    Meta commands
    Gcode meta commands
    2.0k
    • alankilianundefined
      alankilian @jens55
      @jens55 said in Meta commands:
      Thanks for that but I still don't quite understand. From what I understand (yeah, very little), the 'continue' statement does go back to the top like you said but the block that has the 'continue' statement is in the loop of 'if iteration < 10.' So in my thinking, if iterations gets to 10, that 'if' block fails and the next executed statement should be 'abort' .... ????
      You can take that 'continue' statement out completely and see that the macro runs just the same.
      Every time the interpreter gets to the end of the loop it will jump back to the top of the loop.
      So when the 'if' statement is not true, the interpreter does go to the next 'statement'. If there are no more statements in the loop, so it goes back to the top.
      This might be a better way to do the loop and make it more understandable to you.
      while iterations < 10
          m118 s"hello world"
          g4 s2
      Or this might make it even MORE clear (I tested this one!)
      m118 s"Starting the loop"
            m118 s"hello world"
            g4 s2
      m118 s"Done with the loop"
      8/12/2021, 2:27:26 PM 	Done with the loop
      8/12/2021, 2:27:24 PM 	hello world
      8/12/2021, 2:27:22 PM 	hello world
      8/12/2021, 2:27:20 PM 	hello world
      8/12/2021, 2:27:18 PM 	hello world
      8/12/2021, 2:27:16 PM 	hello world
      8/12/2021, 2:27:14 PM 	hello world
      8/12/2021, 2:27:12 PM 	hello world
      8/12/2021, 2:27:10 PM 	hello world
      8/12/2021, 2:27:08 PM 	hello world
      8/12/2021, 2:27:06 PM 	M98 P"0:/macros/000_test"
      Starting the loop
      hello world
      • jens55undefined
        jens55 @DanS79
        @dans79, agreed, that is the way I am used to program a loop and yes, nested loops will be a nightmare.
          alankilian @jens55
          Why?
          Each loop gets its own iterator (which is what iterators ARE) so everything works out.
          while iterations < 3
                m118 s"hello world first"
                  m118 s"hello world second"
                    m118 s"hello world third"
          8/12/2021, 2:57:50 PM 	M98 P"0:/macros/000_test"
          Starting the loop
          hello world first
          hello world second
          hello world third
          hello world third
          hello world third
          hello world second
          hello world third
          hello world third
          hello world third
          hello world second
          hello world third
          hello world third
          hello world third
          hello world first
          hello world second
          hello world third
          hello world third
          hello world third
          hello world second
          hello world third
          hello world third
          hello world third
          hello world second
          hello world third
          hello world third
          hello world third
          hello world first
          hello world second
          hello world third
          hello world third
          hello world third
          hello world second
          hello world third
          hello world third
          hello world third
          hello world second
          hello world third
          hello world third
          hello world third
          Done with the loop
          DanS79undefined 1 Reply Last reply Reply Quote 0
          • DanS79undefined
            DanS79 @alankilian
            @alankilian said in Meta commands:
            Why?
            They are all called iterations.
            If use want to use multiple of them to set a variable, the code would be very hard to read (assuming scoping even allows you to access all of them).
            The following would be real confusing to follow if you replaced a, b, and c with iterations .
            var x = 0
            var a = 0
            var b = 0
            var c = 0
            while a < 10
                set var.b = 0
                while b < 20
                    set var.c = 0
                    while c < 40
                        set var.x = (a * b) - c
                        set var.c = c + 1
                     set var.b = b + 1
                set var.a = a + 1
              alankilian @DanS79
              @dans79 Yeah, there are a thousand wrong ways to use a programming feature for every right way to use them.
              • jens55undefined
                jens55
                I think we are drifting away from the part that I am having problems with which is why the particular construct I was using was having issues. Yes, there is a way to change things but WHY is it needed.
                Here is a different way of going:
                This works:
                  m118 s{"hello world " ^ iterations}
                  g4 s2
                  continue
                This gives:
                Error: in file macro line 6 column 11: meta command: 'continue' was not inside a loop
                ;  m118 s{"hello world " ^ iterations}
                  g4 s2
                  continue
                The commented out line seems to dump the 'continue' statement outside of the loop and seems to me to be a bug in interpretation.
                alankilianundefined 2 Replies Last reply Reply Quote 0
                  alankilian @jens55
                  @jens55 You don't need to add a 'continue' statement at the end of a loop.
                    alankilian @jens55
                    You need to be very particular with the left-side whitespace to keep things working.
                    The interpreter is going to look at how many tab (or space)?) characters you have at the beginning of every line to know where the end of the loops are.
                    Your commented-out line starts with a semicolon in column one which tells the interperter that's the end of your while loop.
                    So, the 'continue' statement is not outside of the loop.
