    Mini5+ BT dongle for transmit.
    Using Duet Controllers
    807
    • tecnoundefined
      tecno @fcwilt
      Waking up this question I have.
      Mini5+ IO1 out
      To
      Sony Experia
      Can somebody help me out to get this combo working, so I can get filming slowmotion of my prints.
      I prefere this way = no cable = easier to place camera as I want
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @tecno
        Is this possible to drive from IO_1 on Mini5+ ?
        • tecnoundefined
          tecno @tecno
          Is this OK?
          • alankilianundefined
            alankilian @tecno
            @tecno said in Mini5+ BT dongle for transmit.:
            Is this OK?
            If it is not, would you be willing to hook up a hobby servo and have it physically push the button under command of the Duet?
            • oliofundefined
              oliof
              @alankilian or, if a servo is undesirable, trigger the button mechanically, as exemplified in https://youtu.be/NgZZzi6sRDU
              • tecnoundefined
                tecno @oliof
                @oliof @alankilian
                Neither solution is desirable.
                  alankilian @tecno
                  @tecno OK, do you know that the momentary switch is normally-open and then closes to ground when you press the button?
                  Can you try jumpering with a wire from the switch to ground on the PCB to verify it triggers?
                  If that's true I think your schematic will work fine.
                  • tecnoundefined
                    tecno @alankilian
                    @alankilian
                    Yes it works that way. As I do not want to blow up IO_1, so do I need any protection? I do not think so but better ask twice 🙂
                      alankilian @tecno
                      @tecno
                      I would put a series resistor inline.
                      Maybe 100 Ohms to 1,000 Ohms and try it.
                      That will help protect the Duet.
                      I don't think you need any kind of flyback diode for this.
                      • tecnoundefined
                        tecno @alankilian
                        Hi guys,
                        This does not work, 3.3V is not present on IO_1 pin 3.3V_ext. Obviously I have understood this wrong.
                        So where can I borrow 3.3V? TEMP is occupied, External drivers pin6 ?
                        • tecnoundefined
                          tecno @tecno
                          Hi guys,
                          Anybody??
                          tecnoundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                          • tecnoundefined
                            tecno @tecno
                            Problem solved, pin6 on External Drivers for 3.3V
                            Now some codeing to get this working.
                              droftarts administrators @tecno
                              Do you have 3.3V on your other IO ports? If so, check the soldering on the 3.3V pin of IO_1. 3.3V_EXT is supplied direct to all of these pins and the PanelDue port. It looks like you're not using any of the 3.3V on the other IO connectors currently.
                              If not, check U10 (by the TEMP_DB connector) and associated components, which is the 3.3V regulator that supplies 3.3V_EXT.
                              Schematic: https://raw.githubusercontent.com/Duet3D/Duet3-Mini5plus/main/v1.01/Duet3_5%2B_Wifi_schematic_v1.01.pdf
