Is there a way to break out of an M116?
@cosmowave said in Is there a way to break out of an M116?:
@deckingman Perhaps you can write a macro which sets the target temp to the actual temp from OM.
TBH, I'm actually moving away from using either M109 or M116. The main reason reason being that in most cases, I want the tool temperature to be at or above a threshold and not necessarily just at a threshold. This is mostly for homing where all I want to do is soften any plastic that might have oozed out of a nozzle (I use the actual nozzle tip as a Z probe). If the tool is already above a threshold and I use either M109 or G10/M568 followed by M116, then it waits for the tool to cool which can be a pain. So instead of M116, I use
while sensors.analog[1].lastReading < whatever set point I choose ..... G4 S5
So a means of breaking out of an M116 loop might not be much use to me, but it might be to others (and I always try to have consideration for other people)
@deckingman Have you tried using M108? Looking at the code for M116 it seems to test the state of a variable called "cancelWait" which is what gets set by M108, so it looks like it is supposed to work for M116.
@gloomyandy said in Is there a way to break out of an M116?:
No I haven't tried it - my printer is in bits (again). That's why I posed the question to start with. . If you think it'll work, then all well and good. Thanks.
@deckingman Can't be 100% sure as I'm just reading the code, but it certainly looks like it may work.
Yes please try it. If it does work, I'll have the wiki entry changed to reflect that. If it doesn't work, it probably ought to.
@phaedrux said in Is there a way to break out of an M116?:
If that was aimed at me, then I can't try it because my printer is in bits (otherwise I would have tried it before posing the question).
For anyone else who is in a position to try it, send G10 P0 S185 R0 (the S and R values are not important as long as the "S" is a reasonably high number), then send M116, then wait a while to ensure that the tool is starts to heat but before it reaches the set point (185deg C in this case), send M108. If it works, the tool will stop heating.
Edit. Actually it probably wont stop -it'll just cancel the wait. So try doing something else like start a fan while the tool is heating. This shouldn't work while M116 is looping but if M108 cancels the loop, then it should be possible to start that fan before the tool has reached 185.
@deckingman @Phaedrux I'll give this a go on mine tonight.
My use case would accidentally switching tools after setting the standby/active temps. I have M116 in my tool change files so DWC gets stick in 'Busy' until those finish. If M108 works, that's much better than having to either wait or reboot
I'll give it a test next print I start.
@engikeneer said in Is there a way to break out of an M116?:
Glad I'm not the only one who thinks a way of curtailing the M116 wait loop would be handy. Let us know how you get on.
@deckingman you can cancel a M116 wait by sending M108 from a different GCode channel.
@dc42 said in Is there a way to break out of an M116?:
Good to hear. But what do you mean by "from a different GCode channel" ? Does it mean if M116 is being run from a macro, then M108 would need to be sent from something other than that same macro (i.e. the console)? Or do you mean something else?
@deckingman said in Is there a way to break out of an M116?:
Yes, exactly that (assuming that the macro wasn't invoked from the console).
@dc42 I tried this by initiating a tool change (I have an M116 in my tool change) by clicking the tool in DWC. With this, DWC stuck on 'changing tool' until the temperature had been reached. I tried sending M108 but it didn't actually send until after the tool change (and heating) had completely finished. Would I need to put the M108 in a macro and call that for this to work?
@engikeneer clicking on the tool in DWC will have sent the command from the DWC input channel, so M108 sent from that channel won't be acted on until the tool change is complete. Whereas if the tool change was commanded by a T command in the file being printed, then M108 sent from DWC should cancel the M116.
