    Mini5+ BT dongle for transmit.
    Using Duet Controllers
    800
    • tecnoundefined
      tecno @fcwilt
      @fcwilt
      Hmmm how can one trigger Android phone camera via Telnet using OPen Camera app ?
      • fcwiltundefined
        fcwilt @tecno
        @tecno said in Go / No go? Mini5+ BT dongle for transmit.:
        @fcwilt
        I have no idea.
        I just mentioned that it is a way to get data from the printer to a program running on some device on the same network.
        In my case the program is running on a Windows machine which is up 24/7. The program receives messages from the printer and turns them into email messages to me.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @fcwilt
          Waking up this question I have.
          Mini5+ IO1 out
          To
          Sony Experia
          Can somebody help me out to get this combo working, so I can get filming slowmotion of my prints.
          I prefere this way = no cable = easier to place camera as I want
          • tecnoundefined
            tecno @tecno
            Is this possible to drive from IO_1 on Mini5+ ?
            • tecnoundefined
              tecno @tecno
              Is this OK?
              • alankilianundefined
                alankilian @tecno
                @tecno said in Mini5+ BT dongle for transmit.:
                Is this OK?
                If it is not, would you be willing to hook up a hobby servo and have it physically push the button under command of the Duet?
                • oliofundefined
                  oliof
                  @alankilian or, if a servo is undesirable, trigger the button mechanically, as exemplified in https://youtu.be/NgZZzi6sRDU
                  • tecnoundefined
                    tecno @oliof
                    @oliof @alankilian
                    Neither solution is desirable.
                      alankilian @tecno
                      @tecno OK, do you know that the momentary switch is normally-open and then closes to ground when you press the button?
                      Can you try jumpering with a wire from the switch to ground on the PCB to verify it triggers?
                      If that's true I think your schematic will work fine.
                      • tecnoundefined
                        tecno @alankilian
                        @alankilian
                        Yes it works that way. As I do not want to blow up IO_1, so do I need any protection? I do not think so but better ask twice 🙂
                          alankilian @tecno
                          @tecno
                          I would put a series resistor inline.
                          Maybe 100 Ohms to 1,000 Ohms and try it.
                          That will help protect the Duet.
                          I don't think you need any kind of flyback diode for this.
                          • tecnoundefined
                            tecno @alankilian
                            Hi guys,
                            This does not work, 3.3V is not present on IO_1 pin 3.3V_ext. Obviously I have understood this wrong.
                            So where can I borrow 3.3V? TEMP is occupied, External drivers pin6 ?
                            • tecnoundefined
                              tecno @tecno
                              Hi guys,
                              Anybody??
                              tecnoundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                              • tecnoundefined
                                tecno @tecno
                                Problem solved, pin6 on External Drivers for 3.3V
                                Now some codeing to get this working.
                                  droftarts administrators @tecno
                                  Do you have 3.3V on your other IO ports? If so, check the soldering on the 3.3V pin of IO_1. 3.3V_EXT is supplied direct to all of these pins and the PanelDue port. It looks like you're not using any of the 3.3V on the other IO connectors currently.
                                  If not, check U10 (by the TEMP_DB connector) and associated components, which is the 3.3V regulator that supplies 3.3V_EXT.
                                  Schematic: https://raw.githubusercontent.com/Duet3D/Duet3-Mini5plus/main/v1.01/Duet3_5%2B_Wifi_schematic_v1.01.pdf
