    Arcwelder?
    510
    • CNCModellerundefined
      CNCModeller
      Hi All,
      Has anyone had any success using Arcwelder? Am thinking about giving it a try.
      Any thoughts would be much appreciated.
      Cheers
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
      PCRundefined o_lampeundefined Stephen6309undefined GeneRisiundefined 4 Replies Last reply Reply Quote 0
      • PCRundefined
        PCR @CNCModeller
        @cncmodeller If you are useing high accel then i would give it a try.IMG_20211003_101520.jpg
        First one without Second one with.
        IT also depends on the resulotion of the stl
        • oliofundefined
          oliof
          ArcWelder can improve prints but I'd inspect every single model for unwanted changes before printing it after postprocessing with ArcWelder. Some slicers do what ArcWelder does natively now, and even there I rarely enable the feature.
          • o_lampeundefined
            o_lampe @CNCModeller
            @cncmodeller I'm using it permanently without problems.
            I don't expect any advantages other than smaller files, so I didn't make any testprints.
            • Stephen6309undefined
              Stephen6309 @CNCModeller
              @cncmodeller I'm using with Prusa Slicer. So far, no problems. I've added program to my post-processing scripts section, so it's run when saving/uploading the gcode.
              Marius Breuerundefined 1 Reply Last reply Reply Quote 0
              • GeneRisiundefined
                GeneRisi @CNCModeller
                @cncmodeller I am using but started getting strange results. After I get the job printed with gcode that doesn't use "G3" I will watch what it is doing and report back here.
                • Marius Breuerundefined
                  Marius Breuer @Stephen6309
                  @stephen6309 +1
                  I also use it with duet 2 Ethernet, external drivers (BLDC Servos for X and Y) and as a script in Prusaslicer. I've not done extensive tests, but the prints do look smoother. Never had any issues with it.
                    CNCModeller
                    Ok, so the general consensus seems to be it's worth a look. I'll add it to my post processing options in S3D and see how it fairs.
                    Thanks for the thoughts folks.
                    Cheers
                    Barry M
                    Wanhao D4S: Duet2
                    K40 Laser, Duet2
                    Wanhao D5S
