    New Raspberry Pi Zero 2W
    65
    4.2k
    • zaptaundefined
      zapta @T3P3Tony
      @t3p3tony said in New Raspberry Pi Zero 2W:
      Alternatively it might allow Klipper or similar to use Duet 3 expansion boards w/o a mainboard, they could implement the Duet CAN-FD protocol on the pi and send the planned moves to each board....
      Does the duet main board send move commands over CAN in real time or does it just sync clocks and then send queued moves with target start time?
      The former will put hard realtime constrains on the SBC, the later is more relaxed.
      As for the Pico's PIOs, they are awesome. The stepper analyzer uses them to write to the display which achieves a significant boost. Typically they communicate with the software via hardware fifos that can be accessed programmatically or by DMA. For example, the MCU (there are two of them) can write the stepper pulse commands (e.g. interval and direction) to a double buffer and trigger a DMA to send them to the pio. Also, the the RP2040 are very cheap but like many other chips these days are hard to get.
      For CAN bus implementation, I would check in the Pico forums, they also have strong presence from the vendor. https://forums.raspberrypi.com/viewforum.php?f=143
      • o_lampeundefined
        o_lampe @zapta
        @zapta That's really good news about the PIOs. I hope we can gain enough interest and gather some SW-experts to make the best possible gadget.
        I still hope it's not all CAN related, for the sake of Duet2 owners...
        BTW: Berrybase.de still has almost 20.000 of them in stock.
        • o_lampeundefined
          o_lampe
          I played a bit with the Z2W and compared it with a RPi3b. They have the same cpu, but the Z2W constantly uses the swap-file in GUI mode.
          I even had to increase the swap-size (default only 100MB)
          The eMMC-uSD card I also bought, has no significant speed gain over class 10 SD card. (RPi4 benchmarks are much better)
          My first impression: if you already have a RPi3 or better, and @PCR 's CAN-FD Hat will fit there too, there's no reason to spend extra money for a Z2W.
          The Pico is still interesting as a low level CoPro. Time will tell...
          • o_lampeundefined
            o_lampe @T3P3Tony
            @PCR using that CAN-FD bus IC & transceiver with a Pi (either directly on a Pi 2/3/4, or using a 2040 + USB to a PC) could certainly allow for bus monitoring and protocol diagnosis, independent of using an oscilloscope so that could be interesting.
            I read more about Pico's PIO state machines and there is a sample code about a logic analyzer (16 channel IIRC). Just thought it was worth mentioning it in this context.
              dc42 administrators @o_lampe
              While the PIO state machines look very useful, the amount of instruction memory (32 instructions) and scratchpad memory (2x 32 bits) are nothing like enough to implement a protocol with the complexity of CAN-FD.
              o_lampeundefined zaptaundefined 2 Replies Last reply Reply Quote 0
              • o_lampeundefined
                o_lampe @dc42
                @dc42 I felt the same, when I studied the CanHack.py program. So we'd need both Can chips to make it work.
                • zaptaundefined
                  zapta @dc42
                  @dc42 said in New Raspberry Pi Zero 2W:
                  @dc42, I am not familiar with CAN bus. What does the PIO need to do other than serializing bits in/out or detect collisions? Those PIO instructions are very capable (they have multiple fields and can do a few things in one instructions) and work well with the the hardware FIFOs, DMAs, and MCU interrupts.
                  o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  • o_lampeundefined
                    o_lampe @zapta
                    @zapta The CanHack program lists many subroutines for testing and demonstration purposes and some real life routines. They are usually only a few lines of code. In C++ they might even be more compact.
                    But for compatibility reasons beween Pico(with state machines) and Z2W(no state machines), the Can-Hat should have both Can chips anyway...
                    • zaptaundefined
                      zapta @o_lampe
                      @o_lampe, I see here two pdf schemas, one with a can controller and one with just the transceiver. What's the difference between them? Can the one without the MCP2518FD still support CAN functionality? Why two versions?
                      https://github.com/kentindell/canhack/tree/master/pico
                      • o_lampeundefined
                        o_lampe @zapta
                        @zapta I'm no CAN expert either, but it seems it has some FiFo buffers, filters and CRC check of the SPI bus. The 40MHz crystal is another feature for better CAN-performance and reliability.
                        • o_lampeundefined o_lampe referenced this topic
                        • o_lampeundefined
                          o_lampe
                          @ALL
                          there's a dual CAN-FD Hat for RPi from Seeedstudio
                          Does anyone see a reason, why this wouldn't work for SBC-purposes? (pins or I/O channels already in use)
                          @PCR
                          would it still make sense to design our own version?
                            jay_s_uk @o_lampe
                            @o_lampe the raspberry pi shield might be a way to add CAN-FD in setups where it's not natively available, such as duet 2 + SBC and the STM/LPC port
                            PCRundefined o_lampeundefined 3 Replies Last reply Reply Quote 0
                            • PCRundefined
                              PCR @jay_s_uk
                              @jay_s_uk Yep problem is that the Shield is using SPI i think?
                              • o_lampeundefined
                                o_lampe @jay_s_uk
                                @jay_s_uk said in New Raspberry Pi Zero 2W:
                                the STM/LPC port
                                The super8 has a Can-Port, but it's not (yet) supported? OTOH, I wouldn't know how to link a RPi?
                                  jay_s_uk @o_lampe
                                  @o_lampe it does but it's only CAN over serial for the klipper guys
                                  • o_lampeundefined
                                    o_lampe @PCR
                                    @pcr said in New Raspberry Pi Zero 2W:
                                    There are two different versions. As it seems they both use SPI.
                                    Which I/O protokol would be best? UART, I2C, SPI?
                                    • o_lampeundefined
                                      o_lampe @jay_s_uk
                                      That's the idea, although I don't think we'll see a Duet2 with a Duet3-toolboard. There's latency between Duet <=> RPi and RPi <=> toolboard
                                        dc42 administrators @zapta
                                        @zapta said in New Raspberry Pi Zero 2W:
                                        Lots of things. When receiving it has to generate a local clock that can handle variation and jitter in the received clock. It has to decode the initial ID byte format to determine whether it uses an 11-bit or 29-bit address, whether the node is interested in that ID, whether it is a CAN-FD or plain CAN packet, and whether bit rate switching is enabled (I guess you could avoid some of that by restricting the types of packet supported). It has to handle bit stuffing, and it has to calculate the CRC of the received message in real time so that it knows whether to assert the ACK bit at the end of the message.
                                        • zaptaundefined
                                          zapta @dc42
                                          @dc42, yes, it sounds a lot of things. As you say, some could be addressed by focusing on message types that exist in a duet system but I am not sure about the CRC, how complex it is or what is the time to respond. On the other hand, the PIO provide room for creative solutions and possibly may be able to use a few state machines in parallel to divide the work, and there is also the second MCU core that is sitting idle and can be dedicated for the CAN decoding, and then there is an official API to overclock everything ... 😉
                                          • o_lampeundefined
                                            o_lampe @zapta
                                            @zapta @dc42
                                            It would be interesting to know: are all of these functions hardwired in a Sammy-C21?
                                            dc42undefined zaptaundefined 2 Replies Last reply Reply Quote 0
