    Meta commands
    Gcode meta commands
    2.0k
    • jens55undefined
      jens55
      I think we are drifting away from the part that I am having problems with which is why the particular construct I was using was having issues. Yes, there is a way to change things but WHY is it needed.
      Here is a different way of going:
      This works:
      while iterations < 10
        m118 s{"hello world " ^ iterations}
        g4 s2
        continue
      This gives:
      Error: in file macro line 6 column 11: meta command: 'continue' was not inside a loop
      ;  m118 s{"hello world " ^ iterations}
        g4 s2
        continue
      The commented out line seems to dump the 'continue' statement outside of the loop and seems to me to be a bug in interpretation.
      alankilianundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @jens55
        @jens55 You don't need to add a 'continue' statement at the end of a loop.
          alankilian @jens55
          @jens55 said in Meta commands:
          You need to be very particular with the left-side whitespace to keep things working.
          The interpreter is going to look at how many tab (or space)?) characters you have at the beginning of every line to know where the end of the loops are.
          Your commented-out line starts with a semicolon in column one which tells the interperter that's the end of your while loop.
          So, the 'continue' statement is not outside of the loop.
          • jens55undefined
            jens55 @alankilian
            @alankilian, I realize that .... but what I am getting at is that something is fishy about how this is interpreted. While I don't need the 'continue', there should be nothing barring me from using it. It isn't inherently wrong.
              alankilian @jens55
              @jens55 That semicolon in column-1 causes the interpeter to end the while loop.
              This works:
                g4 s2
                continue
              • jens55undefined
                jens55 @alankilian
                @alankilian, I will test that but the semicolon is there to comment out the line and should not cause this reaction.
                  alankilian @jens55
                  @jens55 This works to keep the whitespace:
                    g4 s2
                    continue
                  • jens55undefined
                    jens55 @alankilian
                    @alankilian
                    Ahhhh, I need the spaces before the comment .... ok but that s a bug in the interpreter
                      alankilian @jens55
                      This post is deleted!
                        alankilian @jens55
                        From the documentation:
                        The body ends just before the first line that is not indented.
                        So, it could be argued that the interpreter is working fine.
                        It's not up to me to decide.
                        I'm happy you're getting going on your project again.
                        And I learned some things from this discussion, so thank you for that also.
                        • jens55undefined
                          jens55
                          Here is another example of strange behaviour:
                          while true
                            if iterations < 10
                              m118 s"hello world"
                              g4 s2
                              continue
                          break
                          This executes but leaves the printer in a 'busy' state
                          Without the 'break' command it does the same
                          If I move the 'break' command to the right by two spaces, everything finishes ok - it breaks out of the loop
                          Point is, there is no such thing as an 'endif' to clearly identify where the 'if' statement ends. IMHO there should be (optional maybe) an 'endif' for readability but in any case, the 'break' should break out of the loop no matter what.
                          Edit: On re-reading this, there is a flaw in my thinking here, and unless the 'break' is indented two spaces over, the 'while' loop has no exit. Interesting note here is that the iteration variable apparently isn't reset until after exiting the 'while' loop because it only prints 'hello world' for one 'if' loop.
                          That to me seems rather odd ....
                          OwenDundefined 1 Reply Last reply Reply Quote 0
                          • OwenDundefined
                            OwenD @jens55
                            @jens55
                            Nothing strange about it.
                            Using "while true" creates an infinite loop
                            This is a dangerous practice for the uninitiated as you must ensure that at some point you have a conditional that triggers a break command.
                            You have not done so. Therefore the loop continues.
                            Once it gets to iteration 10 it just stops sending the echo.
                            You should have put
                            'if iterations < 10
                                 Echo "blah blah"
                            else
                                  break
                            Your continue command is useless as it's not part of the while construct.
                            The point of continue is to skip an iteration.
