    PrusaSlicer with better RRF time estimates.
    3.1k
    • rjenkinsgbundefined
      rjenkinsgb
      Off topic, but people on here are are familiar with Prusaslicer and it's useful for anyone else starting with it:
      How the *$%ยฃ^!! do you get it to select a tool/extruder??
      I have three tools defined.
      As it is, the GCode has
      M104 S240 ; set temperature
      before the start gcode or any tool selection.
      For a multi-tool machine it needs the appropriate tool / extruder selection before any related settings, but I cannot find how to do that?
      It looks really good; I grabbed it last night and have spent a few hours going through the settings & trying to figure out all the appropriate options, and done a lot of searching, but just cannot find this info.
      Up to now, I've only ever used Cura, an old version originally specified for use with my Overlord pro delta printer.
      It's always worked fine for that, but is rather restricted for the Duet-based machine.
      In that, I've been setting the correct tool in the start gcode; nothing is sent before the start sequence.
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      • botundefined
        bot @rjenkinsgb
        @rjenkinsgb you have to put it in your start g-code. Also, select "RepRapFirmware" g-code flavor.
        *not actually a robot
        • botundefined
          bot
          I definitely released the n8 version of 2.4.0-beta2.
          It is... colourful. ๐Ÿ˜ˆ ๐Ÿ˜น ๐Ÿ‘พ ๐Ÿค ๐Ÿ•ต
          https://github.com/n8bot/PrusaSlicer/releases
          • botundefined
            bot
            Spammmming my own thread
            PCRundefined 1 Reply Last reply Reply Quote 2
            • PCRundefined
              PCR @bot
              @bot That is really good!
              • botundefined
                bot @PCR
                @pcr Thank you! Let me know how you feel after a few days.
                At first, I was reluctant about the colours but I went with what seemed to be best practices. I have since fallen in love with the colours. Dat sequential magma spectrum...
                PCRundefined 2 Replies Last reply Reply Quote 1
                • PCRundefined
                  PCR @bot
                  @bot will do.
                  Just have to adjust the hash of a file....
                  See my PR on upstream ๐Ÿ˜‰
                  https://github.com/prusa3d/PrusaSlicer/pull/7380
                  P-C-R opened this pull request in prusa3d/PrusaSlicer
                  closed Update Hash of wxWidgets #7380
                    rjenkinsgb
                    I did my first print using your slicer version yesterday afternoon/evening.
                    The time estimate was spot on.
                    And, the print quality is vastly better than the old Cura slicer I use with my Overlord Pro and initially used for the Duet machine!
                    The item sides have no noticeable layer lines or ripples, just a really good result.
                    Thanks!
                    Robert J.
                    • PCRundefined
                      PCR @bot
                      @bot
                      https://anonfiles.com/l8Hb19Yau7/PrusaSlicer_n8_b2-x86_64_AppImage
                      Linux AppImage Build ๐Ÿ˜‰
                      botundefined 2 Replies Last reply Reply Quote 1
                      • botundefined
                        bot @PCR
                        @pcr Very nice!! Thank you.
                        I saw that it's somewhat easy to do: use an existing app image, replace all the files. (Don't forget the resources folder! That's where the opengl shaders are located)
                        I wonder if this process is possible to do on macOS? I would hate to have to bug you every time to make an appimage for me! lol.
                        • botundefined
                          bot @PCR
                          @pcr Hey hey hey would you like to make an appimage for this latest release? Make sure you include the Resources folder from this release, because that is where the shaders are... and that is the main improvement!
                          https://github.com/n8bot/PrusaSlicer/releases/tag/version_2.4.0-beta2-release2-n8
                          PCRundefined 1 Reply Last reply Reply Quote 0
                          • PCRundefined
                            PCR @bot
                            @bot here ya go
                            https://anonfiles.com/56F150Ybu3/PrusaSlicer_n8_beta2_release2-x86_64_AppImage
                            and yes i am repacking the original prusa slicer appimage ๐Ÿ˜‰ thats faaaarrr easier
                            • botundefined
                              bot @PCR
                              @pcr Wow thank you so much!
                              Do you have any suggestions for improvements in the source code to make building/deploying on linux easier? I've never done it, but there are some potential improvements that could be made to the PrusaSlicer.desktop and gcodeviewer.desktop files. Do you have any idea what is best for them?
                              • botundefined
                                bot
                                Sorry, but these new shaders are out of this world:
                                • PCRundefined
                                  PCR @bot
                                  @bot thats true! look so good. Thats why i "reopend" the PS github talk about this
                                  But honestly i dont think they will do a change. Mainly because they had to adjust the docs.
                                  the build process of the PS is pretty simple. Once you have all deps. But you can link them. So you dont have to compile them each time. The PS compile time is pretty quick, at least with 16 cores ๐Ÿ˜‰
                                  The crazy thing is that if you compile the deps and PS the size of the folder is over 5GB.....
                                  They implemented a special options to add the desktop files in the menu bar. So now its easy.
                                  I am using PopOS (Debian Based) with Gnome DE. PopOS is great for getting a machine running quick and without hiccups. Its not the most "linuxy" distro out there. But for end users who have not the time to dig deep into the linux multiverse its great. Plus it handles the drivers pretty good. Including the switching of Laptop GPUยดs (Nvidia->Intel).
                                  • botundefined
                                    bot @PCR
                                    @pcr Interesting. I need to get back into linux.
                                    I think they will include the shader improvements. I submitted a stand-alone PR with only the lighting improvements so they can keep their ugly mishmash of colours lololo. The more I use these alternate colours the more I like them.
                                    I think they will incorporate the lighting changes because their upcoming Prusa XL, and they have added the multimaterial painting option. Their current visualization has no colour accuracy whatsoever. This new visualization makes every visualization look like silk filament lol. So shiny, but not too much, and also bright and easy to see.
                                    That is, as long as the user GPU settings can get ride of the moirรฉ.
                                    • botundefined
                                      bot
                                      Spam spam spam spam
                                        Phaedrux Moderator @bot
                                        @bot said in PrusaSlicer with better RRF time estimates.:
                                        Virtual machines come in very handy. https://www.virtualbox.org/ Linux in a window.
                                        • botundefined
                                          bot @Phaedrux
                                          @phaedrux Yeah I really have no excuse lol. Windows has linux on it now ffs!!! I could probably figure out how to do it natively on the WSL.
                                          • botundefined
                                            bot
                                            I have made yet another release. I admit, it's slim on changes from me. It's mostly incorporating some good fixes and changes from prusa master, and refactoring my changes to go with it.
                                            I have yet again tweaked the camera, lighting, and colours. Most noticeably, I swapped a few colours for colourblind-friendliness.
                                            https://github.com/n8bot/PrusaSlicer/releases/tag/version_2.4.0-beta2-release3-n8
                                            PCRundefined 1 Reply Last reply Reply Quote 3
