    Help for translation needed
    51
    2.5k
    • Fred-Yundefined
      Fred-Y @mfs12
      @mfs12 It's coming from the same link you posted above
      • Fred-Yundefined
        Fred-Y @mfs12
        @mfs12 I think I figured out!
        I had this button to submit my review 🙄
        Can you see my comments now? 🤞
        • mfs12undefined
          mfs12
          @Fred-Y yes, now everything appeared.
          It will get in with the next release.
          Visit me on github at https://github.com/mfs12/
          Fred-Yundefined 1 Reply Last reply Reply Quote 0
          • Fred-Yundefined
            Fred-Y @mfs12
            @mfs12 Perfect!
            I will try to install it as soon as it is released and switch to French to make sure it looks good.
            • mfs12undefined
              mfs12
              @Fred-Y i commented some stuff.
              Status values must not be longer then 15 characters otherwise they are cut off.
              Please check
              • https://github.com/mfs12/PanelDueFirmware/pull/2
              And here are the actual changes i did so far.
              • https://github.com/Duet3D/PanelDueFirmware/pull/205/files
              mfs12 opened this pull request in mfs12/PanelDueFirmware
              draft Review translations langs #2
              mfs12 opened this pull request in Duet3D/PanelDueFirmware
              closed Strings: updated french translation #205
              • RomanVinundefined
                RomanVin
                Translate.txt
                Translation into Russian.
                mfs12undefined 1 Reply Last reply Reply Quote 0
                • mfs12undefined
                  mfs12 @RomanVin
                  Hey @romanvin, it would be helpful to comment on the changes at github. Otherwise managing all the changes will be pretty hard.
                  Please check
                  https://github.com/mfs12/PanelDueFirmware/pull/2#issuecomment-909913840
                  • Fred-Yundefined
                    Fred-Y @mfs12
                    @mfs12 I adjusted the status, they should all be 15 chr or less.
                    Let me know if I missed something
                    • mfs12undefined
                      mfs12
                      @RomanVin thanks for your help!
                      I created a pull request with most of you changes. I two changes i didn't take because they were too long.
                      If you want to have a last look on the changes feel free to comment in the pull request.
                      https://github.com/Duet3D/PanelDueFirmware/pull/209/
                      closed Strings: updated russian translation #209
                      • zaptaundefined
                        zapta @mfs12
                        @mfs12, do you use an online service to manage the collaborative translation? They can be very handy. E.g https://crowdin.com/page/open-source-project-setup-request
                        • mfs12undefined
                          mfs12
                          Hey @zapta, no, i didn't think of that when i started the task. But realized things like this exist. So far we are using github pull request to check translations. In the end i am updating the sources manually. Not ideal but so far only small portions need to be replaced.
                          Recently i also stumbled over weblate which sounds also interesting.
                          https://hosted.weblate.org/about/
                          • Vladimir_Uundefined
                            Vladimir_U
                            Hi. I can also help with translation into Russian.
                            • mfs12undefined
                              mfs12 @Vladimir_U
                              @vladimir_u said in Help for translation needed:
                              Thank you, but Russian is already done. But testing the next release would be helpful as well.
                              • Fred-Yundefined
                                Fred-Y
                                @mfs12 I just installed the 3.4.0-pre3 to check the French translation, how/where do you want the adjustment to be submitted?
                                I've seen a few details I would like to correct if possible.
                                • mfs12undefined
                                  mfs12
                                  @Fred-Y, i updated the review PR. So leave your comments there. Thanks.
                                  • Fred-Yundefined
                                    Fred-Y @mfs12
                                    @mfs12 I finished my review.
                                    9 Adjustments / responses to your comments.
                                    • mfs12undefined
                                      mfs12
                                      @Fred-Y , thanks. I will add them for the next release.
                                      Aitorundefined 1 Reply Last reply Reply Quote 0
                                      • mfs12undefined
                                        mfs12
                                        @Aitor, do you have a good translation for
                                        orig->filesOnCard: 'Files on card ', 'Archivos en la tarjeta ' lengths: 14/23
                                        • mfs12undefined
                                          mfs12
                                          @Aitor, the change cards button takes more time be configured. It will be available after the information is received from RRF. This can be fixed but is not related to the translations.
                                          Created an gitlab issue for this problem.
                                          https://github.com/Duet3D/PanelDueFirmware/issues/221
                                          mfs12 created this issue in Duet3D/PanelDueFirmware
                                          closed Files on card button is not updated in files dialog #221
                                          • Aitorundefined
                                            Aitor @mfs12
                                            Good morning @mfs12,
                                            'Files on card ', 'Archivos en la tarjeta ' is correct, but you could put "Archivos de la tarjeta" but both are understood.
                                            Regarding the card button thanks for taking it into account, I'll check if it comes out later, sometimes I don't have the patience XD
                                            Best regards
