    Anybody wants a stepper motor analyzer?
    281
    33.3k
    • rjenkinsgbundefined
      rjenkinsgb
      Well, JLC are on excellent form as usual - the five PCBs arrived yesterday.
      The current sensors have been despatched, but I don't have a delivery date yet.
      I will post an update when they arrive.
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      • PCRundefined
        PCR @jackantubis
        @jackantubis here!
        .BTW. i now got boards and sensors
        you will only need the screen and the pico
        • lbtqsbundefined
          lbtqsb
          @zapta
          Dear zapta, this is lb (deleted my account a few month back because of private/personal issues) but suddenly I recieved "my" stepper-analyzer (tried to cancel my order last minute before deleting my account in a private chat with you, but maybe it got also deleted when I deleted my account and you never had a chance to read the chat-message?). I bought an amazon gift card at a local shop here, and now would like to send all info related to it in a private message: But since this account is brand-new just for this purpose, I do not have enough rights/priviliges to start a private chat with you... Could you open a chat so I can send you the photos of the card with serial and bill and all of that? (Sorry to cause you so much trouble, I should have waited for a reply in the private chat for the cancelling of the order before deleting my account, so it is my fault. The stepper analyzer actually looks pretty cool! Congrats!)
          Best regards
          • zaptaundefined
            zapta @lbtqsb
            @lbtqsb, just sent you a direct message here. Hopefully the system will allow you to reply.
            • o_lampeundefined
              o_lampe
              @zapta I'm late to the party and only came here, because you mentioned using the Pico state machine for the display.
              What are the limits of screen size, colour depth? Which (TFT,HDMI?) screen do you recommend?
              //edit I scrolled through the thread and github pages, but I'm more confused than before: I found different names for the TFT: ER-TFTM35-6 ? What's the order number for a bare TFT with touchpad (without breakout board)
              @pcr @zapta I'd consider this board as a CAN-Hat candicate. Add Can FD chips instead of current sensors (or add both?) as a CAN-analyzer...
              • zaptaundefined
                zapta @o_lampe
                @o_lampe , the stepper analyzer uses a 3.5” 320x480, IL9488, capacitive touch FT6206 TFT display. The older design (legacy) used a PCB based unit buydisplay.com and the newer one uses a bare TFT module from AliExpress ('3.5 LCD CTP' option at https://www.aliexpress.com/item/32862869103.html).
                For your design, a couple of questions about the requirements
                1. What is the desired display size and resolution?
                2. Is it a quick one-of or will it be produced in larger quantities (design effort vs unit price sensitivity).
                3. What is the nature of the display update? E.g. text fields N times per second, rolling graphs, videos, etc. This may affect the choice of the display interface.
                • o_lampeundefined
                  o_lampe
                  @zapta said in Anybody wants a stepper motor analyzer?:
                  Thanks for the detailed TFT info.
                  There is no specific project behind my question, only the general idea of cobbling a RPi Zero, CAN-FD and a display together as CAN sniffer/analyzer or panelDue replacement. The touchpad could also work as macro-trigger buttons or CAD-pendant.
                  Our imagination is the limit!
                    rjenkinsgb
                    @jackantubis said in Anybody wants a stepper motor analyzer?:
                    ACS70331
                    Well, just received the pack of ten ICs.
                    No idea what they actually are [6C185A7], but they are definitely not ACS70331 current sensors!
                    Refund requested from the selling site..
                    Robert J.
                    • zaptaundefined
                      zapta @rjenkinsgb
                      @rjenkinsgb said in Anybody wants a stepper motor analyzer?:
                      A quick elimination can be done by testing if pin 1, 2 are shorted internally. Same for pins 3, 4. If not, that's a wrong IC. If they are, they have the potential to be the right IC.
                      I have good experience with this one, never sent me bad sensors (last time I purchased was on May 2021 and they were $1.39 each)
                      https://www.aliexpress.com/item/4001123087424.html
                      • zaptaundefined
                        zapta @o_lampe
                        @o_lampe said in Anybody wants a stepper motor analyzer?:
                        I see. Will you run linux on the RPI Zero or something more bare bones?
                        • o_lampeundefined
                          o_lampe @zapta
                          @zapta Sorry, my mistake. I meant Pico not Zero.
