    Tool Board Heater Tuning Leading To Faults
    101
    5.5k
    • fcwiltundefined
      fcwilt @KevinMar
      @kevinmar said in Tool Board Heater Tuning Leading To Faults:
      @fcwilt Well, true ambient is about 24C, but the PT1000's always read about 27C as ambient.
      The heater faults, but there is no readout in the console.
      In what way does the heater fault?
      • KevinMarundefined
        KevinMar @fcwilt
        @fcwilt I wish I knew!
        • fcwiltundefined
          fcwilt @KevinMar
          What is happening that is evidence of a fault?
          KevinMarundefined 1 Reply Last reply Reply Quote 0
          • KevinMarundefined
            KevinMar @fcwilt
            DIY-O-Sphereundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
            • DIY-O-Sphereundefined
              DIY-O-Sphere @KevinMar
              @kevinmar
              Please post the config.g
              (UTC+1)
              • KevinMarundefined
                KevinMar @DIY-O-Sphere
                @diy-o-sphere config (1).g
                DIY-O-Sphereundefined fcwiltundefined dc42undefined 3 Replies Last reply Reply Quote 0
                • fcwiltundefined
                  fcwilt @KevinMar
                  OK that helps.
                  All all three heaters actually active at the same time?
                  Do they all fault at the same time?
                  Can you take a screen shot of the temp graph showing the heaters as they heat up and then fault?
                    @kevinmar
                    Your sensor settings a looking wrong...
                    Here is an example of mine
                    M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
                    (UTC+1)
                    KevinMarundefined 1 Reply Last reply Reply Quote 1
                    • fcwiltundefined
                      fcwilt @KevinMar
                      @kevinmar
                      Please get in the habit of copy-and-pasting your files using the </> tag.
                      M550 P"ToolChanger" 					; Set machine name
                      M111 S0                              	; Debug off
                      M929 P"eventlog.txt" S1					; Start logging to file eventlog.txt
                      M555 P1									; Set RepRap output
                      G21										; Set dimensions to millimetres
                      G90										; Send absolute coordinates...
                      M83										; ...but relative extruder moves
                      M669 K1									; CoreXY mode
                      G4 S1  									; Wait for expansion boards to start
                      M569 P0.0 S1 D2							; Drive 0 direction | X
                      M569 P0.1 S1 D2							; Drive 1 direction | Y
                      M569 P0.2 S1 D2							; Drive 2 direction | Z
                      M569 P0.4 S0 D2							; Drive 3 direction | C
                      M569 P0.5 S0 D2							; Drive 5 direction | A
                      M569 P20.0 S0 D2						; Drive 6 direction | T0
                      M569 P21.0 S0 D2						; Drive 7 direction | T1
                      M569 P22.0 S0 D2						; Drive 8 direction | T2
                      M569 P23.0 S0 D2						; Drive 9 direction | T3
                      M584 X0 Y1 Z2 E20.0:21.0:22.0:23.0 C4 A5					; Axis to driver mapping
                      ; Set axis software limits and min/max switch-triggering positions.
                      M208 X-35:320 Y-49:240 Z0:300 C-45:360 A0:55
                      M350 X16 Y16 Z16 E16:16:16:16 A16 I1						; Configure microstepping with interpolation
                      M350 C16 I10												; Configure microstepping without interpolation
                      M906 X1800 Y1800 Z1000 I30									; Set motor currents (mA) and idle percent
                      M906 E1500:1500:1500:1500 C500  I10							; Set motor currents (mA) and idle percent A400
                      M203 X36000 Y36000 Z1200 C5000 E6000:6000:6000:6000 A6000	;Max speeds (mm/min)
                      M201 X6000 Y6000 Z400 C600 E6000:6000:6000:6000 A1200		; Max Accelerations (mm/s^2)
                      M566 X400 Y400 Z60 C6 E60:60:60:60 A360						; Max jerk (mm/min)
                      M92 X100 Y100 Z800 E386:386:386:386 C91.022 A360			; Steps/mm
                      M574 X1 Y1 S3									; X / Y Endstop
                      M574 Z1 S1 P"nil"								; Z Endstop
                      M574 C0											; Z / C No Endstop
                      M558 P5 C"!io0.in" H5 A5 T6000 S0.01 K0
                      G31 P200 X0 Y0 Z0
                      M557 X10:290 Y20:180 S40						; Define mesh grid
                      M915 X Y S3 F0 H400 R2							; X / Y Axes
                      M915 A S5 F0 H200 R2							; A Stall Detection
                      ; Temperature sensors
                      M308 S0 P"0.temp0" Y"thermistor" T100000 B4138 C0 A"Bed"
                      M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Ex0"
                      M308 S2 P"21.temp0" Y"pt1000" T100000 B4725 C7.06e-8 A"Ex1"
                      M308 S3 P"22.temp0" Y"pt1000" T100000 B4725 C7.06e-8 A"Ex2"
                      M308 S4 P"23.temp0" Y"pt1000" T100000 B4725 C7.06e-8 A"Ex3"
                      M950 H0 C"0.out1" T0						; Bed
                      M140 H0										; Bed
                      M950 H1 C"20.out0" T1						; Heater for extruder out tool 0
                      M950 H2 C"21.out0" T2						; Heater for extruder out tool 1
                      M950 H3 C"22.out0" T3						; Heater for extruder out tool 2
                      M950 H4 C"23.out0" T4						; Heater for extruder out tool 3
                      ; Heater PID Tuning
                      M307 H0 R1.641 C353.300:353.300 D2.50 S1.00 V24.0 B0
                      M307 H1 R1.590 C336.700:89.600 D5.00 S1.00 V23.8 B0
