    Help with apparently too hot printing
    64
    3.1k
    • fcwiltundefined
      fcwilt @jens55
      @jens55 said in Help with apparently too hot printing:
      @fcwilt, it's a fairly old model and probably not available any more.
      Here it is from Amazon.com:
      https://www.amazon.com/beruna-Creality-Printing-500x500x500mm-Assembly/dp/B08VD6TKQ1/ref=sr_1_5?dchild=1&keywords=creality+cr-10+s5&qid=1627795739&sr=8-5
      The printer produces good prints if you accept artifacts related to slinging the heavy bed. Yes, I can do better if I go slower. Yes I can do calibration cubes.
      Even the current print job is ok except for the huge overhang. I am not concerned with the mechanical vibration. I am in the process of building a Jubilee for jobs that need a better finish.
      I have a normal 300x300 CR10 and it is set up with ABS and it prints the same model just fine but it uses the original Creality controller (the S5 uses a Duet2)
      Thanks for the info.
      The difference between 300x300 and 500x500 is very significant. The Y axis drive system may not be robust enough.
      Also looking at the picture in the link you provided the printer looks like it is going to suffer from vibration issues.
      If you can generate good prints at slow speeds but not high, try cutting back on the acceleration and jerk settings in your config.g file to very modest levels but keep the print speed up - just as a test.
      And for basic PLA use an extruder temp of 190, a bed temp of 60 and turn off PA and the like.
      • jens55undefined
        jens55 @fcwilt
        @fcwilt said in Help with apparently too hot printing:
        The difference between 300x300 and 500x500 is very significant. Y axis drive system may not be robust enough.
        Oh yeah .... a significant difference! The Y axis is robust but that isn't going to help in the overall vibration issue.
        Yup!
        As I mentioned, acceleration (via Cura) is 500 and jerk is 8 so pretty low values. I am at 70 mm/sec for printing speed including walls. I could bring the outside wall speed down to half ... which is what it was when I started this journey (and which didn't help)
        Well I am printing with supports at the corners and with PA turned off now so tomorrow morning will be interesting ....
        MikeSundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
        • MikeSundefined
          MikeS @jens55
          @jens55 can you record a little video showing that acceleration? Maybe it is still too high, but the numbers doesn't mean anything to me because i don't own a bedslinger.
          • jens55undefined
            jens55 @MikeS
            @mikes, I have never recorded a video with my phone and have no clue what / who / how / where / why .....
            For now I will want to see how tomorrows print looks like (with 0 PA and support in the corners) and I might run another print with the same parameters (ie no PA) and no support.
            MikeSundefined 1 Reply Last reply Reply Quote 0
            • MikeSundefined
              MikeS @jens55
              @jens55 another thing to check is that the filament must be dry. If you leaved the spool outside a dry box for more than one week you probably have to dehydrate it. Wet filament produces more stringing and flow inconsistencies.
              • jens55undefined
                jens55 @MikeS
                @mikes, the filament did indeed have a moisture problem which resulted in very low adhesion of the first layer to the build plate but it was dried and works fine again.
                • fcwiltundefined
                  fcwilt @jens55
                  Well it's hard to tell from the picture but it looks like it is belt driven using one belt - perhaps 9mm. And it may have some sort of belt tensioning device.
                  Given there may be 1000mm or more of belt that represents a pretty good spring which means accurately positioning a heavy bed (at speed) is going to be somewhat of a challenge.
                  Without any hands-on experience I would suspect that 70 mm/sec is rather optimistic.
                  Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 0
                  • Luke'sLaboratoryundefined
                    Luke'sLaboratory @fcwilt
                    If its a quality 9mm belt it should be fine. I run 9mm belt on my bed which is 5/16" mic6 with an AC heater and magsheet setup - its about 5kg all said and done and works fine over 300mm/s at 5kaccel. I bet the v-wheels aren't in the best orientation for the heavier bed load which could add, but I heavily suspect PA is responsible for the issues currently at hand.
                    Luke
                    http://lukeslab.online
                    • jens55undefined
                      jens55
                      My latest test print have me out of ideas and filament (from the roll I have been using so far)
                      I can report that pressure advance definitely was an issue !
                      I can report that the switch to random seam shows only a tiny 'hickup' at any of the 4 corners. I will definitely have to run PA calibration though as a PA of 0 clearly shows PA issues. I always planned on calibrating that so that's not a huge surprise.