                            'if iterations < 10
                                 if iterations = 5
                                        continue
                                 Echo "blah blah" ; won't happen on #5
                            else
                                  break  ;  required to end loop
                            It's safer to use
                            blah blah
                            EDIT
                            Sorry. Doing this on my phone so I could not see your code
                            Your BREK is outside the whole loop, but the comments stand
                            jens55undefined 1 Reply Last reply Reply Quote 1
                            • jens55undefined
                              jens55
                              Here is another thing that strikes me as odd:
                              while true
                                if iterations < 10
                                  m118 s"hello world"
                                  g4 s2
                                  continue
                                if iterations < 11
                                  m118 s"hello north america"
                              	g4 s2
                              	continue
                                break
                              This code will execute the first 'if' for 10 times but will not reset 'iterations' as I would have expected and because of that will only execute the second 'if' loop once.
                              • jens55undefined
                                jens55 @OwenD
                                @owend said in Meta commands:
                                To skip an iteration ???? Where did you see this in the documentation ???
                                I look at 'continue' as a command that strictly exists as a means to improve readability of the code since the command itself seems to do diddly squat and can be left out.
                                alankilianundefined DanS79undefined 2 Replies Last reply Reply Quote 0
                                  alankilian @jens55
                                  'continue' jumps back to the BEGINNING of a loop.
                                  So if you have the following story: (COMPLETELY useless, but trying to illuminate how 'continue' is used)
                                    m118 s{"This is iteration " ^ iterations}
                                    if iterations > 5
                                      continue  ; Don't do this stuff after the first 5 iterations
                                    m118 s{"Perform this action on " ^ iterations}
                                  This is iteration 0
                                  Perform this action on 0
                                  This is iteration 1
                                  Perform this action on 1
                                  This is iteration 2
                                  Perform this action on 2
                                  This is iteration 3
                                  Perform this action on 3
                                  This is iteration 4
                                  Perform this action on 4
                                  This is iteration 5
                                  Perform this action on 5
                                  This is iteration 6
                                  This is iteration 7
                                  This is iteration 8
                                  This is iteration 9
                                    alankilian @jens55
                                    while true
                                      if iterations < 10
                                        m118 s"hello world"
                                        g4 s2
                                        continue
                                      if iterations < 11
                                    	g4 s2
                                    	continue
                                      break
                                    Why do you think 'iterations' will get reset to zero?
                                    'iterations' counts the number of times through the loop.
                                    Your 'if' statements will not affect the iteration count at all.
                                    • DanS79undefined
                                      DanS79 @jens55
                                      To be clear it doesn't skip an iteration, it skips everything after the continue statement in the current iteration. It goes back to the top of the looping structure and starts the next iteration. Every programming language I can think of works this way.
                                        alankilian @jens55
                                        @jens55 I'm trying to help you understand how this works, but your responses seem to be accusatory (the interpreter is broken) and inflammatory, so if you don't change your attitude, I'll check out of this conversation.
                                        I'm really trying to help you understand how to write programs in a clear understandable way.
                                        Ref: I'm a retired embedded-systems software and hardware engineer who has been programming since about 1978, so I've got the experience to be able to help and in addition, you can help me learn new things also if we both work together on it.
                                        • jens55undefined
                                          jens55 @alankilian
                                          @alankilian, I REALLY appreciate any and all help and I apologize if you felt in any way slighted whatsoever. It was most certainly not my intent !!!
                                          I got confused by the sentence "The point of continue is to skip an iteration."
                                          DanS79 cleared it up and confirmed my interpretation by saying "To be clear it doesn't skip an iteration, it skips everything after the continue statement in the current iteration." IE it doesn't skip an iteration but goes back to the beginning of the loop.
                                          Your example (thanks) did however clarify another point on the continue command that I was not aware of and hence my earlier confusion about sequential 'if' statements. The iteration happens over the 'while' loop and not as I had assumed over the 'if' loop. A very important bit of learning for me!
                                          So to repeat, I apologize profusely and hope we are back on the same wavelength !
                                          alankilianundefined 1 Reply Last reply Reply Quote 3
                                            alankilian @jens55
                                            @jens55 Awesome!
                                            AND, you got me to try some new stuff using meta-commands, so everyone wins.
