    Tool Board Heater Tuning Leading To Faults
    101
    5.6k
    • KevinMarundefined
      KevinMar @DIY-O-Sphere
      @diy-o-sphere Huh, yeah that ain't right
        dc42 administrators @KevinMar
        @kevinmar if you are running without a silicone sock on the heater block, please add a silicone sock and re-tune. Your M307 parameters suggest that the fan substantially cools the hot end, which typically means that the fan is blowing on the heater block.
        Also please confirm that the part cooling fan is off when you command heating and the heater faults
        If after re-tuning with the silicone sock on (if necessary) the heaters still fault, you can try reducing the M307 R parameter. Try a 30% reduction.
        KevinMarundefined 1 Reply Last reply Reply Quote 1
        • Dougal1957undefined
          Dougal1957
          M308 S2 P"21.temp0" Y"pt1000" T100000 B4725 C7.06e-8 A"Ex1"
          M308 S3 P"22.temp0" Y"pt1000" T100000 B4725 C7.06e-8 A"Ex2"
          M308 S4 P"23.temp0" Y"pt1000" T100000 B4725 C7.06e-8 A"Ex3"
          Not sure if these lines are wrong or not for one you have the T B C and A params not sure if they are needed or correct for a PT1000
          • fcwiltundefined
            fcwilt @KevinMar
            @kevinmar said in Tool Board Heater Tuning Leading To Faults:
            You are loading config-override.g at the end of config.g
            Please post that file.
            KevinMarundefined 1 Reply Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @Dougal1957
              @dougal1957 said in Tool Board Heater Tuning Leading To Faults:
              From the docs:
              Additional parameters for PT1000 sensors
              Rnnn Series resistor value. Leave blank to use the default for your board.
              Lnnn ADC low offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)
              Hnnn ADC high offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)
              Dougal1957undefined KevinMarundefined 2 Replies Last reply Reply Quote 0
                Dougal1957 @fcwilt
                @fcwilt said in Tool Board Heater Tuning Leading To Faults:
                From the docs:
                yes but the T100000 is for a ntc100k thermistor should not be required for a pt1000 nor a beta value as they are linear and don't have a c param either so not sure if having those params are confusing the issue
                • KevinMarundefined
                  KevinMar @fcwilt
                  @fcwilt s
                  So Lnnn can offset the higher ambient reading?
                  • KevinMarundefined
                    KevinMar @fcwilt
                    @fcwilt I'm currently re-running the autotuning with the removed T, B, and C values from the config
                    Dougal1957undefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 1
                      Dougal1957 @KevinMar
                      Good luck Kevin
                      Doug
                      • DIY-O-Sphereundefined
                        DIY-O-Sphere @KevinMar
                        @kevinmar
                        Put in the R value
                        (UTC+1)
                        • fcwiltundefined
                          fcwilt @Dougal1957
                          I was trying to point out that R, L and N are the only additional parameters for PT1000 devices.
                          The B,C and T are clearly incorrect but are the affecting the heater or are they ignored since they don't apply?
                          I don't know.
                            Dougal1957 @DIY-O-Sphere
                            @diy-o-sphere said in Tool Board Heater Tuning Leading To Faults:
                            @kevinmar
                            Put in the R value
                            doesn't need it as it will default correctly
                              Dougal1957 @fcwilt
                              I don't know.
                              I agree neither do I know but it has to be worth a try
                              • fcwiltundefined
                                fcwilt @KevinMar
                                @fcwilt s
                                I have no idea. Never used PT1000 devices.
                                And how does one know if the hardware supports automatic ADC gain and offset calibration?
                                Again I have no idea but I suspect @dc42 would.
                                  Dougal1957 @fcwilt
                                  @fcwilt I do use PT1000 and 100's as well and do prefer them and don't have any need for the additional Params as yet but we will see Hopefully Kevin gets it all sorted
                                  • fcwiltundefined
                                    fcwilt @Dougal1957
                                    Do those devices require additional hardware to connect to a Duet board?
                                    Dougal1957undefined KevinMarundefined DIY-O-Sphereundefined 3 Replies Last reply Reply Quote 0
                                      Dougal1957 @fcwilt
                                      pt1000 no but the pt100 does need the daughter board
                                      • KevinMarundefined
                                        KevinMar @fcwilt
                                        This post is deleted!
                                          DIY-O-Sphere @fcwilt
                                          @fcwilt
                                          Not required for PT1000 on Duet3 and Maestro
                                          (UTC+1)
                                          Dougal1957undefined 1 Reply Last reply Reply Quote 1
                                            @fcwilt
                                            nor on a wifi/ethernet duet 2 board either just not quite as accurate due to the 4k7 sense resistor rather than the 2k2 one
