    PWM to 10V via e0heater always gives 10V
    CNC
    9
    29
    2.1k
    • larswundefined
      larsw @JamesM
      @jamesm said in PWM to 10V via e0heater always gives 10V:
      Duet boards perform their PWM on the ground side and the positive side stays full voltage. The PWM converter you listed appears to want the PWM on the positive lead so it won't work with the duet. I know I've read there are ways around that but I don't remember what they are.
      That makes sense with my observations.
      Looking at the board layout, that seems to be the case for the fans too?
      What about the !e0heat inversion (which I have tried without luck)?
      • cjmundefined
        cjm @larsw
        @larsw
        Just to check, is this is how the PWM board is connected as it should work, provided the jumper on the board is set for “12V to 24V” operation.
        VCC	DC 12V-30V                    -> Duet VIN
        GND	Ground.                       -> Duet 0V
        PWM	Positive of PWM input signal. -> Duet VIN
        GND	Negative of input signal.     -> heater0 pin
        VOUT	Output Voltage 0-10V.         -> Analogue Output
        GND	Output Voltage Ground         -> Duet 0V
        larswundefined 1 Reply Last reply Reply Quote 0
        • alankilianundefined
          alankilian @larsw
          @larsw I would connect the PWM board like this:
          GND	Ground.                       -> Duet Ground
          PWM	Positive of PWM input signal. -> heater0 pin
          GND	Negative of input signal.     -> Duet Ground
          VOUT	Output Voltage 0-10V.         -> Analogue Output to spindle controller
          GND	Output Voltage Ground         -> Ground on the spindle controller
          Then, you need a pullup resistor on the PWM input to the converter.
          Connect a resistor in the range 2,000 to 10,000 Ohms from the PWM input on the converter to a 5 Volt pin on the Duet.
          You can add this resistor on the Duet between the heater0 pin and a 5 Volt pin right at the Duet.
          • larswundefined
            larsw @cjm
            @cjm:
            The jumper is at 24V. I'm not sure exactly which pins you connect. I changed to below to use the names from the Duet 2 wifi board layout. This is how I have it connected.
            VCC	DC 12V-30V                    -> Duet VIN at DC powersupply - its 12,8V
            GND	Ground.                       -> Duet GND at DC powersupply
            PWM	Positive of PWM input signal. -> Heater VIN, it is 12,8V
            GND	Negative of input signal.     -> E0-
            GND	Output Voltage Ground         -> Duet GND
            This results in 10V output no matter M3 Sspeed
            cjmundefined 1 Reply Last reply Reply Quote 0
            • larswundefined
              larsw @alankilian
              @alankilian I assume that heater0 pin is E0- ?
              I have tried this - though without the pullup resistor,
              It almost works - if I use !e0heat in the M950 command I can use the M3 command and adjust from 0 to almost 5V in output.
              The heater PWM is 12,8V - should this be connected with the pullup resistor to 5V, or was that a mistype?
              fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @larsw
                @larsw
                On this device, when disconnected from anything else, can you check if there is continuity between the DC GND pin and the PWM GND pin?
                  alankilian @larsw
                  @larsw said in PWM to 10V via e0heater always gives 10V:
                  Yes.
                  It should be connected with a pullup to 5 Volts.
                  This is the PWM control input to the converter and it's designed to be driven from a microcontroller, so it's input range is 0 to 5 Volts according to what I can get out of the data sheet you linked to in your first post.
                  Does anyone know what "Fengfeng value" might mean" I'm not hitting anything on the google machine.
                  • larswundefined
                    larsw @fcwilt
                    @fcwilt said in PWM to 10V via e0heater always gives 10V:
                    @larsw
                    I just measured and can confirm this.
                    • larswundefined
                      larsw @alankilian
                      @alankilian said in PWM to 10V via e0heater always gives 10V:
                      Actually no - the converter has two PWM input modes - 4,5V to 10V or 12V to 24V. Selectable by a jumper (The documentation calls this a jump needle - had me quite confused). I have jumped it for 12-24V.
                      Nice to know I was not the only one.. Fengfeng value means peak value. That also took me quite a while to get translated.
                        alankilian @larsw
                        OK, that's cool. I was getting confused by the data sheet and couldn't quite get that information from it.
                        Then you can just pull up to the heater supply voltage.
                        • larswundefined
                          larsw @alankilian
                          @alankilian Perfect. Still same resistor range?
                            alankilian @larsw
                            @larsw Yes, the pullup resistor value is not critical at all.
                            i generally use 4.7 KOhms for a quickly changing signal (like this) and a 47 KOhm for slowly changing signals like switches.
                            • cjmundefined
                              cjm @larsw
                              @larsw Understood - and the reason this is not working is because the "Negative of the PWM input signal" is connected to Ground as you measured and confirmed in your answer to @fcwilt. This is unlike other similar boards where both positive and negative PWM inputs are fully isolated from ground, in which case this connection works fine.
                              However, with your board, @alankilian's approach is a good one.
                              larswundefined 2 Replies Last reply Reply Quote 1
                              • larswundefined
                                larsw @cjm
                                @cjm Fantastic - I'll try this in the weekend when I get my hands on the machine again.
                                • cjmundefined
                                  cjm @larsw
                                  @larsw A point to note is that if the photos of your converter board on the web are correct, it uses an opto-isolator with a choice of two series resistor values (selected by the jumpers) to match either 5V or 12V-24V.
                                  The pull-up resistor used in @alankilian’s approach is in series with the opto-isolator’s input resistor and so has to have a low enough value to pass sufficient current to turn on the opto-isolator.
                                  The 2K or 4K values mentioned by @alankilian connected to the heater supply voltage should be fine.
                                  However, some opto-isolators have low efficiency so, if you find you’re not getting reliable results, you might want to try setting the board’s jumper to 5V mode.
                                    dc42 administrators @cjm
                                    @cjm I agree, from the photo it appears that it has an opto isolator for the input. So why is there continuity between the PWM input ground and the output ground?
                                      alankilian @dc42
                                      @dc42 I think I found a picture of the back of the board, and indeed, both the input and output GND connections are to the same net!
                                      Ref: Link.
                                      (And in this photo, PWM might also be shorted to ground Ha ha)
                                      • EducatingSavvasundefined
                                        EducatingSavvas @larsw
                                        @larsw I tried to use a similar type for an older CNC controller of mine and didn't have any luck. I eventually found and used this type which worked:
                                        Available from the usual places.
                                        baird1faundefined 1 Reply Last reply Reply Quote 0
                                        • zaptaundefined
                                          zapta
                                          As a side note, this board reminds me of a similar project by egon.net https://forum.duet3d.com/topic/21680/designing-a-pwm-to-analog-mini-board-for-fans
                                          • larswundefined
                                            larsw @cjm
                                            @cjm I tried the pull resistor (4.7k) and it worked perfectly.
                                            Only issue now is, that the 0-10V output max'es out at 8.6V, but I read somewhare that the converter - even though the specs says VIN 12V to 24V needs least 14,6V to reach 10V in output signal, and my powersupply is 12,8V.
                                            8,6V is close enough - my spindle reaches to max speed at 9V.
                                            alankilianundefined cjmundefined 2 Replies Last reply Reply Quote 0
