    Accelerometers on a bedslinger
    783
    • tecnoundefined
      tecno @dc42
      OK one cable to one port it is then, thank you !
      tecnoundefined 1 Reply Last reply Reply Quote 1
      • tecnoundefined
        tecno @tecno
        Is this OK?
        Wire# Duet Mini5+
        1 nc
        2 IO_3 GND
        3 nc
        4 SBC26_23
        5 SBC26_19
        6 SBC26_26
        7 IO_3 in
        8 IO_3 3.3V
        9 IO_3 out
        10 nc
          dc42 administrators @tecno
          @tecno no, don't use the SBC connector, that's on a different SPI channel.
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @dc42
            Cables fixed today, one accelerometer and the other to have IO1 extended outside for easier tests not needed to breakdown the printer from is cabinet.
            • tecnoundefined
              tecno @tecno
              2021-08-09 13:35:50 M955 P0
              Error: M955: Accelerometer not found
              2021-08-09 13:29:40 M955 P0 C"io3.out+io3.in"
              Error: M955: Accelerometer not found on specified port
              Any suggestions what to do next?
                @tecno are those results with or without the extension cable? The ribbon cable by itself should be OK if it is made up the same as the one I illustrated at https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Direct_SPI_connection_to_a_Duet_main_board.
                • tecnoundefined
                  tecno @dc42
                  1m and to your spec. Have continuity tested the cable/connectors. NO extension.
                  • tecnoundefined
                    tecno @tecno
                    These are going back to seller, I do not believe these are DSH. Board looks very different to others on market. Ordered new from PureTek in UK that are on its way.
                      @tecno confirm you are using RRF 3.4beta2 ? Earlier versions do not support the LIS3DSH.
                      • tecnoundefined
                        tecno @dc42
                        Still on 3.3, expected a sign of life.
                          @tecno said in Accelerometers on a bedslinger:
                          If it's a LIS3DSH (not 3DH) then you won't get any response using 3.3.
                          • o_lampeundefined
                            o_lampe @dc42
                            Is there any benefit in using the DSH variant?
                              dc42 administrators @o_lampe
                              @o_lampe it has higher resolution, different sampling rates and produces a slightly cleaner signal.
