    Accelerometers on a bedslinger
    784
      dc42 administrators @tecno
      @tecno if you are connecting both via SPI, you can do either. RRF currently only supports one directly-connected accelerometer, so even if you do use two different I/O ports, you will still need to change the accelerometer config command to switch between them.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @dc42
        OK one cable to one port it is then, thank you !
        tecnoundefined 1 Reply Last reply Reply Quote 1
        • tecnoundefined
          tecno @tecno
          Is this OK?
          Wire# Duet Mini5+
          1 nc
          2 IO_3 GND
          3 nc
          4 SBC26_23
          5 SBC26_19
          6 SBC26_26
          7 IO_3 in
          8 IO_3 3.3V
          9 IO_3 out
          10 nc
            @tecno no, don't use the SBC connector, that's on a different SPI channel.
            • tecnoundefined
              tecno @dc42
              Cables fixed today, one accelerometer and the other to have IO1 extended outside for easier tests not needed to breakdown the printer from is cabinet.
              • tecnoundefined
                tecno @tecno
                2021-08-09 13:35:50 M955 P0
                Error: M955: Accelerometer not found
                2021-08-09 13:29:40 M955 P0 C"io3.out+io3.in"
                Error: M955: Accelerometer not found on specified port
                Any suggestions what to do next?
                  @tecno are those results with or without the extension cable? The ribbon cable by itself should be OK if it is made up the same as the one I illustrated at https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Direct_SPI_connection_to_a_Duet_main_board.
                  • tecnoundefined
                    tecno @dc42
                    1m and to your spec. Have continuity tested the cable/connectors. NO extension.
                    • tecnoundefined
                      tecno @tecno
                      These are going back to seller, I do not believe these are DSH. Board looks very different to others on market. Ordered new from PureTek in UK that are on its way.
                        @tecno confirm you are using RRF 3.4beta2 ? Earlier versions do not support the LIS3DSH.
                        • tecnoundefined
                          tecno @dc42
                          Still on 3.3, expected a sign of life.
                            @tecno said in Accelerometers on a bedslinger:
                            If it's a LIS3DSH (not 3DH) then you won't get any response using 3.3.
                            • o_lampeundefined
                              o_lampe @dc42
                              Is there any benefit in using the DSH variant?
                                dc42 administrators @o_lampe
                                @o_lampe it has higher resolution, different sampling rates and produces a slightly cleaner signal.
