Unable to print PLA
This doesn't really fit all your symptoms, but what is the ambient temperature - that is, temperature of the air around the extruder?
I have a printer with direct drive extruder inside a fairly insulated enclosure, and PLA doesn't like it when the air in the enclosure gets too hot. The extruder is hobbed drive direct on the stepper shaft. If the air in the enclosure gets too warm, and the extruder gets hot, the stepper skips steps as if filamnet is jammed.
I fixed mine by gluing (with conductive epoxy) heat-sinks on the sides of the extruder stepper and arranging a fan and shroud to blow through the heatsink pins, plus opening the doors of the enclosure if it gets too hot.
I felt possibly the surface of the filament was softening enough to not feed nicely. I admit, it doesn't sound likely, but one hot summer I had all these filament feed problems, and cooling the stepper resolved them, so...
I'm not at all convinced this fits your case, because in a BMG the filament drive won't be getting heat conducted from the stepper, but it's another variable to explore...
I do not think there are any wiring problems but I was planning on doing a rewire to switch to a drag chain configuration in the near future, so I will be re-seating / reconnecting everything.
I had not considered the power supply as a possible source of trouble as PETG prints consistently. I do not have another 24V power supply to to test with, however I would expect that if there was any dip in voltage output I would see a dimming in the lighting kit.
I do have a fluke meter with data logging capabilities if you happen to have some suggestions on what to look for.
Thank you for your input! I would love to get this put to rest!
@wouldstain said in Unable to print PLA:
................. What is vexing about this is that there is no actual blockage.
Well that depends on how you define blockage. The fact that you've had the extruder grinding away at the filament indicates that there must be some sort of restriction. As I tried to explain, PLA has a very low glass transition temperature of about 60 deg C. So, if you get heat creep up through the filament, or if you pull pull too much filament out when you retract, then you can end up with filament that is above the glass transition temperature, inside the heat break. When you then "unretract" the filament, the pressure from the extruder will the cause this softened filament to swell and bulge out sideways rather than travel forward, and so it (partially) blocks the heat break - or more precisely, it causes a restriction. I'm even more convinced that this is what is happening because you say that you can then manually extrude. Which indicates that the swollen filament inside the heat break has either cooled and hardened, or it has softened further and thus become less viscous.
I do not disagree about the difference in material properties being a factor, but I am baffled as to what else I can do to isolate the issue, although I have not yet tried replacing the heat break fan.
I will order a replacement heat break fan and give that a try, but otherwise, I am not sure what else is left.
Before you do that, reduce or disable retraction and see what happens. The print might have blobs and be stringy but it will prove a point one way or another. Ideally, look at using firmware retraction (G10/G11). This is much better because it enables you to tune it "on the fly" - both distance and speed.
EDIT. By they way, I've spent the last two years designing and building prototype hot ends, and before that spent a few years "taming" multi-input mixing hot ends. I've seen exactly the sort of thing you describe many times.
@deckingman Just tried multiple test prints with zero retraction
First one:
MFM stopped the job with the following error:
"Extruder 0 reported 'tooLittleMovement'"Output from M591 D0:
Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 130 agc 74, measured sensitivity 26.48mm/rev, min 0% max 105% over 606.9mm
If not for the MFM, this is where it would the extruder would start grinding away at the filament.
Repeated test with similiar results with temperatures ranging from 190C to 230C.
Also:
m572
Extruder pressure advance: 0.000 -
@wouldstain - Firts your AGC value is too low.
In my opinion, a 0.9 stepper on a geared extruder doesn't make sense. 0.9 always has less torque and less speed at the same voltage. Maybe it's one of the problems you have. PLA is relatively dense and is more difficult for the extruder to extrude.
As far as it connecting to PWM1, the connections are correct per
the Railcore build guide here.Do you use an external 5V supply for the Duex? Otherwise the BLTouch servo connection is shady
@deckingman Just tried multiple test prints with zero retraction ..................
But you can reliably print PET-G yes? Have you tried recently? It would be important to know for sure if this is related only to PLA or if some other factor has crept in between you trying PET-G and then switching to PLA.
You can check this by sending M122 - Vin voltage is monitored by the Duet.
@petrkroupa said in Unable to print PLA:
AGC can be too high (over 110 or so) but not really too low in our MFM design. A lower value indicates the magnetic field is being sensed more strongly, so better. (it is presumably possible to have a huge magnet and have a different problem but that does not apply here.
