    Houston we have a problem...
    1.7k
      jay_s_uk @peirof
      @peirof do you have a multimeter to check the power from the PSU?
      Also check all the fuses if you haven't already
      peirofundefined 1 Reply Last reply Reply Quote 0
      • peirofundefined
        peirof @jay_s_uk
        @jay_s_uk
        thanks i will try, i put reports after
        peirofundefined 1 Reply Last reply Reply Quote 1
        • peirofundefined
          peirof @peirof
          @peirof
          seems fuse.... but why?
          dc42undefined peirofundefined 2 Replies Last reply Reply Quote 0
            dc42 administrators @peirof
            @peirof which Duet do you have, and which fuse has blown?
            • peirofundefined
              peirof @peirof
              @peirof
              Duet v2
              What protect this fuse?
              I can read in fuse 7.5
              • peirofundefined
                peirof @peirof
                @peirof as supossed... first must solve the issue... i have changed the fuse.... and burn fast....
                what protect these fuse... know where i have to search
                  jay_s_uk @peirof
                  • peirofundefined
                    peirof @jay_s_uk
                    @jay_s_uk thanks
                    • peirofundefined
                      peirof @peirof
                      @peirof I have not had time to prove anything ...tomorrow, but I have a question.
                      From that fuse. Does the Due Panel also depend? because it is in black
                        T3P3Tony administrators @peirof
                        @peirof yes the 5V from the PanelDue is also supplied via that fuse
                        • peirofundefined
                          peirof @T3P3Tony
                          @t3p3tony
                          This is a thought out loud, so you can tell me the mistakes I make, since I have no experience in electronics / electricity.
                          My goal is to identify which component is shorted, and which is causing the fuse to blow.
                          The components that this fuse monitors are:
                          • Due panel
                          • Extruder Heater
                          • Extruder Stepper
                          • Axis Stepper.
                          If the fuse burns, as soon as the printer is turned on, I have to discard the components that have not received power yet ... Which leaves us alone:
                          • Due panel.
                          No? Something escapes me? Do you watch any more components?
                          A component that could cause problems is the Heater ... but if it has not received power when the fuse blows ... I do not think it is the cause of the problem
                          peirofundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                          • peirofundefined
                            peirof @peirof
                            @peirof
                            another question that arises ...
                            I think I remember, that there have been moments, I don't remember if now, in config.g, in M906 I have or have had a current for 1200 motors, which exceeds the protection of the fuse.
                            Why hasn't it been burned before?
                            jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                            • jumpedwithbothfeetundefined
                              jumpedwithbothfeet @peirof
                              @peirof Do you have a multi-meter? if your blowing a fuse the safest thing to do would be to check all your wiring for shorts before you connect anything.
                              looking at the picture you posted above there appears to be stray strands of wire on the right most stepper connector (red wire)
                              6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                                @peirof said in Houston we have a problem...:
                                Heaters are switched on the ground side not the supply side so a heater that had a short to ground would start taking power as soon as the board has power. That said its unlikely that a normal heater in normal operation will draw 7.5A+ and blow the fuse, however a faulty heater with an internal short could do.
                                As has already been said shorts in the wiring can also be the cause, most likely is VIN to ground.
                                It is not impossible for it to be the paneldue, but that is the most unlikely as it gets 5V so it is unlikely for it to draw enough current at 5V to blow the fuse, unless the 5V regulator has also failed short (and then you have a lot of problems as VIN on the 5V line will damage other things as well.
                                • peirofundefined
                                  peirof
                                  hi,
                                  think i have find it, but something its wrong....
                                  i have unplugged:
                                  A)- First
                                  • Heater
                                  • Steppers motors
                                  • Panel Due
                                  B)- Second
                                  • I have changed the burned fuse, 7,5A
                                  C)- Third
                                  • Power on Duet/Printer
                                  and....
                                  After few seconds, maybe 10s...
                                  Smoke has started to come out from the cable connecting the Zprobe to the Duet. As fast as I could I have turned off the printer, but I think it was too late ...
                                  I have disconnected the Zprobe (Precision Piezo), and I have turned on the printer ... and I think wrong ...
                                  Many lights on on the plate, and it does not respond to the orders sent by Panel Due ...
                                  I have tried to connect by Telnet ... and it has not been possible ...
                                  I think DUET has burned ...
                                  what could have happened?
                                  Is it like the new fuse didn't do its job?
                                  What are my options?
                                  • peirofundefined
                                    peirof
                                    disaster photos
                                    • peirofundefined
                                      peirof @peirof
                                      @peirof
                                      Thinking a bit about what could have happened ... the only thing I can think of is that at some point, I would have connected the Precision Piezo in reverse ...
                                      Could this be the cause of the disaster?
                                        @peirof possibly but its odd that it would base a 7.5A fuse to blow first and then start smoking! I cant see from the pictures but I assume the Paneldue is not connecting. Try connecting over USB (with everything else unplugged) and the SD card removed and see if you get a comm port and can connect over YAT.
                                        • peirofundefined
                                          peirof @T3P3Tony
                                          @t3p3tony said in Houston we have a problem...:
                                          Panel Due its not connecting... and i have try to connect with YAT, and Usb connection with Duet dont appears
                                            @peirof Is the SD card damaged as well (test in a PC) when it is powered over USB is anything getting hot?
