    Accelerometer Usage
    Beta Firmware
    25
    191
    20.2k
      dc42 administrators @StaticRed
      @staticred I just connected a LIS3DH board to my Duet 3 Mini5+ WiFi and it is working as expected. I used connector IO2 to connect the CS and INT lines.
      StaticRedundefined 1 Reply Last reply Reply Quote 0
      • StaticRedundefined
        StaticRed @dc42
        @dc42 thank you for all the infos. I will tomorrow (after upgrading to my new orbiter extruder) solder all the wires to the lis3DH and also make proper connections. Maybe just a faulty cable caused it.
          For anyone having problems getting an SPI-connected accelerometer to work:
          I have found that capacitive coupling between the SDO and CS signals in the cable can cause a glitch on CS when the accelerometer replied to a read register request, and this glitch stops the accelerometer sending any more data. This is especially likely if those two signals, which use adjacent pins on the Adafruit LIS3DH board, use adjacent conductors in a flat cable. I was able to work around this by putting a 1K resistor in series with SDO at the accelerometer end of the cable.
          • Ducati87undefined
            Ducati87
            I'm having an issue with the connection. I used a CAT7 ethernet cable but nothing works. Every time I try to launch the command, the accelerator is not found. Any suggest about which cable I should use? Thankt you.
            SIamundefined dc42undefined 2 Replies Last reply Reply Quote 0
            • SIamundefined
              SIam @Ducati87
              @ducati87 I use a USB3 cable and have no problems since then
              https://forum.duet3d.com/topic/22878/software-package-3-3beta3-released/68?_=1624809172098
              Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
              Duet WiFi 1.02 or later + DueX5
              RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
              Duet WiFi Server: 1.26
              Duet Web Control 3.4.0beta4 (2021-09-27)
              Ducati87undefined 1 Reply Last reply Reply Quote 0
              • Ducati87undefined
                Ducati87 @SIam
                @siam Thank you Slam, I will try it 🙂
                  dc42 administrators @Ducati87
                  @ducati87 said in Accelerometer Usage:
                  See my reply immediately before your post.
                  • Ducati87undefined
                    Ducati87 @dc42
                    @dc42 what do you mean for "in series with SDO at the accelerometer end of the cable"?
                      @ducati87 I mean connect the resistor between the SDO pin of the accelerometer board and the wire that goes to MISO on the Duet, instead of connecting the wire directly to the SDO pin.
                      Ducati87undefined 2 Replies Last reply Reply Quote 1
                      • Ducati87undefined
                        Ducati87 @dc42
                        @dc42 perfect thank you!
                          StaticRed @dc42
                          @dc42 i will definetly try that out. I had firstly swap my board because of that early production process. While doing that i also swapped my z axis, now need to reconfigure than, and then can test the lis3dh again.
                          • Ducati87undefined
                            Ducati87 @dc42
                            @dc42 said in Accelerometer Usage:
                            in spite of the 1K resistor, the accelerometer is not found. I checked the cable on my duet daughter board and everything seems to be ok. Any suggest? Thank you.
                              @ducati87 thanks for trying. I've no more suggestion yet, but I will get back to this when I have time. What sort of cable are you using, and how long is it? Photos of the two ends please.
                              MikeSundefined 1 Reply Last reply Reply Quote 0
                              • MikeSundefined
                                MikeS @dc42
                                @dc42 i'm in the same situation as @Ducati87 . Here's the thread where i have asked for help and post a photo of the wiring https://forum.duet3d.com/topic/24099/accelerometer-on-duet2wifi-duex5-expansion/3
                                • CCS86undefined
                                  CCS86
                                  Same boat here.
                                  M955 P0 >>>> "Accelerometer not found"
                                  M955 P0 C"exp.pa22+exp.pa21" >>>> "Accelerometer not found on specified port"
                                  • Running RRF3.3 Stable
                                  • Wired with a VGA cable. I could probably take about 12" out of the cable length. I left it longer to keep the second ferrite noise filter in place.
                                  dc42undefined tekstyleundefined 2 Replies Last reply Reply Quote 0
                                    dc42 administrators @CCS86
                                    @ccs86 I can't see anything wrong with the wiring or configuration command; so I guess it's an issue of cable length. How long is the cable? A 900mm long multicore cable is working OK for me on a Duet WiFi.
                                    Have you tried temporarily unplugging the PT100 daughter board?
                                    CCS86undefined 1 Reply Last reply Reply Quote 0
                                    • CCS86undefined
                                      CCS86 @dc42
                                      I just tried unplugging the daughterboard and still not finding the accelerometer.
                                      I may try re-wiring with a CAT6 cable, if there aren't any other easier steps to take.
                                      Phaedruxundefined Ducati87undefined 2 Replies Last reply Reply Quote 0
                                        Phaedrux Moderator @CCS86
                                        @ccs86 Are you using a Maestro board?
                                        • CCS86undefined
                                          CCS86 @Phaedrux
                                          @phaedrux said in Accelerometer Usage:
                                          Yes.
                                          Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                            @ccs86 said in Accelerometer Usage:
                                            Yes.
                                            The lack of floating point unit makes accelerometer usage problematic. I didn't even think there was a build for the Maestro.