                          The PIO needs a special programming language, I currently try to llearn. Most code will be microPython I guess.
                          • zaptaundefined
                            zapta @o_lampe
                            @o_lampe , PIO programming is like solving a puzzle and can be fun because it has a lot of room for creativity, for example, the stepper analyzer uses three programs for the same state machine and switches between them as needed (see the start_* labels in the program below)
                            https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/platformio/src/display/tft_driver.pio
                            VisualGDB (commercial) is supposed to have a good PIO debugger but never used it.
                            I highly recommend platformio over the SDK.
                            • Dogma2kundefined
                              Dogma2k
                              @zapta
                              Is there an alternative for the ACS70331EOLCTR-2P5B3 that can be used? They are not really available at the moment and if only extremely overpriced
                              rjenkinsgbundefined 1 Reply Last reply Reply Quote 1
                                rjenkinsgb @Dogma2k
                                @dogma2k said in Anybody wants a stepper motor analyzer?:
                                I've been looking for some as well, as I have all the other parts.
                                The Broadcom ACHS-7191 appears to be pin compatible and available, though rather less sensitive (10A full scale) and lower frequency response, only up to near 80 KHz..
                                https://docs.broadcom.com/docs/ACHS-719x-DS
                                https://www.mouser.co.uk/ProductDetail/Broadcom-Limited/ACHS-7191-000E?qs=sGAEpiMZZMv0NwlthflBi7EEbbt72Wx0J1IUc%252BxIF%2Fg%3D
                                I have no idea it they are usable in the design as it is, or if some software changes would be needed to adjust sensitivity.
                                And I'm not sure what impact the lower frequency response would have?
                                Robert J.
                                • Th0mpyundefined
                                  Th0mpy
                                  HELLO everyone!
                                  I've finally gotten a few more analyzers completed. I swapped out the current sensor with a TI TMCS1101, which is pin compatible and works with the correct voltages. Additionally, it's available 🙂
                                  I've modified the code to accept the new sensor, and made a couple modifications to the board. should more sensors be needed in the future.
                                  I will sell them for $65 a piece. The cost went up a bit due to the cost of the current sensors.
                                  If needed, I can include jumpers for a 5+ mini or 6hc (connect between the analyzer and the duet board). Prices for the 5+ is $5 (only 1 is needed) or $8 for the 6hc (two needed)
                                  Send me a private message if you want one. If you need jumpers please indicate that and what kind (5+ or 6hc). I accept payments only via PayPal and will give you my info when you message me.
                                  In total I have 8 available. There are a few who already asked in my messages so I will hit them up first and in the order they requested.
                                  The picture below is one of the actual units.
                                  54fad5e1-1387-45d1-91ec-ffda0cea651e-2ABD09C9-5CA4-4BE0-BDBD-5E475409DC17_1_105_c.jpeg
                                  Usually the team that scores the most points wins the game.
                                  PCRundefined zaptaundefined 3 Replies Last reply Reply Quote 1
                                  • PCRundefined
                                    PCR @Th0mpy
                                    @th0mpy
                                    i have 6 boards here aswell. But without sensors... can i get your code?
                                    BEst
                                    Th0mpyundefined 1 Reply Last reply Reply Quote 0
                                    • PCRundefined
                                      PCR @Th0mpy
                                      @th0mpy said in Anybody wants a stepper motor analyzer?:
                                      TI TMCS1101
                                      and every site i search they are not avaible ;(
                                      • Dogma2kundefined
                                        Dogma2k
                                        Hi @Th0mpy,
                                        i also have 5 boards here without sensors and would also be interested in the adapted code like @PCR .
                                        P.S. what is the exact name of the TMCS1101? (TMCS1101A3UQDRQ1 or TMCS1101A4UQDRQ1 etc.)
                                        P.S. Which jumpers do you think are still needed? Do you mean the connections at J1 + J2?
                                        • zaptaundefined
                                          zapta @rjenkinsgb
                                          The stock board assumes current sensors that operates on 3.3V. The ACHS-7191 seems to require 5V so will need some design changes.
                                          Have you seen the recent post here that mentioned the TI TMCS1101 ?
                                          rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                                          • zaptaundefined
                                            zapta @Th0mpy
                                            Can you release these modifications? It will be useful if we will 'standardize' the configuration such that we can share firmware between boards.
