    differences between manual and automatic leveling
    IR Height Sensor
    10
    41
    2.7k
    • fcwiltundefined
      fcwilt @Gip_86
      @gip_86
      The heightmap you posted reveals some bed irregularities, which are common.
      It also shows the bed is not as level as you would like it.
      You can read about using the manual bed leveling assistant here:
      Bed Leveling Assistant
      When can you update to firmware 3.3 (or later)?
        Some of your config.g command syntax looks like RRF3 already.
        M558 P1 C"zprobe.in" H5 F400 T6000
        What firmware version are you actually using?
        Can you share the results of sending M122 and M98 P"config.g"?
        Can you confirm your coordinate system is right handed?
        -X should move left, +X should move right
        -Y should move to the nozzle to the front of the bed, +Y to the back.
        Gip_86undefined 1 Reply Last reply Reply Quote 0
        • Gip_86undefined
          Gip_86 @Phaedrux
          @fcwilt
          okay thank you for this information.
          I think i can update this weekend. but i'm not shure if it works, because i have tried it befor i have set up the machine abd i always got errors. If i update to 3.3, can i use the old config or should i do all new?
          (because i'm not so good writing these files)
          @phaedrux
          here is M122, (M98 will follow this day)
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6M2-NWNS4-7J1FG-3S06R-9A0ZM
          Used output buffers: 3 of 24 (16 max)
          Static ram: 25680
          Dynamic ram: 93680 of which 380 recycled
          Exception stack ram used: 604
          Never used ram: 10728
          Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3780) IDLE(ready,160)
          Owned mutexes:
          Last reset 09:34:28 ago, cause: software
          Last software reset at 2021-09-15 21:44, reason: User, spinning module GCodes, available RAM 10792 bytes (slot 1)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
          Error status: 24
          Free file entries: 9
          SD card longest block write time: 511.5ms, max retries 0
          MCU temperature: min 37.7, current 38.8, max 40.4 Supply voltage: min 23.8, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: ok, SG min/max 0/1023
          Driver 1: ok, SG min/max 0/1023
          Driver 2: standstill, SG min/max 0/1023
          Driver 3: ok, SG min/max 0/1023
          Date/time: 2021-09-16 07:19:21
          Slowest loop: 227.29ms; fastest: 0.07ms
          Hiccups: 0, FreeDm: 148, MinFreeDm: 124, MaxWait: 20085157ms Bed compensation in use: none, comp offset 0.000
          === DDARing ===
          Scheduled moves: 21661, completed moves: 21621, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
          Heater 0 is on, I-accum = 0.9
          Heater 1 is on, I-accum = 0.4
          - WiFi –
          Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0
          WiFi firmware version 1.26
          WiFi MAC address f4:cf:a2:ea:55:43
          WiFi Vcc 3.36, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 27016
          WiFi IP address 192.168.0.84
          WiFi signal strength -65dBm, reconnections 0, sleep mode unknown
          Yes i can confirm that my coordinate system is right handed. as you described.
          • fcwiltundefined
            fcwilt @Gip_86
            @gip_86
            There are changes that need to be made to use v3 firmware but they are not extensive.
            You could use the configuration utility to create a new set of configuration files.
            Or you can edit your existing files.
            I put off doing it for quite a while but I'm glad I finally did. Version 3 firmware has many good things.
            You cannot for from v2.x to v3.3. You have to go from 2.x to 3.0 and then from 3.0 to 3.3.
            • zaptaundefined
              zapta
              When dealing with bed mesh, it useful to remember that what we measure is not just the characteristics of the bed but also all the errors between the bed and the sensor, including x,y,z mechanical system, head errors (e.g. does it sags and tilts) and error nozzle and the sensor (e.g. if the head tilts) and sensor errors (how accurate it is, is the bed surface compatible with it, etc).
              That's why we sometimes see measurement results that wouldn't make sense if we would measure the bed alone.
