    Diagnostics Missing?
    Beta Firmware
    610
    • GeneRisiundefined
      GeneRisi @GeneRisi
      @generisi When I enter M122 on the Paneldue, I get the first few lines on its' screen.
      • GeneRisiundefined
        GeneRisi @sebkritikel
        @sebkritikel Thanks for the confirmation!
          Phaedrux Moderator @GeneRisi
          @generisi Unfortunately the PanelDue doesn't have enough ram and display capacity to show the entire M122 report on it's screen.
          Can yu confirm that you are using 3.4 beta 2 and are experiencing the same symptoms as @sebkritikel ?
          GeneRisiundefined 1 Reply Last reply Reply Quote 0
          • GeneRisiundefined
            GeneRisi @Phaedrux
            @phaedrux Yes, I am running 3.4beta2. I haven't tried opening two browsers from two different IP addresses; should I ?
              You could. You might see the same behaviour as seb did and see the output of M122 at least.
              • GeneRisiundefined
                GeneRisi @Phaedrux
                @phaedrux I just tried 2 different browsers on same PC.Diagnostic info shows on first duet web session and browser when entered into the second web browser session. It does not appear to work the other way around
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta2 (2021-08-03 12:41:37) running on Duet WiFi 1.02 or later + DueX5
                Board ID: 08DGM-9T6BU-FG3SJ-6JKF4-3SD6L-TUXRF
                Used output buffers: 3 of 24 (24 max)
                Static ram: 23932
                Dynamic ram: 79440 of which 0 recycled
                Never used RAM 4940, free system stack 98 words
                Tasks: NETWORK(ready,14.0%,227) ACCEL(notifyWait,0.0%,348) HEAT(delaying,0.1%,326) Move(notifyWait,1.7%,285) DUEX(notifyWait,0.0%,24) MAIN(running,84.1%,381) IDLE(ready,0.0%,29), total 100.0%
                Owned mutexes: WiFi(NETWORK)
                Last reset 03:58:03 ago, cause: software
                Last software reset at 2021-08-05 09:23, reason: User, GCodes spinning, available RAM 8916, slot 2
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00417000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x0c
                Aux0 errors 0,0,0
                Step timer max interval 0
                MCU temperature: min 37.1, current 37.6, max 38.1
                Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
                Driver 0: position 24822, ok, SG min/max 0/1023
                Driver 1: position 4516, ok, SG min/max 0/1023
                Driver 2: position 90248, standstill, SG min/max 0/1023
                Driver 3: position 3300, ok, SG min/max 0/1023
                Driver 4: position 0, standstill, SG min/max not available
                Driver 5: position 0, standstill, SG min/max not available
                Driver 6: position 0, standstill, SG min/max not available
                Driver 7: position 0, standstill, SG min/max not available
                Driver 8: position 0, standstill, SG min/max not available
                Driver 9: position 0, standstill, SG min/max not available
                Driver 10: position 0
                Driver 11: position 0
                Date/time: 2021-08-05 13:21:32
                Slowest loop: 12.86ms; fastest: 0.18ms
                === Storage ===
                Free file entries: 9
                SD card longest read time 1.3ms, write time 0.0ms, max retries 0
                DMs created 83, segments created 38, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 168818, completed moves 168778, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                === AuxDDARing ===
                Heater 0 is on, I-accum = 0.0
                Heater 1 is on, I-accum = 0.5
                Segments left: 1
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is doing "G1 X140.012 Y77.042 E0.0100" in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty
                === DueX ===
                Read count 0, 0.00 reads/min
                === Network ===
                Slowest loop: 201.01ms; fastest: 0.08ms
                HTTP sessions: 1 of 8
                - WiFi -
                Network state is active
                Failed messages: pending 0, notready 0, noresp 2
                WiFi firmware version 1.26
                WiFi MAC address ec:fa:bc:25:34:dd
                WiFi Vcc 3.34, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 24632
                WiFi IP address 192.168.123.68
                WiFi signal strength -69dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
                  Thanks for confirming.
                  • GeneRisiundefined
                    GeneRisi @Phaedrux
                    @phaedrux And it only displays the diagnostics issues once. After that, all it shows in the console on both browsers is "M122"
                    • sebkritikelundefined
                      sebkritikel
                      @chrishamm I just upgraded to DWC and RRF 3.4.0-b3/3.4.0beta3 (2021-08-24) and am still having this issue.
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta3 (2021-08-24 13:56:10) running on Duet WiFi 1.02 or later + DueX5
                      Board ID: 08DGM-917DA-G4MSD-6JTDD-3SN6L-1STR9
                      Static ram: 23940
                      Dynamic ram: 77256 of which 44 recycled
                      Never used RAM 10840, free system stack 184 words
                      Tasks: NETWORK(ready,15.8%,227) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.0%,364) DUEX(notifyWait,0.0%,24) MAIN(running,84.1%,441) IDLE(ready,0.1%,29), total 100.0%
                      Last reset 00:01:03 ago, cause: software
                      Last software reset at 2021-08-25 15:58, reason: User, GCodes spinning, available RAM 10840, slot 0
                      Error status: 0x04
                      Aux0 errors 0,0,0
                      MCU temperature: min 31.2, current 31.8, max 31.8
                      Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: position 0, standstill, SG min/max not available
                      Driver 1: position 0, standstill, SG min/max not available
                      Driver 2: position 0, standstill, SG min/max not available
                      Driver 3: position 0, standstill, SG min/max not available
                      Date/time: 2021-08-25 15:59:56
                      Cache data hit count 2383346339
                      Slowest loop: 6.10ms; fastest: 0.16ms
                      === Storage ===
                      Free file entries: 10
                      SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      File is idle in state(s) 0
                      Code queue is empty
                      === DueX ===
                      === Network ===
                      Slowest loop: 201.10ms; fastest: 0.09ms
                      HTTP sessions: 2 of 8
                      - WiFi -
                      WiFi firmware version 1.23
                      WiFi MAC address cc:50:e3:0d:25:4b
                      WiFi Vcc 3.40, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 23960
                      WiFi IP address 192.168.0.8
                      WiFi signal strength -39dBm, mode none, reconnections 0, sleep mode modem
                      Clock register ffffffff
                      Large(ish?) IDEX - 6HC, 1HCL
                      Stratasys Dimension 1200es to 6HC Conversion
                        dc42 administrators @sebkritikel
                        @sebkritikel we've identified an issue in DWC that prevents the M122 response from a Duet WiFi being displayed in some situations. It looks like it may have been triggered by the response getting a little longer.
