    Z setting ??
    Config Tool
    591
    • Robertoundefined
      Roberto @Roberto
      @roberto I can't get the bed up near the nozzel
      • oliofundefined
        oliof @Roberto
        @roberto Set Z minimum to -1 or -4 for adjustment. But be careful to not break your mechanics.
        Robertoundefined 1 Reply Last reply Reply Quote 0
        • Robertoundefined
          Roberto @oliof
          @oliof Once I get to -0.5, the engines don't run anymore when I ask it to go to -1
          • Robertoundefined
            Roberto @Roberto
            @roberto Do I have to raise the plate manually?
            • oliofundefined
              oliof @Roberto
              @roberto when you adjust the Z axis parameter, it should move via GCode, provided it's mechanically possible.
              • Robertoundefined
                Roberto @oliof
                @oliof I move the Z axis with the dashboard move command.
                But, at Z-0.5mm, the motors don't respond anymore?
                And the plate does not go up anymore. When I manually put the bed against the head, once I do the Z home, the bed goes back too far from the head. And even when I lower manually the tray voluntarily too much. I make the Zhome and again it comes to put itself with the same spacing with the head
                • Robertoundefined
                  Roberto @Roberto
                  @roberto he writes:
                  Error: Z probe already triggered at start of probing move Error: G0/G1 : insufficient axes homed
                    Can you share your config.g and homeall.g and homez.g files as well as what firmware version you're using?
                    @oliof said in Z setting ??:
                    @Roberto Can the bed physically move higher or is it hitting an endstop or part of the frame preventing it from getting closer to the nozzle?
                    • Robertoundefined
                      Roberto @Phaedrux
                      @phaedrux Hello,
                      I did some more tests.When I do the homes, I can't get it to go lower than -0.5. But with the baby stepping, I can get the tray up to the nozzel.
                      I go into the config and make the change.
                      Then when I do the homes, the plate goes back too low and again from -0.5 I can't make it go up.
                      Here are the settings.
                      I think that it is the BL-Touch that is out of adjustment.
                      How can I recalibrate the BL-Touch?
                      Thanks for the help.
                      SYSTEME.docx
                        Phaedrux Moderator @Roberto
                        @roberto said in Z setting ??:
                        Yes it sounds like you need to re-measure your bltouch offset and or ensure it's mounted in the right height.
                        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                        • Robertoundefined
                          Roberto @Phaedrux
                          @phaedrux Ok! I will check the calibration of the BLTouch.
                          Thanks for the info.
