    How to obtain Microstepping
    538
      dc42 administrators @muhac80
      @muhac80 for microstepping it's normally best to leave it set to x16 with interpolation on. Exception: if your extruder is ungeared, it will have a low steps per mm (usually less than 100), and you may get better print quality if you use x64 microstepping on the extruder motor.
      muhac80undefined 1 Reply Last reply Reply Quote 0
      • muhac80undefined
        muhac80 @jay_s_uk
        @jay_s_uk Thank you for the reply. My printer is not one of the known or over-the-counter printers that I can copy the parameters from. It is a custom made cartesian printer that is why I am little bit lost obtaining these parameters. Do you need any specific information about the printer to generate these motor values. Please advise.
        • muhac80undefined
          muhac80 @dc42
          @dc42 said in How to obtain Microstepping:
          interpolation
          Thank you for the reply; I looked at the description of the extruder again. It is indicating that it has internal gear ratio of 3:1 if this is what you are reffering;
          SIMAX3D Dual Drive BMG Bowden Extruder utilizes an internal gearing ratio of 3:1 together with precision
          cnc-machined hardened steel drive gears to give you a compact powerhouse for all your applications.
          https://www.amazon.ca/gp/product/B085BLQSYV/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&th=1
          Would it make sense to leave all the values as it appears in the pic I sent, up in my first message, and then tune it later based on its performance (other than the current value obviously). Please advise.
          • PaulHewundefined
            PaulHew
            What are you currently using as a control board?
            Do you have a working config that you can extract info from?
            • muhac80undefined
              muhac80 @PaulHew
              @paulhew Duet 2 wifi is my board and I don't have any current config. Building this printer from scratch. Thank you.
                deckingman @muhac80
                @muhac80 said in How to obtain Microstepping:
                interpolation
                The steps per mm and 16X micro-stepping will be fine for a BMG style extruder and a normal (non-mixing) hot end. The speeds and accelerations look very low for all axes but you haven't provided any details about the moving mass or the motors which are driving it so it's impossible to advise. For the extruder, I use 3600 mm/min jerk (60 mm/sec), 9000 maximum speed (150mm/sec) and 6000 mm/sec^2 acceleration. Suggest you use something similar because the values you've chosen will slow the print down.
                Be aware that the term "steps per mm" is always a misnomer and should really be "micro-steps per mm". So if you elected to use (say) 32x micro stepping for the extruder, then the steps per mm would need to change from 420 to 840.
                Phaedruxundefined muhac80undefined 3 Replies Last reply Reply Quote 1
                  Phaedrux Moderator @deckingman
                  @deckingman said in How to obtain Microstepping:
                  Perhaps step-pulses-per-mm would be most accurate of all?
                    deckingman @Phaedrux
                    @phaedrux said in How to obtain Microstepping:
                    Maybe. But then some pedant or other will likely point out driver chip interpolation will further sub divide the micro step pulses into smaller pulses so maybe we have to say "pre-interpolated-step-pulses-per-mm" 🙂
                    But that becomes difficult to remember. What we need is a mnemonic. How about Pre Interpolated Step Setting - Originating From Firmware. 🙂
                    • muhac80undefined
                      muhac80 @deckingman
                      BMG style extruder
                      Thank you for the detailed explanation;
                      Here is some of the details x,y,z: 200,130,150mm
                      Motors: Nema 17; https://www.amazon.ca/gp/product/B07MDY5RX7/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
                      Board: Duet 2 Wifi
                      Power Supply: 600W, 24 V: https://www.amazon.ca/gp/product/B00DEDB2U2/ref=ppx_yo_dt_b_asin_title_o08_s01?ie=UTF8&psc=1
                      Heatedbed:
                      https://www.amazon.ca/gp/product/B07MR59G18/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
                      Pleas let me know if you need any other details.
                      • muhac80undefined
                        muhac80 @deckingman
                        This post is deleted!