                      M307 H2 R2.135 C314.200:86.000 D6.20 S1.00 V24.3 B0
                      M307 H3 R2.023 C364.200:86.200 D5.70 S1.00 V23.7 B0
                      M307 H4 R1.900 C383.000:383.000 D7.50 S1.00 V23.8 B0
                      ;M307 H1 A849.7 C225.4 D5.9 S1.00 V24.2 B0  ; From Railcore with similar setup running V2.xx
                      ; Max Temps
                      M143 H0 S225
                      M143 H1 S300
                      M143 H2 S300
                      M143 H3 S300
                      M143 H4 S300
                      ; Fans for hot end cooling
                      M950 F10 C"20.out2"
                      M106 P10 S255 H1 T70
                      M950 F11 C"21.out2"
                      M106 P11 S255 H2 T70
                      M950 F12 C"22.out2"
                      M106 P12 S255 H3 T70
                      M950 F13 C"23.out2"
                      M106 P13 S255 H4 T70
                      ; Fans for part cooling
                      M950 F0 C"20.out1"
                      M950 F1 C"21.out1"
                      M950 F2 C"22.out1"
                      M950 F3 C"23.out1"
                      M950 F7 C"^0.out9" Q600					;Wipe Servo
                      M106 P7 C"Wipe" 						;Wipe Servo
                      M302 S185 R185
                      M404 N1.75 D0.4
                      ; Tool definitions
                      M563 P0 S"Tool0" D0 H1 F0
                      G10  P0 S220 R205
                      M563 P1 S"Tool1" D1 H2 F1
                      G10  P1 S220 R205
                      M563 P2 S"Tool2" D2 H3 F2
                      G10  P2 S220 R205
                      M563 P3 S"Tool3" D3 H4 F3
                      G10  P3 S220 R205
                      G29 S2
                      M98  P"/sys/Toffsets.g"					; Set tool offsets from the bed
                      T-1
                      M501									; Load config-override.g
                      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
                      • KevinMarundefined
                        @diy-o-sphere Huh, yeah that ain't right
                          dc42 administrators @KevinMar
                          @kevinmar if you are running without a silicone sock on the heater block, please add a silicone sock and re-tune. Your M307 parameters suggest that the fan substantially cools the hot end, which typically means that the fan is blowing on the heater block.
                          Also please confirm that the part cooling fan is off when you command heating and the heater faults
                          If after re-tuning with the silicone sock on (if necessary) the heaters still fault, you can try reducing the M307 R parameter. Try a 30% reduction.
                          • Dougal1957undefined
                            Dougal1957
                            Not sure if these lines are wrong or not for one you have the T B C and A params not sure if they are needed or correct for a PT1000
                            • fcwiltundefined
                              fcwilt @KevinMar
                              You are loading config-override.g at the end of config.g
                              Please post that file.
                              • fcwiltundefined
                                fcwilt @Dougal1957
                                @dougal1957 said in Tool Board Heater Tuning Leading To Faults:
                                From the docs:
                                Additional parameters for PT1000 sensors
                                Rnnn Series resistor value. Leave blank to use the default for your board.
                                Lnnn ADC low offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)
                                Hnnn ADC high offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)
                                Dougal1957undefined KevinMarundefined 2 Replies Last reply Reply Quote 0
                                  Dougal1957 @fcwilt
                                  @fcwilt said in Tool Board Heater Tuning Leading To Faults:
                                  From the docs:
                                  yes but the T100000 is for a ntc100k thermistor should not be required for a pt1000 nor a beta value as they are linear and don't have a c param either so not sure if having those params are confusing the issue
                                  • KevinMarundefined
                                    KevinMar @fcwilt
                                    @fcwilt s
                                    So Lnnn can offset the higher ambient reading?
                                    • KevinMarundefined
                                      KevinMar @fcwilt
                                      @fcwilt I'm currently re-running the autotuning with the removed T, B, and C values from the config
                                      Dougal1957undefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 1
                                        Dougal1957 @KevinMar
                                        Good luck Kevin
                                        Doug
                                          @kevinmar
                                          Put in the R value
                                          (UTC+1)
                                          • fcwiltundefined
                                            fcwilt @Dougal1957
                                            I was trying to point out that R, L and N are the only additional parameters for PT1000 devices.
                                            The B,C and T are clearly incorrect but are the affecting the heater or are they ignored since they don't apply?
                                            I don't know.
