Tool board - no response
741
    dutti @dc42
    @dc42 ok update done. thanks
    Now, I have very crazy number on thermistor for tool 0.
    undefined 1 Reply Last reply 11 Aug 2021, 19:53 Reply Quote 0
      dutti @dutti
      undefined 1 Reply Last reply 11 Aug 2021, 21:17 Reply Quote 0
        M307 H0 B0 R0.243 C586.2 D33.87 S1.00 V220.0
        Did you manually set V220?
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M307_Set_or_report_heating_process_parameters
        Vnnn VIN supply voltage at which the A parameter was calibrated (RepRapFirmware 1.20 and later). This allows the PID controller to compensate for changes in supply voltage. A value of zero disables compensation for changes in supply voltage. Use V0 for AC mains powered heaters. (V0 is the default. Leaving off V is the same as V0)
        V220 would mean your heater is mains powered? But if that is the case, it suggests using V0 instead.
        undefined 1 Reply Last reply 11 Aug 2021, 20:12 Reply Quote 0
          dutti @Phaedrux
          I did it manually 😕
          I changed the number to 0.
          Same problem....
            No that's fine. And it's not related to your tool temperature anyway, it just stuck out to me.
            Can you please try adding a G4 S4 to the start of your config.g to allow for the tool boards to power up before they are sent commands and see if that has any impact on the spurious reading.
            Can you also check that your DWC version matches the firmware 3.3?
            Can you send M122 and M122 B121 and post the results?
            undefined 1 Reply Last reply 11 Aug 2021, 20:34 Reply Quote 0
              dutti @Phaedrux
              @phaedrux
              After setting G4 S4 in front of the g.code --> same problem
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode)
              Board ID: 08DJM-956L2-G43S8-6J9D0-3S46R-9U2AD
              Used output buffers: 3 of 40 (13 max)
              Static ram: 150904
              Dynamic ram: 92748 of which 100 recycled
              Never used RAM 110440, free system stack 200 words
              Tasks: NETWORK(ready,12.0%,212) ETHERNET(notifyWait,0.1%,124) HEAT(delaying,0.0%,331) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.1%,799) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,6.8%,93) MAIN(running,33.2%,1096) IDLE(ready,47.8%,29), total 100.0%
              Owned mutexes:
              Last reset 00:00:51 ago, cause: software
              Last software reset at 2021-08-11 22:31, reason: User, GCodes spinning, available RAM 110464, slot 1
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              Step timer max interval 127
              MCU temperature: min 39.8, current 40.2, max 41.3
              Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
              Driver 0: position 0, standstill, reads 25598, writes 14 timeouts 0, SG min/max 0/0
              Driver 1: position 0, standstill, reads 25598, writes 14 timeouts 0, SG min/max 0/0
              Driver 2: position 0, standstill, reads 25598, writes 14 timeouts 0, SG min/max 0/0
              Driver 3: position 0, standstill, reads 25599, writes 14 timeouts 0, SG min/max 0/0
              Driver 4: position 0, standstill, reads 25599, writes 14 timeouts 0, SG min/max 0/0
              Driver 5: position 0, standstill, reads 25599, writes 14 timeouts 0, SG min/max 0/0
              Date/time: 2021-08-11 22:32:07
              Slowest loop: 9.13ms; fastest: 0.05ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 2.3ms, write time 0.0ms, max retries 0
              DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === CAN ===
              Messages queued 450, received 364, lost 67, longest wait 2ms for reply type 6049, peak Tx sync delay 6, free buffers 49 (min 48), ts 257/256/0
              Tx timeouts 0,0,0,0,0,0
              === Network ===
              Slowest loop: 17.57ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              • Ethernet -
                State: active
                Error counts: 0 0 1 0 0
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 16:15:35 GMT+0200 (Mitteleuropäische Sommerzeit)
              M550 P"Duet 3" ; set printer name
              M552 S1 P192.168.2.108 ; Wifi
              G4 S4
              M569 P0.2 S0 ; physical drive 0.2 goes forwards
              M569 P0.3 S0 ; physical drive 0.2 goes forwards
              M569 P0.4 S0 ; physical drive 0.2 goes forwards
              M569 P0.5 S0 ; physical drive 0.2 goes forwards
              M569 P121.0 S1 ; physical drive 121.0 goes forwards
              M569 P122.0 S1 ; physical drive 122.0 goes forwards
              M569 P123.0 S1 ; physical drive 123.0 goes forwards
              M584 M584 X1.1 Y0.0:0.1 Z0.2:0.3:0.4:0.5 E121.0:122.0:123.0 ; set drive mapping
              M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
              M92 X160.00 Y160.00 Z640.00 E409.00:409.00:409.00 ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E3000.00:3000.00:3000.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X12000.00 Y12000.00 Z6000.00 E6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z300.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
