    Diagnostics Missing?
    Beta Firmware
    610
    • sebkritikelundefined
      sebkritikel @GeneRisi
      @generisi said in Diagnostics Missing?:
      When I enter M122, I don't get any information. I also don't see "diag" files in the list of assets. What am I missing? Thanks!
      Just upgraded to 3.4.0beta2 (2021-08-03) and Duet Web Control 3.4.0-b2 and can confirm M122 does not return diagnostics.
      Its actually a little trickier (tested Firefox and Chrome). If I send M122 on my PC, it only confirms the event in green. If I have console opened at the same time on mobile (Safari) the results of M122 are shown there. If I send M122 on mobile (Safari) the inverse is true, event is returned as green but on PC the diagnostics are printed.
      Large(ish?) IDEX - 6HC, 1HCL
      Stratasys Dimension 1200es to 6HC Conversion
      chrishammundefined GeneRisiundefined 2 Replies Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @sebkritikel
        @sebkritikel Make sure you have only one active DWC tab/session per device.
        Duet software engineer
        sebkritikelundefined 1 Reply Last reply Reply Quote 0
          sebkritikel @chrishamm
          @chrishamm Seeing no change
          • Closed out of all active DWC sessions (mobile, PC, etc)
          • Rebooted printer
          • M122 -> no diag output on PC/session that sent M122
          • Opened DWC on PC and Mobile
          • Rebooted printer
          • M122 on PC -> no output on PC/session that sent M122, output visible on mobile
          • M122 on mobile -> no output on mobile/session that sent M122, output visible on PC
            @sebkritikel That's odd, it sounds like you access DWC through a network tunnel. Can you check how many HTTP sessions are reported by M122? It should be two, one for your mobile and another one for the PC.
              @chrishamm said in Diagnostics Missing?:
              It reports two sessions (with mobile and PC connected). FWIW the mobile device is connected to the same WiFi network.
              I was previously running one of the latest Input Shaping binaries and definitely did not notice this behavior.
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta2 (2021-08-03 12:41:37) running on Duet WiFi 1.02 or later + DueX5
              Board ID: 08DGM-917DA-G4MSD-6JTDD-3SN6L-1STR9
              Used output buffers: 3 of 24 (24 max)
              Static ram: 23932
              Dynamic ram: 79136 of which 0 recycled
              Never used RAM 9012, free system stack 186 words
              Tasks: NETWORK(notifyWait,14.3%,233) ACCEL(notifyWait,0.0%,348) HEAT(delaying,0.0%,326) Move(notifyWait,0.0%,364) DUEX(notifyWait,0.0%,24) MAIN(running,85.6%,443) IDLE(ready,0.0%,29), total 100.0%
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:00:59 ago, cause: software
              Last software reset at 2021-08-05 11:06, reason: User, GCodes spinning, available RAM 9012, slot 2
              Error status: 0x04
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 34.0, current 34.3, max 34.8
              Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: position 0, standstill, SG min/max not available
              Driver 1: position 0, standstill, SG min/max not available
              Driver 2: position 0, standstill, SG min/max not available
              Driver 3: position 0, standstill, SG min/max not available
              Driver 4: position 0, standstill, SG min/max not available
              Driver 5: position 0, standstill, SG min/max not available
              Driver 6: position 0, standstill, SG min/max not available
              Driver 7: position 0, standstill, SG min/max not available
              Driver 8: position 0, standstill, SG min/max not available
              Driver 9: position 0, standstill, SG min/max not available
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2021-08-05 11:07:02
              Cache data hit count 2152506680
              Slowest loop: 6.23ms; fastest: 0.17ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 1.0ms, write time 0.0ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty
              === DueX ===
              Read count 0, 0.00 reads/min
              === Network ===
              Slowest loop: 205.64ms; fastest: 0.09ms
              HTTP sessions: 2 of 8
              - WiFi -
              Network state is active
              Failed messages: pending 0, notready 0, noresp 1
              WiFi firmware version 1.23
              WiFi MAC address cc:50:e3:0d:25:4b
              WiFi Vcc 3.40, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 20968
              WiFi IP address 192.168.0.8
              WiFi signal strength -40dBm, mode none, reconnections 0, sleep mode modem
              Clock register ffffffff
              Socket states: 4 0 0 0 0 0 0 0
              • GeneRisiundefined
                GeneRisi @GeneRisi
                @generisi When I enter M122 on the Paneldue, I get the first few lines on its' screen.
                • GeneRisiundefined
                  GeneRisi @sebkritikel
                  @sebkritikel Thanks for the confirmation!
                    Phaedrux Moderator @GeneRisi
                    @generisi Unfortunately the PanelDue doesn't have enough ram and display capacity to show the entire M122 report on it's screen.
                    Can yu confirm that you are using 3.4 beta 2 and are experiencing the same symptoms as @sebkritikel ?
