    Does it needs to be faster?
    My Duet controlled machine
    599
    • jens55undefined
      jens55
      I didn't see it actually lifting off so yes, it needs to be faster ....
      Chrissundefined 1 Reply Last reply Reply Quote 0
      • Chrissundefined
        Chriss @jens55
        @jens55
        You are right.. the b*tch should start flying... 😄
        • matt3oundefined
          matt3o @Chriss
          @chriss it seems it is banging the head twice against the frame... I'd say you need to go a little slower....
          jens55undefined Chrissundefined 2 Replies Last reply Reply Quote 1
          • jens55undefined
            jens55 @matt3o
            @matt3o, that wasn't the question. The question was 'does it need to go faster'. No parameters where mentioned so a bit of knocking shouldn't really enter into the equation 🙂
            matt3oundefined 1 Reply Last reply Reply Quote 0
            • matt3oundefined
              matt3o @jens55
              @jens55 there's no such thing as "fast enough" in 3d printing 😄
              • jens55undefined
                jens55 @matt3o
                @matt3o ... exactly! Layer shift and crumbling print be damned 🙂
                • mrehorstdmdundefined
                  mrehorstdmd
                  Servomotors FTW!
                  • Chrissundefined
                    Chriss @matt3o
                    @matt3o
                    That is what you hear, indeed. But it happens in slower speed too. The switches are to flush, so the always have the "mechanical" impact. That is the next thing. 😉 And I have to reduce the speed a lot, that was for testing and to swank only. 😉
                    I'm sooo happy that the tiny nema14 are now able to move everything in high speed. The V0 skipped steps at 130mm/s with the old stepper.
                    Cheers, Chriss
                    zaptaundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                    • zaptaundefined
                      zapta @Chriss
                      @chriss, did you purchase a kit or did you source the parts individually? With Vorons, if you stick to the sourcing list the parts (and steppers in this case) should be good.
                      • fcwiltundefined
                        fcwilt @Chriss
                        @chriss
                        IR Beam Break devices for position sensing are nice - they are accurate and silent.