              Having some experience with HEVO, and it's motion mechanism tends to be soft (compared to more modern extrusion+rail based designs), especially the X rods, which are thinner (8mm?) and sag or cause head tilting. I would suggest to place the sensor to have zero y offest rather than zero x offset since this will cancel better the effect of head tilting.
              BTW, do you use two independent drivers for the Z motors? If you do, the Duet can do auto 'real' leveling between the two motor which is nice and reduces the compensation that the mesh need to do.
                Updating to 3.3 isn't that hard really, but it can be confusing if you're really used to the RRF2 way. I do recommend updating though, 2.03 is ~2 years old.
                If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                That will get your firmware and DWC up to date.
                You can see the change logs here:
                https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
                For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                https://configtool.reprapfirmware.org/Start
                Backup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
                These documents will come in handy during the conversion.
                https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                https://duet3d.dozuki.com/Wiki/Gcode
                Gip_86undefined 1 Reply Last reply Reply Quote 1
                • Gip_86undefined
                  Gip_86 @Phaedrux
                  @phaedrux
                  ufff spent the 4 last hours to upgrade to 3.3. holy sh... nothing was working anymore. had to switchover to bossa.
                  Now it works ok. but i get a heater fault. i will try to compare to my old config
                  • fcwiltundefined
                    fcwilt @Gip_86
                    @gip_86 said in differences between manual and automatic leveling:
                    @phaedrux
                    If you copy-and-paste your new config.g file here (using the </> tag) we can all pitch in and take a look.
                    It's very likely just a syntax error.
                    • Gip_86undefined
                      Gip_86 @fcwilt
                      @fcwilt
                      so this is the new config. I hava adjusted all i see to fit with the old config
                      ; Configuration file for Duet WiFi (firmware version 3.3)
                      ; generated by RepRapFirmware Configuration Tool v3.3.2 on Sat Sep 18 2021 02:15:19 GMT+0200 (Mitteleuropäische Sommerzeit)
                      G90                                            ; send absolute coordinates...
                      M83                                            ; ...but relative extruder moves
                      M550 P"HeVo"                                   ; set printer name
                      M669 K1                                        ; select CoreXY mode
                      M552 S1                                        ; enable network
                      M586 P0 S1                                     ; enable HTTP
                      M586 P1 S0                                     ; disable FTP
                      M586 P2 S0                                     ; disable Telnet
                      M575 P1 B57600 S1
                      M569 P0 S1                                     ; physical drive 0 goes forwards
                      M569 P1 S1                                     ; physical drive 1 goes forwards
                      M569 P2 S1                                     ; physical drive 2 goes forwards
                      M569 P3 S1                                     ; physical drive 3 goes forwards
                      M584 X0 Y1 Z2 E3                               ; set drive mapping
                      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z400.00 E396.00              ; set steps per mm
                      M566 X21000.00 Y21000.00 Z180.00 E54000.00     ; set maximum instantaneous speed changes (mm/min)
                      M203 X21000.00 Y21000.00 Z180.00 E300000.00    ; set maximum speeds (mm/min)
                      M201 X4000.00 Y4000.00 Z3000.00 E4000.00       ; set accelerations (mm/s^2)
                      M906 X1000 Y1000 Z1000 E800 I30                ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                        ; Set idle timeout
                      M208 X0 Y0 Z-1 S1                               ; set axis minima
                      M208 X205 Y202 Z150 S0                         ; set axis maxima
                      M574 X2 S1 P"xstop"                            ; configure active-high endstop for high end on X via pin xstop
                      M574 Y2 S1 P"ystop"                            ; configure active-high endstop for high end on Y via pin ystop
                      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
                      M558 P1 C"zprobe.in" H5 F120 T6000             ; set Z probe type to unmodulated and the dive height + speeds
                      G31 P500 X40 Y-35 Z2.04                          ; set Z probe trigger value, offset and trigger height
                      M557 X15:205 Y15:195 S20                       ; define mesh grid
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4400 ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                        ; map heated bed to heater 0
                      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4400  ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                      M950 F1 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                      M950 F0 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                      M563 P0 D0 H1 F0                               ; define tool 0
                      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                      • fcwiltundefined
                        fcwilt @Gip_86
                        @gip_86
                        Hmm...
