PWM to 10V via e0heater always gives 10V
CNC
9
29
1.9k
    larsw @alankilian
    @alankilian said in PWM to 10V via e0heater always gives 10V:
    @larsw said in PWM to 10V via e0heater always gives 10V:
    It should be connected with a pullup to 5 Volts.
    This is the PWM control input to the converter and it's designed to be driven from a microcontroller, so it's input range is 0 to 5 Volts according to what I can get out of the data sheet you linked to in your first post.
    Actually no - the converter has two PWM input modes - 4,5V to 10V or 12V to 24V. Selectable by a jumper (The documentation calls this a jump needle - had me quite confused). I have jumped it for 12-24V.
    Does anyone know what "Fengfeng value" might mean" I'm not hitting anything on the google machine.
    Nice to know I was not the only one.. Fengfeng value means peak value. That also took me quite a while to get translated.
    undefined 1 Reply Last reply 27 Jul 2021, 16:24 Reply Quote 0
      alankilian @larsw
      OK, that's cool. I was getting confused by the data sheet and couldn't quite get that information from it.
      Then you can just pull up to the heater supply voltage.
      undefined 1 Reply Last reply 27 Jul 2021, 17:09 Reply Quote 0
        larsw @alankilian
        @alankilian Perfect. Still same resistor range?
        undefined 1 Reply Last reply 27 Jul 2021, 17:58 Reply Quote 0
          alankilian @larsw
          @larsw Yes, the pullup resistor value is not critical at all.
          i generally use 4.7 KOhms for a quickly changing signal (like this) and a 47 KOhm for slowly changing signals like switches.
            cjm @larsw
            @larsw Understood - and the reason this is not working is because the "Negative of the PWM input signal" is connected to Ground as you measured and confirmed in your answer to @fcwilt. This is unlike other similar boards where both positive and negative PWM inputs are fully isolated from ground, in which case this connection works fine.
            However, with your board, @alankilian's approach is a good one.
            undefined 2 Replies Last reply 28 Jul 2021, 09:49 Reply Quote 1
              larsw @cjm
              @cjm Fantastic - I'll try this in the weekend when I get my hands on the machine again.
              undefined 1 Reply Last reply 30 Jul 2021, 07:28 Reply Quote 0
                cjm @larsw
                @larsw A point to note is that if the photos of your converter board on the web are correct, it uses an opto-isolator with a choice of two series resistor values (selected by the jumpers) to match either 5V or 12V-24V.
                The pull-up resistor used in @alankilian’s approach is in series with the opto-isolator’s input resistor and so has to have a low enough value to pass sufficient current to turn on the opto-isolator.
                The 2K or 4K values mentioned by @alankilian connected to the heater supply voltage should be fine.
                However, some opto-isolators have low efficiency so, if you find you’re not getting reliable results, you might want to try setting the board’s jumper to 5V mode.
                undefined 1 Reply Last reply 30 Jul 2021, 08:02 Reply Quote 1
                  dc42 administrators @cjm
                  @cjm I agree, from the photo it appears that it has an opto isolator for the input. So why is there continuity between the PWM input ground and the output ground?
                  undefined 1 Reply Last reply 30 Jul 2021, 13:26 Reply Quote 0
                    alankilian @dc42
                    @dc42 I think I found a picture of the back of the board, and indeed, both the input and output GND connections are to the same net!
                    Ref: Link.
                    (And in this photo, PWM might also be shorted to ground Ha ha)
                    undefined 1 Reply Last reply 2 Aug 2021, 12:27 Reply Quote 0
                      EducatingSavvas @larsw
                      @larsw I tried to use a similar type for an older CNC controller of mine and didn't have any luck. I eventually found and used this type which worked:
                      Available from the usual places.
                      undefined 1 Reply Last reply 29 Aug 2021, 21:27 Reply Quote 0
                        zapta
                        As a side note, this board reminds me of a similar project by egon.net https://forum.duet3d.com/topic/21680/designing-a-pwm-to-analog-mini-board-for-fans
                          larsw @cjm
                          @cjm I tried the pull resistor (4.7k) and it worked perfectly.
                          Only issue now is, that the 0-10V output max'es out at 8.6V, but I read somewhare that the converter - even though the specs says VIN 12V to 24V needs least 14,6V to reach 10V in output signal, and my powersupply is 12,8V.
                          8,6V is close enough - my spindle reaches to max speed at 9V.
                          undefined undefined 2 Replies Last reply 2 Aug 2021, 13:24 Reply Quote 0
                            dc42 administrators @alankilian
                            @alankilian they've made a mistake with that design IMO, by sharing the ground plane with both ground pins even though the input is optically isolated.
                            I would be tempted to cut the 4 fingers that join each of the pins I have marked to the ground plane, and connect them together with a wire instead.
                              alankilian @larsw
                              That's GREAT news!
                              Thanks for keeping up with our ideas and letting us know you got it working.
                              If you want to get to 9 Volts, you can try adjusting the potentiometer on the board.
                              undefined 1 Reply Last reply 3 Aug 2021, 10:46 Reply Quote 0
                                cjm @larsw
                                @larsw Good news! Glad to hear it’s all working now…
                                  larsw @alankilian
                                  I hope somebody else can use these findings. The converter seems to be pretty common.
                                  This is with the potentioneter at max, but as I said - good enough.
                                    baird1fa @EducatingSavvas
                                    @educatingsavvas
                                    I just wired up one of these and it works too.
                                    One thing to note is that using less than 3000hz seems to result in the generation of a 0-10v signal that the VFD sees as oscillating and then it changes frequencies a lot. It ramps up and down 10’s of hertz.
