Accelerometers on a bedslinger
783
    tecno
    So I have now mounted my LIS3DSH, one on X/Z axis and one Y under the bed.
    What is the best/easiest way to wire up to my Duet Mini5+ ? On X/Z I have one Toolboard V1.
    undefined 1 Reply Last reply 6 Aug 2021, 17:35 Reply Quote 0
      dc42 administrators @tecno
      @tecno see https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Direct_SPI_connection_to_a_Duet_main_board. Pay attention to keeping the CS signal away from other signal wires, as I did in the cable I made up.
      Alternatively, connect it to a SAMMYC21 and connect that to the D3Mini via CAN - but that costs more.
      undefined 1 Reply Last reply 6 Aug 2021, 18:25 Reply Quote 0
        tecno @dc42
        Do I use 2 IO's one each for X/Z and Y and run both accelerometers? Or 1 IO and switch cable?
        undefined 1 Reply Last reply 6 Aug 2021, 18:27 Reply Quote 0
          @tecno if you are connecting both via SPI, you can do either. RRF currently only supports one directly-connected accelerometer, so even if you do use two different I/O ports, you will still need to change the accelerometer config command to switch between them.
          undefined 1 Reply Last reply 6 Aug 2021, 18:30 Reply Quote 0
            tecno @dc42
            OK one cable to one port it is then, thank you !
            undefined 1 Reply Last reply 7 Aug 2021, 11:36 Reply Quote 1
              tecno @tecno
              Is this OK?
              Wire# Duet Mini5+
              1 nc
              2 IO_3 GND
              3 nc
              4 SBC26_23
              5 SBC26_19
              6 SBC26_26
              7 IO_3 in
              8 IO_3 3.3V
              9 IO_3 out
              10 nc
              undefined 1 Reply Last reply 7 Aug 2021, 12:03 Reply Quote 0
                @tecno no, don't use the SBC connector, that's on a different SPI channel.
                undefined 1 Reply Last reply 8 Aug 2021, 16:20 Reply Quote 0
                  tecno @dc42
                  Cables fixed today, one accelerometer and the other to have IO1 extended outside for easier tests not needed to breakdown the printer from is cabinet.
                  undefined 1 Reply Last reply 9 Aug 2021, 12:00 Reply Quote 0
                    tecno @tecno
                    2021-08-09 13:35:50 M955 P0
                    Error: M955: Accelerometer not found
                    2021-08-09 13:29:40 M955 P0 C"io3.out+io3.in"
                    Error: M955: Accelerometer not found on specified port
                    Any suggestions what to do next?
                    undefined 1 Reply Last reply 11 Aug 2021, 08:58 Reply Quote 0
                      @tecno are those results with or without the extension cable? The ribbon cable by itself should be OK if it is made up the same as the one I illustrated at https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Direct_SPI_connection_to_a_Duet_main_board.
                      undefined 1 Reply Last reply 11 Aug 2021, 09:19 Reply Quote 0
                        tecno @dc42
                        1m and to your spec. Have continuity tested the cable/connectors. NO extension.
                        undefined 1 Reply Last reply 11 Aug 2021, 09:21 Reply Quote 0
                          tecno @tecno
                          These are going back to seller, I do not believe these are DSH. Board looks very different to others on market. Ordered new from PureTek in UK that are on its way.
                          undefined 1 Reply Last reply 11 Aug 2021, 09:34 Reply Quote 0
                            @tecno confirm you are using RRF 3.4beta2 ? Earlier versions do not support the LIS3DSH.
                            undefined 1 Reply Last reply 11 Aug 2021, 09:36 Reply Quote 0
                              tecno @dc42
                              Still on 3.3, expected a sign of life.
                              undefined 1 Reply Last reply 11 Aug 2021, 09:39 Reply Quote 0
                                @tecno said in Accelerometers on a bedslinger:
                                If it's a LIS3DSH (not 3DH) then you won't get any response using 3.3.
                                undefined 1 Reply Last reply 11 Aug 2021, 09:56 Reply Quote 0
                                  o_lampe @dc42
                                  Is there any benefit in using the DSH variant?
                                  undefined 1 Reply Last reply 11 Aug 2021, 10:11 Reply Quote 0
                                    dc42 administrators @o_lampe
                                    @o_lampe it has higher resolution, different sampling rates and produces a slightly cleaner signal.
                                    5 out of 17
