    New Raspberry Pi Zero 2W
    65
    4.2k
    • o_lampeundefined
      o_lampe @zapta
      @zapta I'm no CAN expert either, but it seems it has some FiFo buffers, filters and CRC check of the SPI bus. The 40MHz crystal is another feature for better CAN-performance and reliability.
      • o_lampeundefined o_lampe referenced this topic
      • o_lampeundefined
        o_lampe
        @ALL
        there's a dual CAN-FD Hat for RPi from Seeedstudio
        Does anyone see a reason, why this wouldn't work for SBC-purposes? (pins or I/O channels already in use)
        @PCR
        would it still make sense to design our own version?
          jay_s_uk @o_lampe
          @o_lampe the raspberry pi shield might be a way to add CAN-FD in setups where it's not natively available, such as duet 2 + SBC and the STM/LPC port
          PCRundefined o_lampeundefined 3 Replies Last reply Reply Quote 0
          • PCRundefined
            PCR @jay_s_uk
            @jay_s_uk Yep problem is that the Shield is using SPI i think?
            • o_lampeundefined
              o_lampe @jay_s_uk
              @jay_s_uk said in New Raspberry Pi Zero 2W:
              the STM/LPC port
              The super8 has a Can-Port, but it's not (yet) supported? OTOH, I wouldn't know how to link a RPi?
                jay_s_uk @o_lampe
                @o_lampe it does but it's only CAN over serial for the klipper guys
                • o_lampeundefined
                  o_lampe @PCR
                  @pcr said in New Raspberry Pi Zero 2W:
                  There are two different versions. As it seems they both use SPI.
                  Which I/O protokol would be best? UART, I2C, SPI?
                  • o_lampeundefined
                    o_lampe @jay_s_uk
                    That's the idea, although I don't think we'll see a Duet2 with a Duet3-toolboard. There's latency between Duet <=> RPi and RPi <=> toolboard
                      dc42 administrators @zapta
                      @zapta said in New Raspberry Pi Zero 2W:
                      @dc42 said in New Raspberry Pi Zero 2W:
                      While the PIO state machines look very useful, the amount of instruction memory (32 instructions) and scratchpad memory (2x 32 bits) are nothing like enough to implement a protocol with the complexity of CAN-FD.
                      @dc42, I am not familiar with CAN bus. What does the PIO need to do other than serializing bits in/out or detect collisions? Those PIO instructions are very capable (they have multiple fields and can do a few things in one instructions) and work well with the the hardware FIFOs, DMAs, and MCU interrupts.
                      Lots of things. When receiving it has to generate a local clock that can handle variation and jitter in the received clock. It has to decode the initial ID byte format to determine whether it uses an 11-bit or 29-bit address, whether the node is interested in that ID, whether it is a CAN-FD or plain CAN packet, and whether bit rate switching is enabled (I guess you could avoid some of that by restricting the types of packet supported). It has to handle bit stuffing, and it has to calculate the CRC of the received message in real time so that it knows whether to assert the ACK bit at the end of the message.
                      • zaptaundefined
                        zapta @dc42
                        @dc42, yes, it sounds a lot of things. As you say, some could be addressed by focusing on message types that exist in a duet system but I am not sure about the CRC, how complex it is or what is the time to respond. On the other hand, the PIO provide room for creative solutions and possibly may be able to use a few state machines in parallel to divide the work, and there is also the second MCU core that is sitting idle and can be dedicated for the CAN decoding, and then there is an official API to overclock everything ... 😉
                        • o_lampeundefined
                          o_lampe @zapta
                          @zapta @dc42
                          It would be interesting to know: are all of these functions hardwired in a Sammy-C21?
                          dc42undefined zaptaundefined 2 Replies Last reply Reply Quote 0
                            dc42 administrators @o_lampe
                            @o_lampe said in New Raspberry Pi Zero 2W:
                            @zapta @dc42
                            Yes.
                            • zaptaundefined
                              zapta @o_lampe
                              @zapta @dc42
                              To set the record straight, I know almost nothing about CANBUS and the little I know is mostly from this thread. 😉
                              BTW, I do have some experience with another automotive bus call LINBUS that you can find in modern cars but is seldom mentioned. This product for example is based on a public domain design that I published on github http://t-design9.com/memory_module_porsche.html .
                              • arhiundefined arhi referenced this topic
                              • 0nn0undefined 0nn0 referenced this topic