                    GeneRisiundefined 1 Reply Last reply Reply Quote 0
                    • GeneRisiundefined
                      GeneRisi @Phaedrux
                      @phaedrux Yes, I am running 3.4beta2. I haven't tried opening two browsers from two different IP addresses; should I ?
                        You could. You might see the same behaviour as seb did and see the output of M122 at least.
                        • GeneRisiundefined
                          GeneRisi @Phaedrux
                          @phaedrux I just tried 2 different browsers on same PC.Diagnostic info shows on first duet web session and browser when entered into the second web browser session. It does not appear to work the other way around
                          Board ID: 08DGM-9T6BU-FG3SJ-6JKF4-3SD6L-TUXRF
                          Static ram: 23932
                          Dynamic ram: 79440 of which 0 recycled
                          Never used RAM 4940, free system stack 98 words
                          Tasks: NETWORK(ready,14.0%,227) ACCEL(notifyWait,0.0%,348) HEAT(delaying,0.1%,326) Move(notifyWait,1.7%,285) DUEX(notifyWait,0.0%,24) MAIN(running,84.1%,381) IDLE(ready,0.0%,29), total 100.0%
                          Last reset 03:58:03 ago, cause: software
                          Last software reset at 2021-08-05 09:23, reason: User, GCodes spinning, available RAM 8916, slot 2
                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00417000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                          Error status: 0x0c
                          Aux0 errors 0,0,0
                          MCU temperature: min 37.1, current 37.6, max 38.1
                          Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
                          Driver 0: position 24822, ok, SG min/max 0/1023
                          Driver 1: position 4516, ok, SG min/max 0/1023
                          Driver 2: position 90248, standstill, SG min/max 0/1023
                          Driver 3: position 3300, ok, SG min/max 0/1023
                          Date/time: 2021-08-05 13:21:32
                          Slowest loop: 12.86ms; fastest: 0.18ms
                          === Storage ===
                          Free file entries: 9
                          SD card longest read time 1.3ms, write time 0.0ms, max retries 0
                          DMs created 83, segments created 38, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 168818, completed moves 168778, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                          === AuxDDARing ===
                          Heater 0 is on, I-accum = 0.0
                          Heater 1 is on, I-accum = 0.5
                          Segments left: 1
                          File is doing "G1 X140.012 Y77.042 E0.0100" in state(s) 0
                          Code queue is empty
                          === DueX ===
                          === Network ===
                          Slowest loop: 201.01ms; fastest: 0.08ms
                          HTTP sessions: 1 of 8
                          - WiFi -
                          Failed messages: pending 0, notready 0, noresp 2
                          WiFi firmware version 1.26
                          WiFi MAC address ec:fa:bc:25:34:dd
                          WiFi Vcc 3.34, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 24632
                          WiFi IP address 192.168.123.68
                          WiFi signal strength -69dBm, mode 802.11n, reconnections 0, sleep mode modem
                          Clock register 00002002
                            Thanks for confirming.
                            • GeneRisiundefined
                              GeneRisi @Phaedrux
                              @phaedrux And it only displays the diagnostics issues once. After that, all it shows in the console on both browsers is "M122"
                                sebkritikel
                                @chrishamm I just upgraded to DWC and RRF 3.4.0-b3/3.4.0beta3 (2021-08-24) and am still having this issue.
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta3 (2021-08-24 13:56:10) running on Duet WiFi 1.02 or later + DueX5
                                Static ram: 23940
                                Dynamic ram: 77256 of which 44 recycled
                                Never used RAM 10840, free system stack 184 words
                                Tasks: NETWORK(ready,15.8%,227) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.0%,364) DUEX(notifyWait,0.0%,24) MAIN(running,84.1%,441) IDLE(ready,0.1%,29), total 100.0%
                                Last reset 00:01:03 ago, cause: software
                                Last software reset at 2021-08-25 15:58, reason: User, GCodes spinning, available RAM 10840, slot 0
                                Error status: 0x04
                                Aux0 errors 0,0,0
                                MCU temperature: min 31.2, current 31.8, max 31.8
                                Date/time: 2021-08-25 15:59:56
                                Cache data hit count 2383346339
                                Slowest loop: 6.10ms; fastest: 0.16ms
                                === Storage ===
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                Code queue is empty
                                === DueX ===
                                === Network ===
                                Slowest loop: 201.10ms; fastest: 0.09ms
                                - WiFi -
                                WiFi flash size 4194304, free heap 23960
                                WiFi signal strength -39dBm, mode none, reconnections 0, sleep mode modem
                                  dc42 administrators @sebkritikel
                                  @sebkritikel we've identified an issue in DWC that prevents the M122 response from a Duet WiFi being displayed in some situations. It looks like it may have been triggered by the response getting a little longer.