@wouldstain
can you try the following test:- Slice a file for PETG, that previously did not work for PLA, preferably with no retractions.
- Confirm it prints correctly with PETG
- manually edit just the temperature setting at the beginning of the file to be appropriate for PLA.
- reprint it with PLA.
After @deckingman's replies, I took a closer look at the heat break fan and realized it could be seated a bit lower
on the heat sink and moved it. Sadly it did not change the results.Tried another PLA job @200 and 215 with same result. M122 Voltage looks normal.
I will follow up with a PETG and PLA with manually adjusted temp and post results.
@petrkroupa The extruder and motor combination is common configuration for Railcore.
AFAIK I'm the only one having this issue so it's something specific to my components, physical installation, or slicing. However, the slicing has been tested by others already in previous thread and as I've mentioned, this has not always been a problem.Aside from cleaning the hotend, extruder and swapping out the nozzle, throat and bowden tubes, the rest of the configuration is relatively unchanged from initial build when it was working.
What kind of PLA are you trying to print?
Certain types of PLA require little or nor retraction.
@fcwilt Ive tried several brands of PLA, all with the same result.
@t3p3tony PETG printed as well as you would expect with no retraction or pressure advance... ugly corners and some stringing across axis markers on XYZ calibration cube.
PLA wont even finish the starting nozzle wipe at the moment. Tried three times.
Only differences in setup:
PETG:
Layer 1 Print temp: 235C
Layers > 1 Print temp: 230C
Z offset: -.15PLA:
Print Temp: 220C
Z offset: 0This is a new error:
M120 M83 G1 E100 F300 M121
Error: G0/G1: insufficient axes homedAlso found this in the console from earlier:
M290 R1 Z-0.05
Error: M290: insufficient axes homed
Error: M290: insufficient axes homedAgain, all axis are homed and machine starts up PETG jobs normally.
Not sure if this is related or not but I don't imagine I should be seeing these errors.Both gcode files attached.
@T3P3Tony One other thing I just remembered, not that it should make a difference... When I replaced the heatbreak, I used Boron Nitride paste rather than white thermal grease (had some handy at the time!) but I don't think this is the issue as the problem started prior to replacement.
To eliminate this as a variable, I have ordered some white thermal grease of the same composition as that provided by E3D in their hotend kits. It should be here tomorrow so I will pull apart the hotend, clean it and put in another heatbreak with white thermal grease. That should return it to as absolutely close to its original configuration as I can get it.
@deckingman's responses re: glass transition point have me going over everything in my head that could impact temperature at the heatbreak.
M122.txt
Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yesThat shows that between the last M122 and that M122 (or power up) you have not had any power issues with VIN.
M290 R1 Z-0.05
Error: M290: insufficient axes homedthat looks like you tried to babystep without the axis homed.
When you say it wont print past the pruge line, do you mean the filament monitor errors at that point?
I did indeed! one less thing to worry about!
Correct. In fact, I just took a look at the bed and the purge line looked to be about half of normal length when it paused.
m591 d0
Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 26.50mm/rev, allow 1% to 200%, check every 3.0mm, version 3, mag 131 agc >>75, measured sensitivity 1079.51mm/rev, min -31% max 133% over 16.9mm
Even though I've never set a firmware retraction value or used G10/G11, I did take a look at M207 just to see if there was anything and found this:
Tool 0 retract/reprime: length 2.00/2.00mm, speed 16.7/16.7mm/sec, Z hop 0.00mm
dont know if that matters w/o G10/G11 calls but it is there.
Duex has it's own positive lug on 24V power supply
That's not related. Duex boards only have a 12V buck converter, but no 5V.
There's a 5V_AUX_IN connector and a 5V_AUX_Select jumper for servo power. -
@wouldstain As bizarre as this sounds, try printing PLA at a lower temperature. If you can't even get beyond purging/priming, that indicates the flow restriction (lets call it that rather than blockage) happens very early on. So maybe you are seeing heat creep up through the filament during the warm up phase, such that the PLA inside the heat break is already above it's glass transition temperature by the time you try the first extrusion. Looking through your gcode file, I note that you are setting the temperature to 220 deg C which is at the top of the range for PLA. So if you set the temperature to the low end at say 190, that 30 degrees lower might be enough to prevent the filament inside the heat break from reaching it's glass transition temperature.
Is this a genuine E3D V6 by the way, or is it a clone? Is the heat sink cooling fan working properly? Try a high flow fan if you can.
