    Meta commands
    Gcode meta commands
    2.0k
    • alankilianundefined
      alankilian @jens55
      @jens55 You want to rewrite the logic of that code using a 'break' statement instead of a 'continue' statement.
      'continue' causes the loop to go back to the top of the loop.
      'break' causes the loop to be exited.
      Maybe something like this? (UNTESTED)
      while true
        m118 s"hello world"
        g4 s2
        if iterations > 9
          break
      abort
      From HERE:
      A loop may contain one or more break statements, which would normally be inside if-constructs:
      while <boolean-expression>
        if <boolean-expression>
          break
      The break statement transfers control to the line following the end of the loop body.
      A loop may also contain one or more continue statements, which would normally be inside if-constructs:
          continue
      The continue statement increments the iteration counter and transfers control back to the start of the loop, ready to evaluate the while-condition again.
      • jens55undefined
        jens55
        Thanks for that but I still don't quite understand. From what I understand (yeah, very little), the 'continue' statement does go back to the top like you said but the block that has the 'continue' statement is in the loop of 'if iteration < 10.' So in my thinking, if iterations gets to 10, that 'if' block fails and the next executed statement should be 'abort' .... ????
        DanS79undefined alankilianundefined 2 Replies Last reply Reply Quote 0
        • DanS79undefined
          DanS79 @jens55
          @jens55
          It's just a guess, but since no commands are being run when the if statement fails interations might not get incremented (maybe a bug).
          As a developer I'm not sure i like the concept of an iterations variable.
          the documentation says this about it.
          iterations - The number of completed iterations of the innermost loop
          If you have nested looping structures it could get difficult to follow the code.
          if i have all the syntax correct, something like this is more standard in the software development world.
          var cnt = 0
          while cnt < 10
              set var.cnt = cnt + 1
              m118 s"hello world"
              g4 s2
            alankilian @jens55
            @jens55 said in Meta commands:
            You can take that 'continue' statement out completely and see that the macro runs just the same.
            Every time the interpreter gets to the end of the loop it will jump back to the top of the loop.
            So when the 'if' statement is not true, the interpreter does go to the next 'statement'. If there are no more statements in the loop, so it goes back to the top.
            This might be a better way to do the loop and make it more understandable to you.
            while iterations < 10
                m118 s"hello world"
                g4 s2
            Or this might make it even MORE clear (I tested this one!)
            m118 s"Starting the loop"
                  m118 s"hello world"
                  g4 s2
            m118 s"Done with the loop"
            8/12/2021, 2:27:26 PM 	Done with the loop
            8/12/2021, 2:27:24 PM 	hello world
            8/12/2021, 2:27:22 PM 	hello world
            8/12/2021, 2:27:20 PM 	hello world
            8/12/2021, 2:27:18 PM 	hello world
            8/12/2021, 2:27:16 PM 	hello world
            8/12/2021, 2:27:14 PM 	hello world
            8/12/2021, 2:27:12 PM 	hello world
            8/12/2021, 2:27:10 PM 	hello world
            8/12/2021, 2:27:08 PM 	hello world
            8/12/2021, 2:27:06 PM 	M98 P"0:/macros/000_test"
            Starting the loop
            hello world
            • jens55undefined
              jens55 @DanS79
              @dans79, agreed, that is the way I am used to program a loop and yes, nested loops will be a nightmare.
                alankilian @jens55
                Why?
                Each loop gets its own iterator (which is what iterators ARE) so everything works out.
                while iterations < 3
                      m118 s"hello world first"
                        m118 s"hello world second"
                          m118 s"hello world third"
                8/12/2021, 2:57:50 PM 	M98 P"0:/macros/000_test"
                Starting the loop
                hello world first
                hello world second
                hello world third
                hello world third
                hello world third
                hello world second
                hello world third
                hello world third
                hello world third
                hello world second
                hello world third
                hello world third
                hello world third
                hello world first
                hello world second
                hello world third
                hello world third
                hello world third
                hello world second
                hello world third
                hello world third
                hello world third
                hello world second
                hello world third
                hello world third
                hello world third
                hello world first
                hello world second
                hello world third
                hello world third
                hello world third
                hello world second
                hello world third
                hello world third
                hello world third
                hello world second
                hello world third
                hello world third
                hello world third
                Done with the loop
                DanS79undefined 1 Reply Last reply Reply Quote 0
                • DanS79undefined
                  DanS79 @alankilian
                  @alankilian said in Meta commands:
                  Why?
                  They are all called iterations.
                  If use want to use multiple of them to set a variable, the code would be very hard to read (assuming scoping even allows you to access all of them).
