    Tool Board Heater Tuning Leading To Faults
    101
    5.2k
    • KevinMarundefined
      KevinMar @fcwilt
      @fcwilt s
      Rnnn Series resistor value. Leave blank to use the default for your board.
      Lnnn ADC low offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)
      Hnnn ADC high offset correction, default 0 (ignored if the hardware supports automatic ADC gain and offset calibration)
      So Lnnn can offset the higher ambient reading?
      • KevinMarundefined
        KevinMar @fcwilt
        @fcwilt I'm currently re-running the autotuning with the removed T, B, and C values from the config
        Dougal1957undefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 1
        • Dougal1957undefined
          Dougal1957 @KevinMar
          @kevinmar said in Tool Board Heater Tuning Leading To Faults:
          Good luck Kevin
          Doug
          KevinMarundefined 1 Reply Last reply Reply Quote 0
          • DIY-O-Sphereundefined
            DIY-O-Sphere @KevinMar
            @kevinmar
            Put in the R value
            (UTC+1)
            • fcwiltundefined
              fcwilt @Dougal1957
              @dougal1957 said in Tool Board Heater Tuning Leading To Faults:
              yes but the T100000 is for a ntc100k thermistor should not be required for a pt1000 nor a beta value as they are linear and don't have a c param either so not sure if having those params are confusing the issue
              I was trying to point out that R, L and N are the only additional parameters for PT1000 devices.
              The B,C and T are clearly incorrect but are the affecting the heater or are they ignored since they don't apply?
              I don't know.
                Dougal1957 @DIY-O-Sphere
                @diy-o-sphere said in Tool Board Heater Tuning Leading To Faults:
                @kevinmar
                Put in the R value
                doesn't need it as it will default correctly
                  Dougal1957 @fcwilt
                  @fcwilt said in Tool Board Heater Tuning Leading To Faults:
                  I don't know.
                  I agree neither do I know but it has to be worth a try
                  • fcwiltundefined
                    fcwilt @KevinMar
                    @fcwilt s
                    I have no idea. Never used PT1000 devices.
                    And how does one know if the hardware supports automatic ADC gain and offset calibration?
                    Again I have no idea but I suspect @dc42 would.
                      Dougal1957 @fcwilt
                      @fcwilt I do use PT1000 and 100's as well and do prefer them and don't have any need for the additional Params as yet but we will see Hopefully Kevin gets it all sorted
                      • fcwiltundefined
                        fcwilt @Dougal1957
                        Do those devices require additional hardware to connect to a Duet board?
                        Dougal1957undefined KevinMarundefined DIY-O-Sphereundefined 3 Replies Last reply Reply Quote 0
                          Dougal1957 @fcwilt
                          pt1000 no but the pt100 does need the daughter board
                          • KevinMarundefined
                            KevinMar @fcwilt
                            This post is deleted!
                              DIY-O-Sphere @fcwilt
                              @fcwilt
                              Not required for PT1000 on Duet3 and Maestro
                              (UTC+1)
                              Dougal1957undefined 1 Reply Last reply Reply Quote 1
                                @fcwilt
                                nor on a wifi/ethernet duet 2 board either just not quite as accurate due to the 4k7 sense resistor rather than the 2k2 one
                                • KevinMarundefined
                                  KevinMar @Dougal1957
                                  @dougal1957
                                  New parameters: M307 H2 R2.050 C309.100:130.600 D6.20 S1.00 V24.3 B0
                                  Another fault:
                                  (I had been using the fan to cool the hotend down, so ignore values before 11:00)
                                  • fcwiltundefined
                                    fcwilt @KevinMar
                                    @dougal1957
                                    Another fault:
                                    Did you check your config-override.g file to see if it included M307 commands?
                                    • KevinMarundefined
                                      KevinMar @fcwilt
                                      @fcwilt it included M307 commands that were generated from the autotuning and saved using M500
                                      • fcwiltundefined
                                        fcwilt @KevinMar
                                        So we can ignore the ones in your config.g file?
                                        • KevinMarundefined
                                          KevinMar @fcwilt
                                          @fcwilt They're identical
                                          • fcwiltundefined
                                            fcwilt @KevinMar
                                            So you copied the lines from the config-override.g file and put them into your config.g file?
                                            I assume you re-booted.