                        Everything seems correct.
                        When are you getting this fault?
                        What is the exact message your are seeing?
                        • Gip_86undefined
                          Gip_86 @fcwilt
                          @fcwilt
                          hi Frederick
                          this is the message i got:
                          Error: Heater 0 fault: temperature rising much more slowly than the expected 1.3°C/sec
                          Resume state saved
                          Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                          Blacksheep99undefined 1 Reply Last reply Reply Quote 0
                          • Blacksheep99undefined
                            Blacksheep99 @Gip_86
                            @gip_86 Have you run a PID tune of your extruder and bed?
                            • Gip_86undefined
                              Gip_86 @Blacksheep99
                              @blacksheep99
                              yes i have one done for the heater and the bed.
                              Bed:
                              Warning: heater behaviour was not consistent during tuning
                              Auto tuning heater 0 completed after 4 idle and 25 tuning cycles in 5317 seconds. This heater needs the following M307 command:
                              M307 H0 B0 R0.957 C113.0 D6.66 S1.00 V24.2
                              Edit the M307 H0 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.
                              Heater:
                              M307 H1 B0 R2.746 C97.9:59.2 D5.41 S1.00 V24.2
                              one question:
                              after firmwareupdate now it takes very long to heat up the bed. is this normal?
                              Blacksheep99undefined 1 Reply Last reply Reply Quote 1
                                @gip_86 Have you got a config-override.g in your sys folder with the output of the tuning? You also need a M501 in your config.g if you do.
                                • Gip_86undefined
                                  @blacksheep99
                                  no, i have put the M307 in config directly..
                                  ;M307 H0 B0 S1.00
                                  M307 H0 B0 R0.957 C113.0 D6.66 S1.00 V24.2	   ; disable bang-bang mode for the bed heater and set PWM limit
                                  ;M307 H1 B0 S1.00
                                  M307 H1 B0 R2.746 C97.9:59.2 D5.41 S1.00 V24.2 ; disable bang-bang mode for heater  and set PWM limit
                                  if i put it in override, what have i to put in?
                                  and in config should only M501?
                                  • fcwiltundefined
                                    fcwilt @Gip_86
                                    @gip_86
                                    It's perfectly fine to put everything in config.g
                                    The config-override.g file is just to make it a bit easier as a M500 after certain operations makes the needed entries in config-override.g.
                                    I have never used config-override.g - I move the contents to config.g and delete config-override.g
                                    • Gip_86undefined
                                      Gip_86 @fcwilt
                                      @fcwilt
                                      after pid tuning i have decided to add "R4700 behind the M308.
                                      Now bed has heated really fast. Is there something agains R4700? I had this thing in my old config.
                                      Now it looks like:
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4400 R4700
                                      M308 S1 P"e0temp" Y"thermistor" T100000 B4400 R4700
                                      • fcwiltundefined
                                        fcwilt @Gip_86
                                        @fcwilt
                                        Now it looks like:
                                        Well the R setting is supposed to match the values of the resistors on your board.
                                        If you don't have a R setting it is supposed to default to the correct values for your board.
                                        • Gip_86undefined
                                          Gip_86 @fcwilt
                                          @fcwilt
                                          Ok, machine is now running as aspected (but without mesh compensation)
                                          I also have designed a new holder for the probe.
                                          So and what are the best steps for next?
                                          • fcwiltundefined
                                            fcwilt @Gip_86
                                            Have you made the configuration settings needed to use the Manual Bed Leveling Assistant?
                                            Once that is done and the bed is level you should then proceed to get Mesh Bed Compensation working.
