    Accelerometer Usage
    Beta Firmware
    25
    191
    21.4k
      dc42 administrators @CCS86
      @ccs86 try using the temp daughterboard connector instead of the 12864_EXP2 connector. If you have a temperature daughterboard installed, you can connect to the pins on top of it.
      CCS86undefined 1 Reply Last reply Reply Quote 0
      • CCS86undefined
        CCS86 @dc42
        @dc42 said in Accelerometer Usage:
        I just tried like this and still get the not found error:
        M955 P0 C"twd0+twck0"
        (I assume that is a typo in your dozuki edit: Unknown pin name 'twcl0')
        (orange is CS... wht/grn is INT)
        o_lampeundefined CCS86undefined 2 Replies Last reply Reply Quote 0
        • o_lampeundefined
          o_lampe @CCS86
          @ccs86
          do you have evidence that the accelerator board is OK?
          • CCS86undefined
            CCS86 @o_lampe
            @o_lampe said in Accelerometer Usage:
            @ccs86
            The green light comes on, so that's a start. I'm not sure what else I might be able to test with my multimeter.
            • CCS86undefined
              CCS86 @CCS86
              @ccs86 said in Accelerometer Usage:
              @dc42 Does this setup look correct? Any other ideas?
                No, it isn't correct. If the PT100 board was not there, it might be correct. However, the PT100 board does not route TWD0 and TWCK0 straight through, it routes them to the CS2 and CS1 positions on the top connector, so that if you stack another daughterboard on top, it will use TWCK0 and TWD0 instead of CS1 and CS2.
                • CCS86undefined
                  CCS86 @dc42
                  Like this then?
                    @ccs86 that looks better. Alternatively, connect all the accelerometer wires to the connector on top of the PT100 board.
                    Edit: I think you may have the orange and dashed green wires crossed.
                    I can test that configuration when my bench system is free again.
                    • CCS86undefined
                      CCS86
                      Do you have a complete pinout for the installed daughterboard? I wasn't able to find one on the wiki.
                      When you say "crossed", do you just mean mis-matched to the M955 P0 C"twd0+twck0"?
                      So I could physically swap the wires, or update to M955 P0 C"twck0+twd0"?
                        yes.
                        TheBasedDogeundefined CCS86undefined 2 Replies Last reply Reply Quote 0
                        • TheBasedDogeundefined
                          TheBasedDoge @dc42
                          I am trying to setup the Adafruit LIS3DH Accelerometer with no luck so far. I have the Duet2 Wifi. I think that it is connected, light is on, and i didn't get an error in the log for it not being able to connect, but I am not getting any data. I am getting a drive error in the log:
                          • CCS86undefined
                            CCS86 @dc42
                            yes.
                              dc42 administrators @TheBasedDoge
                              @thebaseddoge use P0 in your M956 command (same as in your M955 command), not P124.0.
                                @ccs86 it's probably a wiring issue. A few days go I updated the wiring instructions at https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Direct_SPI_connection_to_a_Duet_main_board. The first photo in that section is the 1m long cable that I used successfully to connect the Adafruit board to the Maestro.
                                You might like to try connecting the accelerometer to the Duet first using short jumper wires. When you have that working, you can try the same connections with a longer cable, taking care to keep the CS wire away from the other signal wires.
                                • CCS86undefined
                                  CCS86 @dc42
                                  Could you tell us what wires are considered signal wires?
                                  I can try short jumpers, but I feel very good about my wiring. This was a fresh piece of CAT6 off the spool, all terminals crimped with a proper tool (EDM jaws), and it is the minimum length needed (shorter than 1 m).
                                  Is the 1k resistor still benefiting my setup?
                                  • tekstyleundefined
                                    tekstyle @CCS86
                                    @ccs86
                                    is there any reason to use VIN instead of the 3V pin on the LIs3DH module?
                                    • CCS86undefined
                                      CCS86 @tekstyle
                                      @tekstyle said in Accelerometer Usage:
                                      @ccs86
                                      Yes, because that is a 3V output.
                                      The V_in pin can take a 3-5V input.
                                      • CCS86undefined
                                        CCS86
                                        All re-wired with short jumpers... same issue.
                                          @ccs86 please connect all the jumpers to the appropriate pins on top of the temperature daughter board.
                                          • CCS86undefined
                                            CCS86 @dc42
                                            I would need that pinout, since it does not match the mainboard pinout.