                      If I print with support turned on and the overhang angle set to 50 degrees, I get support at just the four corners. This improves the outcome but with contact between the point of the corner and the support being ever so tiny and missing on occasion, I still had one corner that had some bending up causing problems.
                      Things are vastly improved over the original model when all this started.
                      So, where to go from here ...... since I used up the roll I was working with, I will try a different roll from a different manufacturer (or at least a different brand name) and see what happens.
                      • fcwiltundefined
                        fcwilt @jens55
                        @jens55
                        Glad to hear you are making progress.
                        I've never used PA but I'm thinking I may experiment with it.
                        engikeneerundefined jens55undefined Luke'sLaboratoryundefined 3 Replies Last reply Reply Quote 0
                        • engikeneerundefined
                          engikeneer @fcwilt
                          @fcwilt you are missing out my friend! Even on direct drives, I've found a small amount helps
                          i3 clone with a bunch of mods
                          • jens55undefined
                            jens55 @fcwilt
                            @fcwilt, I started out with a Bowden setup (CR10) and PA is a noticeable (significant) improvement for that (even though I know people who use no PA). My second printer was the CR10 S5 which has a Bowden tube of probably close to 800 mm. It would be nuts to expect reasonable prints from that without PA.
                            I am starting to work with direct drive extruders now and PA can help for the discerning person but isn't absolutely essential. It might be essential if you are doing soft stuff like TPU but haven't tried that yet.
                            • jens55undefined
                              jens55
                              Final update:
                              Different filament did the same thing with curling at the points of the corners.
                              I had previously reported that support at the corner edges helped but that one corner still had problems. I changed the X/Y/Z distances between support and the model in Cura which got me a solid support and no curling.
                              To sum it up, the two big issues where pressure advance and support. I am sure I printed without support to at least 60 degrees of overhang before but maybe I didn't and maybe the shape of this model causes issues earlier but setting the support angle at 50 degrees and having the support close enough to the edge fixed all the issues. While the side angle was 45 degrees, the edge where two 45 degree sides meet must be just under 55 degree overhang.
                              While I did go down to 180C from my normal 200C nozzle temp for PLA, I do not know if that was actually necessary given that support was the big issue. It did help when there was no support.
                              Thank you to everybody that helped me sort through this issue !!!
                              • jens55undefined
                                jens55
                                Well well well ..... I think I jinxed it when I said 'final' update.
                                So I kept thinking about the blower fan I use for model cooling. Yes, it works, yes I can reduce the output and it turns nicely even at 25% .... but I just couldn't leave well enough alone.
                                I removed the fan so I could gauge the output a bit better and there clearly was output. Put a new fan on to compare - same thing.
                                Still wasn't happy so hooked up a power supply, hooked up one of the fans and got the same output.
                                Contemplated life a bit and decided that still wasn't good enough!
                                I dug out yet another new fan and hooked that up .... the output was probably 4 times as much air !!!!
                                I will attempt to print one more of the fence post caps but this time with proper air flow for cooling.
                                Boy will I be pissed off if it prints perfectly even with no support!
                                I will also get myself a new batch of better quality fans (this time ball bearings) !
                                I can't believe that there is a good chance that I spent 3 days or so printing because of a fan issue, the very first thing I checked and suspected!
                                All fans were marked as 24V and I use 24V but either two of the fans were 36 or 48V or defective (while behaving just fine except for low rpm)
                                  @fcwilt
                                  If tuned correctly PA makes a world of difference printing fast.
                                  @jens55 they could just be worse fans, unless they're the same brand/model. Fans are not equivalent even if they're the same size. Glad to see things are moving in the correct direction
                                  Luke
                                  • jens55undefined
                                    jens55 @Luke'sLaboratory
                                    @luke-slaboratory, same brand of fan ... all from the same batch I ordered
                                    Phaedruxundefined Luke'sLaboratoryundefined 2 Replies Last reply Reply Quote 0
                                      Phaedrux Moderator @jens55
                                      Chinesium?
                                      • jens55undefined
                                        jens55 @Phaedrux
                                        @phaedrux, you bet 🙂
                                          Luke'sLaboratory @jens55
                                          @jens55 Yeesh. Unlucky 😕
                                          Luke
                                          • MikeSundefined
                                            MikeS @jens55
                                            @jens55 some fans does not like being pwm'd. Try changing the switching frequency of that fan when you declare it in config.g .