                    • jens55undefined
                      jens55 @alankilian
                      @alankilian, I realize that .... but what I am getting at is that something is fishy about how this is interpreted. While I don't need the 'continue', there should be nothing barring me from using it. It isn't inherently wrong.
                        alankilian @jens55
                        @jens55 That semicolon in column-1 causes the interpeter to end the while loop.
                        This works:
                          g4 s2
                          continue
                        • jens55undefined
                          jens55 @alankilian
                          @alankilian, I will test that but the semicolon is there to comment out the line and should not cause this reaction.
                            alankilian @jens55
                            @jens55 This works to keep the whitespace:
                              g4 s2
                              continue
                            • jens55undefined
                              jens55 @alankilian
                              @alankilian
                              Ahhhh, I need the spaces before the comment .... ok but that s a bug in the interpreter
                                alankilian @jens55
                                This post is deleted!
                                  alankilian @jens55
                                  From the documentation:
                                  The body ends just before the first line that is not indented.
                                  So, it could be argued that the interpreter is working fine.
                                  It's not up to me to decide.
                                  I'm happy you're getting going on your project again.
                                  And I learned some things from this discussion, so thank you for that also.
                                  • jens55undefined
                                    jens55
                                    Here is another example of strange behaviour:
                                    while true
                                      if iterations < 10
                                        m118 s"hello world"
                                        g4 s2
                                        continue
                                    break
                                    This executes but leaves the printer in a 'busy' state
                                    Without the 'break' command it does the same
                                    If I move the 'break' command to the right by two spaces, everything finishes ok - it breaks out of the loop
                                    Point is, there is no such thing as an 'endif' to clearly identify where the 'if' statement ends. IMHO there should be (optional maybe) an 'endif' for readability but in any case, the 'break' should break out of the loop no matter what.
                                    Edit: On re-reading this, there is a flaw in my thinking here, and unless the 'break' is indented two spaces over, the 'while' loop has no exit. Interesting note here is that the iteration variable apparently isn't reset until after exiting the 'while' loop because it only prints 'hello world' for one 'if' loop.
                                    That to me seems rather odd ....
                                    OwenDundefined 1 Reply Last reply Reply Quote 0
                                    • OwenDundefined
                                      OwenD @jens55
                                      @jens55
                                      Nothing strange about it.
                                      Using "while true" creates an infinite loop
                                      This is a dangerous practice for the uninitiated as you must ensure that at some point you have a conditional that triggers a break command.
                                      You have not done so. Therefore the loop continues.
                                      Once it gets to iteration 10 it just stops sending the echo.
                                      You should have put
                                      'if iterations < 10
                                           Echo "blah blah"
                                      else
                                            break
                                      Your continue command is useless as it's not part of the while construct.
                                      The point of continue is to skip an iteration.
                                      'if iterations < 10
                                           if iterations = 5
                                                  continue
                                           Echo "blah blah" ; won't happen on #5
                                      else
                                            break  ;  required to end loop
                                      It's safer to use
                                      blah blah
                                      EDIT
                                      Sorry. Doing this on my phone so I could not see your code
                                      Your BREK is outside the whole loop, but the comments stand
                                      jens55undefined 1 Reply Last reply Reply Quote 1
                                      • jens55undefined
                                        jens55
                                        Here is another thing that strikes me as odd:
                                        while true
                                          if iterations < 10
                                            m118 s"hello world"
                                            g4 s2
                                            continue
                                          if iterations < 11
                                            m118 s"hello north america"
                                        	g4 s2
                                        	continue
                                          break
                                        This code will execute the first 'if' for 10 times but will not reset 'iterations' as I would have expected and because of that will only execute the second 'if' loop once.
                                        • jens55undefined
                                          jens55 @OwenD
                                          @owend said in Meta commands:
                                          To skip an iteration ???? Where did you see this in the documentation ???
                                          I look at 'continue' as a command that strictly exists as a means to improve readability of the code since the command itself seems to do diddly squat and can be left out.
                                          alankilianundefined DanS79undefined 2 Replies Last reply Reply Quote 0
                                            alankilian @jens55
                                            'continue' jumps back to the BEGINNING of a loop.
                                            So if you have the following story: (COMPLETELY useless, but trying to illuminate how 'continue' is used)
                                              m118 s{"This is iteration " ^ iterations}
                                              if iterations > 5
                                                continue  ; Don't do this stuff after the first 5 iterations
                                              m118 s{"Perform this action on " ^ iterations}
                                            This is iteration 0
                                            Perform this action on 0
                                            This is iteration 1
                                            Perform this action on 1
                                            This is iteration 2
                                            Perform this action on 2
                                            This is iteration 3
                                            Perform this action on 3
                                            This is iteration 4
                                            Perform this action on 4
                                            This is iteration 5
                                            Perform this action on 5
                                            This is iteration 6
                                            This is iteration 7
                                            This is iteration 8
                                            This is iteration 9