                  The following would be real confusing to follow if you replaced a, b, and c with iterations .
                  var x = 0
                  var a = 0
                  var b = 0
                  var c = 0
                  while a < 10
                      set var.b = 0
                      while b < 20
                          set var.c = 0
                          while c < 40
                              set var.x = (a * b) - c
                              set var.c = c + 1
                           set var.b = b + 1
                      set var.a = a + 1
                    alankilian @DanS79
                    @dans79 Yeah, there are a thousand wrong ways to use a programming feature for every right way to use them.
                    • jens55undefined
                      jens55
                      I think we are drifting away from the part that I am having problems with which is why the particular construct I was using was having issues. Yes, there is a way to change things but WHY is it needed.
                      Here is a different way of going:
                      This works:
                        m118 s{"hello world " ^ iterations}
                        g4 s2
                        continue
                      This gives:
                      Error: in file macro line 6 column 11: meta command: 'continue' was not inside a loop
                      ;  m118 s{"hello world " ^ iterations}
                        g4 s2
                        continue
                      The commented out line seems to dump the 'continue' statement outside of the loop and seems to me to be a bug in interpretation.
                        alankilian @jens55
                        @jens55 You don't need to add a 'continue' statement at the end of a loop.
                          alankilian @jens55
                          You need to be very particular with the left-side whitespace to keep things working.
                          The interpreter is going to look at how many tab (or space)?) characters you have at the beginning of every line to know where the end of the loops are.
                          Your commented-out line starts with a semicolon in column one which tells the interperter that's the end of your while loop.
                          So, the 'continue' statement is not outside of the loop.
                          • jens55undefined
                            jens55 @alankilian
                            @alankilian, I realize that .... but what I am getting at is that something is fishy about how this is interpreted. While I don't need the 'continue', there should be nothing barring me from using it. It isn't inherently wrong.
                              alankilian @jens55
                              @jens55 That semicolon in column-1 causes the interpeter to end the while loop.
                              This works:
                                g4 s2
                                continue
                              • jens55undefined
                                jens55 @alankilian
                                @alankilian, I will test that but the semicolon is there to comment out the line and should not cause this reaction.
                                  alankilian @jens55
                                  @jens55 This works to keep the whitespace:
                                    g4 s2
                                    continue
                                  • jens55undefined
                                    jens55 @alankilian
                                    @alankilian
                                    Ahhhh, I need the spaces before the comment .... ok but that s a bug in the interpreter
                                      alankilian @jens55
                                      This post is deleted!
                                        alankilian @jens55
                                        From the documentation:
                                        The body ends just before the first line that is not indented.
                                        So, it could be argued that the interpreter is working fine.
                                        It's not up to me to decide.
                                        I'm happy you're getting going on your project again.
                                        And I learned some things from this discussion, so thank you for that also.
                                        • jens55undefined
                                          jens55
                                          Here is another example of strange behaviour:
                                          while true
                                            if iterations < 10
                                              m118 s"hello world"
                                              g4 s2
                                              continue
                                          break
                                          This executes but leaves the printer in a 'busy' state
                                          Without the 'break' command it does the same
                                          If I move the 'break' command to the right by two spaces, everything finishes ok - it breaks out of the loop
                                          Point is, there is no such thing as an 'endif' to clearly identify where the 'if' statement ends. IMHO there should be (optional maybe) an 'endif' for readability but in any case, the 'break' should break out of the loop no matter what.
                                          Edit: On re-reading this, there is a flaw in my thinking here, and unless the 'break' is indented two spaces over, the 'while' loop has no exit. Interesting note here is that the iteration variable apparently isn't reset until after exiting the 'while' loop because it only prints 'hello world' for one 'if' loop.
                                          That to me seems rather odd ....
                                          OwenDundefined 1 Reply Last reply Reply Quote 0
                                          • OwenDundefined
                                            OwenD @jens55
                                            @jens55
                                            Nothing strange about it.
                                            Using "while true" creates an infinite loop
                                            This is a dangerous practice for the uninitiated as you must ensure that at some point you have a conditional that triggers a break command.
                                            You have not done so. Therefore the loop continues.
                                            Once it gets to iteration 10 it just stops sending the echo.
                                            You should have put
                                            'if iterations < 10
                                                 Echo "blah blah"
                                            else
                                                  break
                                            Your continue command is useless as it's not part of the while construct.
                                            The point of continue is to skip an iteration.
                                            'if iterations < 10
                                                 if iterations = 5
                                                        continue
                                                 Echo "blah blah" ; won't happen on #5
                                            else
                                                  break  ;  required to end loop
                                            It's safer to use
                                            blah blah
                                            EDIT
                                            Sorry. Doing this on my phone so I could not see your code
                                            Your BREK is outside the whole loop, but the comments stand
                                            jens55undefined 1 Reply Last reply Reply Quote 1
