 B0 R2.824 C282.4:110.0 D9.82 S1.00 V25.7
            Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @dhusolo
              @dhusolo Why F0.9?
              Fnn (RRF 3.3beta3 and later) Fan PWM to use when the print cooling fan is turned on (ignored if the T parameter is not present), default 1.0. Use a lower value if youpr printer uses a powerful print cooling fan that you do not normally run at full PWM.
              • dhusoloundefined
                dhusolo @Phaedrux
                @phaedrux tunes with Fan on at 90%
                  Vs
                  Now the quetion is, how does it perform?
                  • dhusoloundefined
                    dhusolo @Phaedrux
                    @phaedrux No change. Started heating to 220C from 30C. It faults once it gets to about 90c. Reset fault and continue heating right away. This time it gets to 180c and faults. Reset again and it'll heat the rest of the way.download.png
                    SIamundefined 1 Reply Last reply Reply Quote 0
                      Can you post a photo of the hotend itself?
                      Is the fan on when heating? Have you tried tuning the heater without the fan?
                      • dhusoloundefined
                        dhusolo @Phaedrux
                        @phaedrux I ran PID tuning again without the "F" parameter and I got
                        M307 H1 B0 R2.837 C252.0:103.7 D9.60 S1.00 V25.7
                        previously with the layer fan on it was
                          What does the hot block look like?
                          Did tuning without the F param help at all?
                          • SIamundefined
                            SIam @dhusolo
                            I'm not sure if it helps, but I recently had such a heating curve with the same error. The solution was a loose Crimp on the Duet Board, so I would say double-check the thermistor wiring with the crimps.
                            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                            Duet WiFi 1.02 or later + DueX5
                            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                            Duet WiFi Server: 1.26
                            Duet Web Control 3.4.0beta4 (2021-09-27)
                            • dhusoloundefined
                              dhusolo @SIam
                              @siam Thanks for the suggestion. I suspected bad crimps so I re-did them just to make sure they had a good connection. The curve is due to the hotend going to a fault state and stops heating. I clear the fault and start heating again
                              • dhusoloundefined
                                dhusolo @Phaedrux
                                @phaedrux It's an older design but for the most part the only thing changed between this and my current setup is now I'm using twin blower fans instead of 1
                                • dhusoloundefined
                                  dhusolo
                                  I've found out that if I heat in increments it doesn't fault. If I go directly to 210 it'll fault. It didn't fault if I set it to 80c, wait for it to heat up, set it to 160c, wait to heat up, than set to 210.
                                    dc42 administrators @dhusolo
                                    1. From those parameters, I think your hot end must have a high thermal mass, a high powered heater, and good insulation. However, turning on the print cooling fan cools the heater a lot. Does that sound right?
                                    2. Please run M307 H1 and check that it reports that those are the parameters.
                                    3. I suggest you try reducing the R parameter. Too high and it will fault while heating up; too low and the temperature will overshoot. Try R2.0.
                                    • dhusoloundefined
                                      dhusolo @dc42
                                      @dc42 It's a mosquito liquid hotend from Slice Engineering. Yesterday I received a new thermistor and heater cartridge from them for that block. I double checked the crimps on the thermistor JST connectors and the wire ferrules on the heater cartridge are good. I don't think it's the cooling fan though. I re-ran PID tuning without the fan and this is the result.
                                      M307 H1 B0 R3.722 C283.2:94.4 D8.95 S1.00 V25.7
                                      This is my sensor settings
                                      M308 S1 P"20.temp0" Y"thermistor" A"Hotend" T100000 B3950 C7.06e-8
                                      M307 H1
                                      Heater 1 model: heating rate 3.722, cooling time constant 283.2/94.4, dead time 8.95, max PWM 1.00, calibration voltage 25.7, mode PID Computed PID parameters: setpoint change: P5.4, I0.106, D33.6, load change: P5.4, I0.263, D33.6
                                      mosquito liquid
                                      50w heater cartridge
                                      thermistor high temperature
                                      tom33undefined 1 Reply Last reply Reply Quote 0
                                      • tom33undefined
                                        tom33 @dhusolo
                                        @dhusolo I have the same problem with dyze extruder, something new about your PID tuning ?
                                        • dhusoloundefined
                                          dhusolo @tom33
                                          @tom33 Nothing new that I can know of. I've been dong the same method for 2 years now
                                          Nuramoriundefined 1 Reply Last reply Reply Quote 0
                                          • Nuramoriundefined
                                            Nuramori @dhusolo
                                            @dhusolo you and I have pretty much the same hardware; I don’t see any of that behavior. I’m perplexed.