              M906 X1300 Y1300 Z2500 E1000:1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-10 Y-10 Z10 S1 ; set axis minima
              M208 X1030 Y1030 Z1030 S0 ; set axis maxima
              M574 X2 S1 P"^io3.in" ; configure active-high endstop for high end on X via pin ^io3.in
              M574 Y2 S1 P"^io1.in" ; configure active-high endstop for high end on Y via pin ^io1.in
              M574 Z1 S1 P"^io2.in" ; configure active-high endstop for low end on Z via pin ^io2.in
              M558 P0 H-5 F300 T300 ; disable Z probe but set dive height, probe speed and travel speed
              M556 S50 X0 Y0 Z70 ; set orthogonal axis compensation parameters
              M557 X10:10 Y10:10 S20 ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M307 H0 B0 R0.243 C586.2 D33.87 S1.00 V0 ; disable bang-bang mode for the bed heater and set PWM limit
              M308 S1 P"121.temp0" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin 121.temp0
              M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
              M143 H1 S250 ; set temperature limit for heater 1 to 250C
              M308 S2 P"122.temp0" Y"pt1000" R2200 ; configure sensor 2 as PT1000 on pin 122.temp0
              M950 H2 C"122.out0" T2 ; create nozzle heater output on 122.out0 and map it to sensor 2
              M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
              M143 H2 S250 ; set temperature limit for heater 2 to 250C
              M308 S3 P"123.temp0" Y"pt1000" R2200 ; configure sensor 3 as PT1000 on pin 123.temp0
              M950 H3 C"123.out0" T3 ; create nozzle heater output on 123.out0 and map it to sensor 3
              M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
              M143 H3 S250 ; set temperature limit for heater 3 to 250C
              M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
              M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
              M950 F2 C"122.out1" Q500 ; create fan 2 on pin 122.out1 and set its frequency
              M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
              M950 F3 C"122.out2" Q500 ; create fan 3 on pin 122.out2 and set its frequency
              M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on
              M950 F4 C"123.out1" Q500 ; create fan 4 on pin 123.out1 and set its frequency
              M106 P4 S1 H-1 ; set fan 4 value. Thermostatic control is turned off
              M950 F5 C"123.out2" Q500 ; create fan 5 on pin 123.out2 and set its frequency
              M106 P5 S1 H3 T45 ; set fan 5 value. Thermostatic control is turned on
              M950 F6 C"out4" Q500 ; create fan 6 on pin out4 and set its frequency
              M106 P6 S1 H-1 ; set fan 6 value. Thermostatic control is turned off
              M950 F7 C"out5" Q500 ; create fan 7 on pin out5 and set its frequency
              M106 P7 S1 H T45 ; set fan 7 value. Thermostatic control is turned on
              G10 P0 X30 Y28.25 Z45 ; set tool 0 axis offsets
              M563 P1 D1 H2 F2 ; define tool 1
              M563 P2 D2 H3 F4 ; define tool 2
              G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
              G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
              undefined 1 Reply Last reply 11 Aug 2021, 20:35 Reply Quote 0
                dutti @dutti
                @barbarossa-cologne M122 B121
                Diagnostics for board 121:
                Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
                Bootloader ID: not available
                Never used RAM 3636, free system stack 2789 words
                Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.1%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(delaying,2.9%,57) MAIN(running,92.1%,350) IDLE(ready,0.0%,41) AIN(delaying,4.9%,142), total 100.0%
                Last reset 00:03:41 ago, cause: software
                Last software reset data not available
                Driver 0: position 0, 409.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 61, reads 45026, writes 13, timeouts 0, DMA errors 0, steps req 0 done 0
                Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter 0/9, peak Rx sync delay 208, resyncs 0/0, no step interrupt scheduled
                VIN: 24.1V
                MCU temperature: min 38.4C, current 38.5C, max 38.8C
                Ticks since heat task active 186, ADC conversions started 220384, completed 220383, timed out 0, errs 0
                Last sensors broadcast 0x00000002 found 1 191 ticks ago, loop time 0
                CAN messages queued 2487, send timeouts 0, received 1957, lost 0, free buffers 37, min 37, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                Accelerometer detected: no
                I2C bus errors 4619, naks 4619, other errors 4619
                  Can you send m98 p"config.g" and post the results?
