    Tool Board Heater Tuning Leading To Faults
    101
    5.4k
    • KevinMarundefined
      KevinMar @dc42
      @dc42 Confirmed, it is using the parameters that I found from tuning
      • fcwiltundefined
        fcwilt @KevinMar
        @kevinmar said in Tool Board Heater Tuning Leading To Faults:
        The Hemera's have an overpowered part cooling fan, so I'm tuning using M303 T0 A30 F.40 S220
        The tuning runs fine, but when I paste the parameters into config.g, the resulting heater activation inevitably results in a fault before the tool reaches 120C, usually around 70-100C
        Is the ambient temp really 30?
        And what fault are you getting?
        KevinMarundefined 1 Reply Last reply Reply Quote 0
        • DIY-O-Sphereundefined
          DIY-O-Sphere @KevinMar
          @kevinmar
          Do you still have old parameters in the config-override.g?
          But after you have checked the heater in the console it should actually fit.
          (UTC+1)
          • KevinMarundefined
            KevinMar @fcwilt
            @fcwilt Ambient is 26-30C
            I am not getting a fault readout in the console
            • KevinMarundefined
              KevinMar @DIY-O-Sphere
              @diy-o-sphere No, old parameters are overwritten when a new set is generated and saved using M500
              • fcwiltundefined
                fcwilt @KevinMar
                Wow. I gather it is hot were you live and you have no air conditioning?
                You posted this where you said there was a fault.
                • KevinMarundefined
                  KevinMar
                  I think it's faulting way too liberally. My heater and PT1000 are working, it's not like I'm experiencing thermal runaway.
                  Is there a way to change the sensitivity of the faults?
                  • fcwiltundefined
                    fcwilt @KevinMar
                    What fault are you getting?
                    • KevinMarundefined
                      KevinMar @fcwilt
                      @fcwilt Well, true ambient is about 24C, but the PT1000's always read about 27C as ambient.
                      The heater faults, but there is no readout in the console.
                      • fcwiltundefined
                        fcwilt @KevinMar
                        In what way does the heater fault?
                        • KevinMarundefined
                          KevinMar @fcwilt
                          @fcwilt I wish I knew!
                          • fcwiltundefined
                            fcwilt @KevinMar
                            What is happening that is evidence of a fault?
                            • KevinMarundefined
                              KevinMar @fcwilt
                              DIY-O-Sphereundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                @kevinmar
                                Please post the config.g
                                (UTC+1)
                                • KevinMarundefined
                                  @diy-o-sphere config (1).g
                                  DIY-O-Sphereundefined fcwiltundefined dc42undefined 3 Replies Last reply Reply Quote 0
                                  • fcwiltundefined
                                    fcwilt @KevinMar
                                    OK that helps.
                                    All all three heaters actually active at the same time?
                                    Do they all fault at the same time?
                                    Can you take a screen shot of the temp graph showing the heaters as they heat up and then fault?
                                      @kevinmar
                                      Your sensor settings a looking wrong...
                                      Here is an example of mine
                                      M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
                                      (UTC+1)
                                      KevinMarundefined 1 Reply Last reply Reply Quote 1
                                      • fcwiltundefined
                                        fcwilt @KevinMar
                                        @kevinmar
                                        Please get in the habit of copy-and-pasting your files using the </> tag.
                                        M550 P"ToolChanger" 					; Set machine name
                                        M111 S0                              	; Debug off
                                        M929 P"eventlog.txt" S1					; Start logging to file eventlog.txt
                                        M555 P1									; Set RepRap output
                                        G21										; Set dimensions to millimetres
                                        G90										; Send absolute coordinates...
                                        M83										; ...but relative extruder moves
                                        M669 K1									; CoreXY mode
                                        G4 S1  									; Wait for expansion boards to start
                                        M569 P0.0 S1 D2							; Drive 0 direction | X
                                        M569 P0.1 S1 D2							; Drive 1 direction | Y
                                        M569 P0.2 S1 D2							; Drive 2 direction | Z
                                        M569 P0.4 S0 D2							; Drive 3 direction | C
                                        M569 P0.5 S0 D2							; Drive 5 direction | A
                                        M569 P20.0 S0 D2						; Drive 6 direction | T0
                                        M569 P21.0 S0 D2						; Drive 7 direction | T1
                                        M569 P22.0 S0 D2						; Drive 8 direction | T2
                                        M569 P23.0 S0 D2						; Drive 9 direction | T3
                                        M584 X0 Y1 Z2 E20.0:21.0:22.0:23.0 C4 A5					; Axis to driver mapping
                                        ; Set axis software limits and min/max switch-triggering positions.
