    All Axes will Home but have not Connected Any Endstops?
    897
      deckingman @Pickett
      @pickett If you go into DWC and scroll down to "Settings", then select "Machine Specific", you'll see a tab labelled "Endstops". That will show the real time status of all the end stops. With the carriages some distance away from the stops, they should show as not triggered and if you manually trigger each one, the status will should change.
        T3P3Tony administrators @deckingman
        @deckingman unfortunately not without the endstops plugin installed now... hence why I use M119
        Pickettundefined 1 Reply Last reply Reply Quote 0
        • Pickettundefined
          Pickett @T3P3Tony
          @t3p3tony ok I am not seeing an endstops tab so please tell me how to go about getting this endstops tab plugin and or why should I use M119 in lieu of the E-stops tab?
          T3P3Tonyundefined cosmowaveundefined 2 Replies Last reply Reply Quote 0
            T3P3Tony administrators @Pickett
            @pickett https://github.com/Duet3D/DSF-Plugins/tree/master/EndstopsMonitor its here. but its simpler to use M119 .
            T3P3Tonyundefined Pickettundefined 2 Replies Last reply Reply Quote 0
              T3P3Tony administrators @T3P3Tony
              @Pickett download from here:
              https://github.com/Duet3D/DSF-Plugins/releases/tag/v3.3.0
              • cosmowaveundefined
                cosmowave @Pickett
                @pickett you see the endstop tab only if you have installed the endstop plugin.
                So, use M119 for checking the endstops.
                Send M119 without any endstop pressed. DWC will answer with endstop status...
                Then push x-endstop and send M119 again (with pushed endstop). Check if the state has changed.
                Then the same with y-endstop....
                Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                • Pickettundefined
                  Pickett @T3P3Tony
                  @t3p3tony okay i get it now the M119 simply gives an up to date reading of the endstops while the Endstops plugin creates a tab to then show the status of the endstops ok ok I see but here is the thing it appears that I have the wiring done right but everytime I go to home my Axes each Axis will just move a few mm's then call it quits and will basically say "im home!" and will do nothing further kind of like this dude I know from work lols no but seriously can not figure out why each Axis never goes the whole way home and truly "homes" back home its wierd? Maybe Im missing something IDK???? This is like the only thing that is stopping me from getting to my first print................. have learned so much along the way though no doubt!
                    @pickett what is the result of the M119 command with and without the endstops pressed?
                    • Pickettundefined
                      Pickett @T3P3Tony
                      @t3p3tony I dont get it tbe Y is most certainly NOT at its endstop and neither is the X?????
                      m119
                      Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: not stopped
                      cosmowaveundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                        cosmowave @Pickett
                        @pickett invert the endstops with a "!" in the config
                        M574 X1 S1 P"io5.in"
                        change to
                        M574 X1 S1 P"!io5.in"
                        the same with y endstop
                        Pickettundefined 1 Reply Last reply Reply Quote 1
                        • Pickettundefined
                          Pickett @cosmowave
                          @cosmowave ok lemme update the config.g so should i update the homex.g and homeall.g and homey/z.g's as well????
                          cosmowaveundefined 1 Reply Last reply Reply Quote 0
                            cosmowave @Pickett
                            @pickett No, only in config.g
                            Pickettundefined 2 Replies Last reply Reply Quote 1
                            • Pickettundefined
                              Pickett @cosmowave
                              @cosmowave ok now it looks like:
                              M574 X1 S1 P"!io5.in" ; configure active-high endstop for low end on X via pin io5.in
                              M574 Y1 S1 P"!io6.in" ; configure active-high endstop for low end on Y via pin io6.in
                                @pickett I suspect you may have the endstops wired as normally open, not normally closed. As @cosmowave mentions you can change the firmware to work with that, however there are good reasons to normally use normally closed endstops.
                                  cosmowave @Pickett
                                  @pickett If you'd like to change your endstops to normally closed endstops (safer in case of wire failure), you have to wire them to "label" 1 and 3 on the endstops.
                                  But then, i think you should invert the function again with deleting the "!" in config.g
                                  • Pickettundefined
                                    Pickett @cosmowave
                                    @cosmowave ok now the axis move but are going in the opposite direction so I guess I need to reconfigure my stepper motor direction of rotation in the configurator tool? Also the stepper motors seems to be vibrating really loud now like it is some sort of wiring issue but it is wired correctly i know this cause Im the one whom crimped the terminals, got the Black, Green, Blue, Red order. the Z properly homes cause well it just detracts then it dives --------------------000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000=============================================================================================9999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999slowly down til it reaches the bed............. Ok will take a break from this for now coz I keep falling asleep onto my keyboard lolz will return for more troubleshooting techniques and what not!!!!! Thanks for everyones help this far will get it figured out one way or another!!!!!!!0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000r
                                      cosmowave @Pickett
                                      @pickett said in All Axes will Home but have not Connected Any Endstops?:
                                      Yes correct. You can change direction in config.g. Change S0 to S1
                                      M569 P0.0 S0 ; physical drive 0.0 goes backwards
                                      change to
                                      M569 P0.0 S1 ; physical drive 0.0 goes backwards
                                      you have to edit the correct axle! I don't know if x or y should be inverted!
                                        @pickett locking this as you have started a new thread about the issue:
                                        https://forum.duet3d.com/topic/25464/x-y-not-homing-z-is-a-bl-touch-it-is-homing/3
