    Z setting ??
    Config Tool
    591
    • Robertoundefined
      Roberto @oliof
      @oliof I put M208. It refuses to go lower than Z-0.5mm. I don't understand why?
      Robertoundefined 1 Reply Last reply Reply Quote 0
      • Robertoundefined
        Roberto @Roberto
        @roberto I can't get the bed up near the nozzel
        • oliofundefined
          oliof @Roberto
          @roberto Set Z minimum to -1 or -4 for adjustment. But be careful to not break your mechanics.
          • Robertoundefined
            Roberto @oliof
            @oliof Once I get to -0.5, the engines don't run anymore when I ask it to go to -1
            • Robertoundefined
              Roberto @Roberto
              @roberto Do I have to raise the plate manually?
              • oliofundefined
                oliof @Roberto
                @roberto when you adjust the Z axis parameter, it should move via GCode, provided it's mechanically possible.
                • Robertoundefined
                  Roberto @oliof
                  @oliof I move the Z axis with the dashboard move command.
                  But, at Z-0.5mm, the motors don't respond anymore?
                  And the plate does not go up anymore. When I manually put the bed against the head, once I do the Z home, the bed goes back too far from the head. And even when I lower manually the tray voluntarily too much. I make the Zhome and again it comes to put itself with the same spacing with the head
                  • Robertoundefined
                    Roberto @Roberto
                    @roberto he writes:
                    Error: Z probe already triggered at start of probing move Error: G0/G1 : insufficient axes homed
                      Can you share your config.g and homeall.g and homez.g files as well as what firmware version you're using?
                      @oliof said in Z setting ??:
                      @Roberto Can the bed physically move higher or is it hitting an endstop or part of the frame preventing it from getting closer to the nozzle?
                      • Robertoundefined
                        Roberto @Phaedrux
                        @phaedrux Hello,
                        I did some more tests.When I do the homes, I can't get it to go lower than -0.5. But with the baby stepping, I can get the tray up to the nozzel.
                        I go into the config and make the change.
                        Then when I do the homes, the plate goes back too low and again from -0.5 I can't make it go up.
                        Here are the settings.
                        I think that it is the BL-Touch that is out of adjustment.
                        How can I recalibrate the BL-Touch?
                        Thanks for the help.
                        SYSTEME.docx
                          Phaedrux Moderator @Roberto
                          @roberto said in Z setting ??:
                          Yes it sounds like you need to re-measure your bltouch offset and or ensure it's mounted in the right height.
                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                          • Robertoundefined
                            Roberto @Phaedrux
                            @phaedrux Ok! I will check the calibration of the BLTouch.
                            Thanks for the info.
