Z setting ??
@roberto Set Z minimum to -1 or -4 for adjustment. But be careful to not break your mechanics.
@oliof Once I get to -0.5, the engines don't run anymore when I ask it to go to -1
@roberto Do I have to raise the plate manually?
@roberto when you adjust the Z axis parameter, it should move via GCode, provided it's mechanically possible.
@oliof I move the Z axis with the dashboard move command.
But, at Z-0.5mm, the motors don't respond anymore?
And the plate does not go up anymore. When I manually put the bed against the head, once I do the Z home, the bed goes back too far from the head. And even when I lower manually the tray voluntarily too much. I make the Zhome and again it comes to put itself with the same spacing with the head -
@roberto he writes:
Error: Z probe already triggered at start of probing move Error: G0/G1 : insufficient axes homed -
Can you share your config.g and homeall.g and homez.g files as well as what firmware version you're using?
@oliof said in Z setting ??:
@Roberto Can the bed physically move higher or is it hitting an endstop or part of the frame preventing it from getting closer to the nozzle?
@phaedrux Hello,
I did some more tests.When I do the homes, I can't get it to go lower than -0.5. But with the baby stepping, I can get the tray up to the nozzel.
I go into the config and make the change.
Then when I do the homes, the plate goes back too low and again from -0.5 I can't make it go up.
Here are the settings.
I think that it is the BL-Touch that is out of adjustment.
How can I recalibrate the BL-Touch?
Thanks for the help. -
@roberto said in Z setting ??:
Yes it sounds like you need to re-measure your bltouch offset and or ensure it's mounted in the right height.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
@phaedrux Ok! I will check the calibration of the BLTouch.
Thanks for the info.
