Duet 3 heatsink fan not working with smart effector
As the title says, ive recently decided to move all my deltas over to duet 3s, (thinking this would be an easy ans smart move).. Either way, its been a struggle but im almost there. My latest issue has been the heat sink fan not working. Can someone please guide me, the online guide is not very easy to follow once you start adding all these extra factors.
I have me fan connected to Out5 as suggested on the Smart effector guide, (even tho the duet 3 guide says out4...)
I have the 12v jumper on the smart effector so my lights are not dim.
My settings im not even sure where to start. thanks in advance! ! )
@eddygara you've got out5 mapped twice. Where are both fans connected?
@jay_s_uk I honestly don’t know man. I’m so confused by this set up vs the WiFi version.
I have the wires connected to my heat sink fan via out5 on the duet 3 board, snd then that connected to my duet smart effector.
@eddygara then comment out the F0 and P0 lines. Add a ; in front
@jay_s_uk just did still no luck
@eddygara said in Duet 3 heatsink fan not working with smart effector:
Are you waiting for the hotend to get above 45'C, as that's what is defined for the fan turn-on temperature?
Can you post your full config.g as text here?
Also can you send M98 P"config.g" and post the results? -
@rjenkinsgb ; Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Jan 03 2021 21:41:01 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Duet 3" ; set printer name
M665 R144 L290 B140 H282.90 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Drives
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X160.00 Y160.00 Z160.00 E833.16 ; set steps per mm
M566 X120000.00 Y120000.00 Z120000.00 E120000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X1080000.00 Y1080000.00 Z1080000.00 E1080000.00 ; set maximum speeds (mm/min)
M201 X4200.00 Y4200.00 Z4200.00 E5000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z-20 S1 ; set minimum Z; Endstops
M574 X2 S1 P"io0.in" ; configure active-high endstop for high end on X via pin io0.in
M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in; Z-Probe
M558 P1 C"io3.in" H30 F1200 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height
M557 R85 S20; Heaters
M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp0
;M950 F0 C"out5" Q500 ; create fan 0 on pin ;out5 and set its frequency
;M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
; Fans M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
So you're using out5 twice here. You'll need to trace back your wiring and identify which fan is connected where. Right now you're trying to define the part cooling fan and the heatsink fan to the same output.
@phaedrux look at the latest post they are turned off. I try to figure out which one was working. Neither start the fan. Wiring is hooked up to OUT5 as the smart effector recommendations suggest
It's currently set as a thermostatic fan to turn on when the heat sink gets above 45c. Are you test ing that way?
To force the fan on you can send
M106 P1 S1 H-1
Does that work? -
@phaedrux yes i have
@phaedrux can confirm fan doest work, must be wiring. but again these "how too config docs" are all over the place and do not have any good indication of how to set these up correctly in my opinion.
Well you have set it up correctly other than using the output pin twice. If it's a bad wire or some other damage that can make it seem like it's not setup correctly.
Can you connect the fan directly to the out5 pins to test to eliminate the wiring in between? If it still doesn't work, connect the fan to VIN and see if it's the fan itself or the out5 pins.
@phaedrux so I went ahead and tired this. My issue still remains. Can someone please help me diagnose this issue. Or else I’m stuck with 3 boards that can’t work for my machines.
I’m still using the out5 pin. My config files are fine. I’m directly connecting to the pins. And I’ve even used different fans. Someone has to know to problem here..
@eddygara have you tried connecting a fan directly to OUT5 on the Duet, to check that the OUT5 output is still working?
The last config you posted still showed out5 used in two different places - that cannot work as intended.
This is the heat & fan section from my config for a delta with smart effector, using a Duet3 6HC board.
I have no problems with heaters or fans; the heatsink fan turns on at 45'C and the part fan runs as set by the slicer G code.
; Heaters M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ; M308 S1 P"temp1" Y"PT1000" A"Tool" ; configure sensor 1 as a PT1000 on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans ; Part cooling M950 F0 C"out4" Q500 ; create fan 0 on pin out5 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; ; Hotend heatsink M950 F1 C"out5" Q500 ; create fan 1 on pin out6 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
The tool sensor type is different to yours and will need changing back to the 100K thermistor rather than the PT1000.
If you are still not sure, post a photo of the Duet board showing what's connected where??
