    PWM to 10V via e0heater always gives 10V
    CNC
    9
    29
    2.0k
    • alankilianundefined
      alankilian @larsw
      @larsw I would connect the PWM board like this:
      VCC	DC 12V-30V                    -> Duet VIN
      GND	Ground.                       -> Duet Ground
      PWM	Positive of PWM input signal. -> heater0 pin
      GND	Negative of input signal.     -> Duet Ground
      VOUT	Output Voltage 0-10V.         -> Analogue Output to spindle controller
      GND	Output Voltage Ground         -> Ground on the spindle controller
      Then, you need a pullup resistor on the PWM input to the converter.
      Connect a resistor in the range 2,000 to 10,000 Ohms from the PWM input on the converter to a 5 Volt pin on the Duet.
      You can add this resistor on the Duet between the heater0 pin and a 5 Volt pin right at the Duet.
      larswundefined 1 Reply Last reply Reply Quote 0
      • larswundefined
        larsw @cjm
        @cjm:
        The jumper is at 24V. I'm not sure exactly which pins you connect. I changed to below to use the names from the Duet 2 wifi board layout. This is how I have it connected.
        VCC	DC 12V-30V                    -> Duet VIN at DC powersupply - its 12,8V
        GND	Ground.                       -> Duet GND at DC powersupply
        PWM	Positive of PWM input signal. -> Heater VIN, it is 12,8V
        GND	Negative of input signal.     -> E0-
        GND	Output Voltage Ground         -> Duet GND
        This results in 10V output no matter M3 Sspeed
        cjmundefined 1 Reply Last reply Reply Quote 0
        • larswundefined
          larsw @alankilian
          @alankilian I assume that heater0 pin is E0- ?
          I have tried this - though without the pullup resistor,
          It almost works - if I use !e0heat in the M950 command I can use the M3 command and adjust from 0 to almost 5V in output.
          The heater PWM is 12,8V - should this be connected with the pullup resistor to 5V, or was that a mistype?
          fcwiltundefined alankilianundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @larsw
            @larsw
            On this device, when disconnected from anything else, can you check if there is continuity between the DC GND pin and the PWM GND pin?
              alankilian @larsw
              @larsw said in PWM to 10V via e0heater always gives 10V:
              Yes.
              It should be connected with a pullup to 5 Volts.
              This is the PWM control input to the converter and it's designed to be driven from a microcontroller, so it's input range is 0 to 5 Volts according to what I can get out of the data sheet you linked to in your first post.
              Does anyone know what "Fengfeng value" might mean" I'm not hitting anything on the google machine.
              • larswundefined
                larsw @fcwilt
                @fcwilt said in PWM to 10V via e0heater always gives 10V:
                @larsw
                I just measured and can confirm this.
                • larswundefined
                  larsw @alankilian
                  @alankilian said in PWM to 10V via e0heater always gives 10V:
                  Actually no - the converter has two PWM input modes - 4,5V to 10V or 12V to 24V. Selectable by a jumper (The documentation calls this a jump needle - had me quite confused). I have jumped it for 12-24V.
                  Nice to know I was not the only one.. Fengfeng value means peak value. That also took me quite a while to get translated.
                    alankilian @larsw
                    OK, that's cool. I was getting confused by the data sheet and couldn't quite get that information from it.
                    Then you can just pull up to the heater supply voltage.
                    • larswundefined
                      larsw @alankilian
                      @alankilian Perfect. Still same resistor range?
                        alankilian @larsw
                        @larsw Yes, the pullup resistor value is not critical at all.
                        i generally use 4.7 KOhms for a quickly changing signal (like this) and a 47 KOhm for slowly changing signals like switches.
                        • cjmundefined
                          cjm @larsw
                          @larsw Understood - and the reason this is not working is because the "Negative of the PWM input signal" is connected to Ground as you measured and confirmed in your answer to @fcwilt. This is unlike other similar boards where both positive and negative PWM inputs are fully isolated from ground, in which case this connection works fine.
                          However, with your board, @alankilian's approach is a good one.
                          larswundefined 2 Replies Last reply Reply Quote 1
                          • larswundefined
                            larsw @cjm
                            @cjm Fantastic - I'll try this in the weekend when I get my hands on the machine again.
                            • cjmundefined
                              cjm @larsw
                              @larsw A point to note is that if the photos of your converter board on the web are correct, it uses an opto-isolator with a choice of two series resistor values (selected by the jumpers) to match either 5V or 12V-24V.
                              The pull-up resistor used in @alankilian’s approach is in series with the opto-isolator’s input resistor and so has to have a low enough value to pass sufficient current to turn on the opto-isolator.
                              The 2K or 4K values mentioned by @alankilian connected to the heater supply voltage should be fine.
                              However, some opto-isolators have low efficiency so, if you find you’re not getting reliable results, you might want to try setting the board’s jumper to 5V mode.
                                dc42 administrators @cjm
                                @cjm I agree, from the photo it appears that it has an opto isolator for the input. So why is there continuity between the PWM input ground and the output ground?
                                  alankilian @dc42
                                  @dc42 I think I found a picture of the back of the board, and indeed, both the input and output GND connections are to the same net!
                                  Ref: Link.
                                  (And in this photo, PWM might also be shorted to ground Ha ha)
                                  • EducatingSavvasundefined
                                    EducatingSavvas @larsw
                                    @larsw I tried to use a similar type for an older CNC controller of mine and didn't have any luck. I eventually found and used this type which worked:
                                    Available from the usual places.
                                    baird1faundefined 1 Reply Last reply Reply Quote 0
                                    • zaptaundefined
                                      zapta
                                      As a side note, this board reminds me of a similar project by egon.net https://forum.duet3d.com/topic/21680/designing-a-pwm-to-analog-mini-board-for-fans
                                      • larswundefined
                                        larsw @cjm
                                        @cjm I tried the pull resistor (4.7k) and it worked perfectly.
                                        Only issue now is, that the 0-10V output max'es out at 8.6V, but I read somewhare that the converter - even though the specs says VIN 12V to 24V needs least 14,6V to reach 10V in output signal, and my powersupply is 12,8V.
                                        8,6V is close enough - my spindle reaches to max speed at 9V.
                                        alankilianundefined cjmundefined 2 Replies Last reply Reply Quote 0
                                          dc42 administrators @alankilian
                                          @alankilian they've made a mistake with that design IMO, by sharing the ground plane with both ground pins even though the input is optically isolated.
                                          I would be tempted to cut the 4 fingers that join each of the pins I have marked to the ground plane, and connect them together with a wire instead.
                                            alankilian @larsw
                                            That's GREAT news!
                                            Thanks for keeping up with our ideas and letting us know you got it working.
                                            If you want to get to 9 Volts, you can try adjusting the potentiometer on the board.