                                        M208 X-35:320 Y-49:240 Z0:300 C-45:360 A0:55
                                        M350 X16 Y16 Z16 E16:16:16:16 A16 I1						; Configure microstepping with interpolation
                                        M350 C16 I10												; Configure microstepping without interpolation
                                        M906 X1800 Y1800 Z1000 I30									; Set motor currents (mA) and idle percent
                                        M906 E1500:1500:1500:1500 C500  I10							; Set motor currents (mA) and idle percent A400
                                        M203 X36000 Y36000 Z1200 C5000 E6000:6000:6000:6000 A6000	;Max speeds (mm/min)
                                        M201 X6000 Y6000 Z400 C600 E6000:6000:6000:6000 A1200		; Max Accelerations (mm/s^2)
                                        M566 X400 Y400 Z60 C6 E60:60:60:60 A360						; Max jerk (mm/min)
                                        M92 X100 Y100 Z800 E386:386:386:386 C91.022 A360			; Steps/mm
                                        M574 X1 Y1 S3									; X / Y Endstop
                                        M574 Z1 S1 P"nil"								; Z Endstop
                                        M574 C0											; Z / C No Endstop
                                        M558 P5 C"!io0.in" H5 A5 T6000 S0.01 K0
                                        G31 P200 X0 Y0 Z0
                                        M557 X10:290 Y20:180 S40						; Define mesh grid
                                        M915 X Y S3 F0 H400 R2							; X / Y Axes
                                        M915 A S5 F0 H200 R2							; A Stall Detection
                                        ; Temperature sensors
                                        M308 S0 P"0.temp0" Y"thermistor" T100000 B4138 C0 A"Bed"
                                        M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Ex0"
                                        M308 S2 P"21.temp0" Y"pt1000" T100000 B4725 C7.06e-8 A"Ex1"
                                        M308 S3 P"22.temp0" Y"pt1000" T100000 B4725 C7.06e-8 A"Ex2"
                                        M308 S4 P"23.temp0" Y"pt1000" T100000 B4725 C7.06e-8 A"Ex3"
                                        M950 H0 C"0.out1" T0						; Bed
                                        M140 H0										; Bed
                                        M950 H1 C"20.out0" T1						; Heater for extruder out tool 0
                                        M950 H2 C"21.out0" T2						; Heater for extruder out tool 1
                                        M950 H3 C"22.out0" T3						; Heater for extruder out tool 2
                                        M950 H4 C"23.out0" T4						; Heater for extruder out tool 3
                                        ; Heater PID Tuning
                                        M307 H0 R1.641 C353.300:353.300 D2.50 S1.00 V24.0 B0
                                        M307 H1 R1.590 C336.700:89.600 D5.00 S1.00 V23.8 B0
                                        M307 H2 R2.135 C314.200:86.000 D6.20 S1.00 V24.3 B0
                                        M307 H3 R2.023 C364.200:86.200 D5.70 S1.00 V23.7 B0
                                        M307 H4 R1.900 C383.000:383.000 D7.50 S1.00 V23.8 B0
                                        ;M307 H1 A849.7 C225.4 D5.9 S1.00 V24.2 B0  ; From Railcore with similar setup running V2.xx
                                        ; Max Temps
                                        M143 H0 S225
                                        M143 H1 S300
                                        M143 H2 S300
                                        M143 H3 S300
                                        M143 H4 S300
                                        ; Fans for hot end cooling
                                        M950 F10 C"20.out2"
                                        M106 P10 S255 H1 T70
                                        M950 F11 C"21.out2"
                                        M106 P11 S255 H2 T70
                                        M950 F12 C"22.out2"
                                        M106 P12 S255 H3 T70
                                        M950 F13 C"23.out2"
                                        M106 P13 S255 H4 T70
                                        ; Fans for part cooling
                                        M950 F0 C"20.out1"
                                        M950 F1 C"21.out1"
                                        M950 F2 C"22.out1"
                                        M950 F3 C"23.out1"
                                        M950 F7 C"^0.out9" Q600					;Wipe Servo
                                        M106 P7 C"Wipe" 						;Wipe Servo
                                        M302 S185 R185
                                        M404 N1.75 D0.4
                                        ; Tool definitions
                                        M563 P0 S"Tool0" D0 H1 F0
                                        G10  P0 S220 R205
                                        M563 P1 S"Tool1" D1 H2 F1
                                        G10  P1 S220 R205
                                        M563 P2 S"Tool2" D2 H3 F2
                                        G10  P2 S220 R205
                                        M563 P3 S"Tool3" D3 H4 F3
                                        G10  P3 S220 R205
                                        G29 S2
                                        M98  P"/sys/Toffsets.g"					; Set tool offsets from the bed
                                        T-1
                                        M501									; Load config-override.g
                                        DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
                                        • KevinMarundefined
                                          @diy-o-sphere Huh, yeah that ain't right
                                            dc42 administrators @KevinMar
                                            @kevinmar if you are running without a silicone sock on the heater block, please add a silicone sock and re-tune. Your M307 parameters suggest that the fan substantially cools the hot end, which typically means that the fan is blowing on the heater block.
                                            Also please confirm that the part cooling fan is off when you command heating and the heater faults
                                            If after re-tuning with the silicone sock on (if necessary) the heaters still fault, you can try reducing the M307 R parameter. Try a 30% reduction.