                  Do you have your other tool boards connected as well?
                  undefined 1 Reply Last reply 11 Aug 2021, 20:45 Reply Quote 0
                    dutti @Phaedrux
                    @phaedrux
                    I don´t have the other connected, yet.
                    Error: Response timeout: CAN addr 123, req type 6027, RID=96
                    Error: Fan number 5 not found
                    Error: in file macro line 82 column 13: M106: expected number after 'H'
                    11.8.2021, 22:44:22 Error: Response timeout: CAN addr 123, req type 6027, RID=94
                    Error: Fan number 4 not found
                    11.8.2021, 22:44:20 Error: Response timeout: CAN addr 122, req type 6027, RID=90
                    Error: Fan number 2 not found
                    Error: Response timeout: CAN addr 122, req type 6027, RID=92
                    Error: Fan number 3 not found
                    11.8.2021, 22:44:16 Error: Response timeout: CAN addr 123, req type 6026, RID=82
                    Error: Heater 3 not found
                    Error: Heater 3 does not exist
                    11.8.2021, 22:44:14 Error: Response timeout: CAN addr 122, req type 6043, RID=68
                    Response timeout: CAN addr 123, req type 6043, RID=69
                    Error: bad grid definition: X range too small
                    Error: Response timeout: CAN addr 122, req type 6031, RID=76
                    Error: Response timeout: CAN addr 122, req type 6026, RID=78
                    Error: Heater 2 not found
                    Error: Heater 2 does not exist
                    Error: Response timeout: CAN addr 123, req type 6031, RID=80
                    11.8.2021, 22:44:06 Error: Response timeout: CAN addr 122, req type 6042, RID=64
                    Response timeout: CAN addr 123, req type 6042, RID=65
                    11.8.2021, 22:44:04 Error: Response timeout: CAN addr 122, req type 6042, RID=60
                    Response timeout: CAN addr 123, req type 6042, RID=61
                    11.8.2021, 22:44:02 Error: Response timeout: CAN addr 122, req type 6042, RID=56
                    Response timeout: CAN addr 123, req type 6042, RID=57
                    11.8.2021, 22:44:00 Error: Response timeout: CAN addr 123, req type 6018, RID=53
                    Driver assignments: X1.1 Y0.0:0.1 Z0.2:0.3:0.4:0.5 E121.0:122.0:123.0, 3 axes visible
                    11.8.2021, 22:43:59 m98 p"config.g"
                    Error: Response timeout: CAN addr 122, req type 6018, RID=52
                    undefined 1 Reply Last reply 11 Aug 2021, 20:49 Reply Quote 0
                      dutti @dutti
                      @barbarossa-cologne
                      Hot end fan is running.
                      Print cooling fan is not running.
                      I can´t control both.
                        How is the PT1000 connected?
                        Is it actually a PT1000?
                        Photos of your toolboard wiring?
                        undefined 2 Replies Last reply 11 Aug 2021, 21:00 Reply Quote 0
                          dutti @Phaedrux
                          @phaedrux
                          It's the original tool changer thermistor.
                          Is it a pt100?
                          Oh no...
                            dutti @Phaedrux
                            undefined 1 Reply Last reply 11 Aug 2021, 21:10 Reply Quote 0
                              dutti @dutti
                                dc42 administrators @dutti
                                @barbarossa-cologne I've seen that crazy temperature value once before when a tool board was configured for a PT1000 sensor but the sensor wasn't connected.
                                undefined 2 Replies Last reply 11 Aug 2021, 21:19 Reply Quote 0
                                  dutti @dc42
                                  @dc42 that's what I checked another time 2 minutes ago. It's definitely connected.
                                  undefined 1 Reply Last reply 11 Aug 2021, 21:26 Reply Quote 0
                                    @barbarossa-cologne have you measured its resistance, to verify that it is a PT1000, not a PT100 or a thermistor?
                                    undefined 1 Reply Last reply 11 Aug 2021, 21:27 Reply Quote 0
                                      dutti @dc42
                                      @dc42 connected a different thermistor = same problem
                                        dutti @dc42
                                        Yes. Now I connected a typical Chinese thermistor and it shows the same number for temperature:/
                                        undefined 1 Reply Last reply 11 Aug 2021, 21:28 Reply Quote 0
                                          @barbarossa-cologne the config.g file you posted was for a PT1000, not a thermistor. Specifically, this line:
                                          undefined 1 Reply Last reply 11 Aug 2021, 21:30 Reply Quote 0
                                          12 out of 23
